Terminator 3 Groni FS Mod (RPG Fixed)
Strangeleo
It kind of does i think, but not how it should, i think the lights just work around the spider it doesnt actually spin yet. h4ck3r and a guide how to set it up somewhere
  • 3 weeks later...
  • Replies 111
Hi, i am also having problems running this table. The DMS does not stay in position (i will try the solution presented here later) The machine keeps looking for missing balls, when i run the table in hyperpin. In VP it works just fine.
Also no backglass when i switch UVP off ? THis should work if i am not mistaken. I am using the latest version of UVP server.
Any ideas ?
Hi, still having problems. I have commented the line .SetDisplayPosition 1830, 460 , but now i get an error like Idirect3dDevice7 cannot be made ?
OK Guys got it working. TYpe O in the setting.ini file. I put in a resolution of 2080, 1024. Should be 1280 by 1024 of course :top:
Man, i am troubleshooting more than actually playing some pinball :)
So how do you stop getting the error message on startup when running the table with a uvp backgalss
Wrong number of arguments or invalid property assignements
after oking the message the table seems to play fine!
I have no idea why it appears, but changing it makes dragging of the DMD possible like in the other tables. Does not hurt to try i think.
All ".SetDisplayPosition 1830, 460" does is lock where the DMD is dislpayed. When you comment it out you can move the DMD wherever you want and UVP server will not crash.
Simple way to do it yourself is launch the game, hit print screen, then paste that in paint or whatever image editing program you use, save it out as a png with the correct naming convention (and size) and drop it in your table image folder. Not sure if you will get the backglass as well with a print screen. There is a way to just copy one screen. I forget the key you hit though.
  Flying Dutchman said:
'.SetDisplayPosition 1830, 460 was already opted out in my last T3 version to avoid the error msg, .. ;)
It does fix it appropriately. :)
Cheers,
FD.
That on the UVP side of things, or table?
  • 2 months later...
  • 5 months later...
  • 8 months later...
Is there a DMD for this game? Everytime I've loaded it nothing but the playfield shows up... Checked the script, there's code there for the DMD, but nothing pops up. Tried the Alt-Tab trick and still nothing....
  • 3 weeks later...
I did a little video with some modifications done to this table. It improves this table, making it flow more original. 1 issue that is on the down side is that I have to have the gravity set a little higher than ussual, so gameplay is fast and tuff.
[YOUTUBE HD]NKseaScP7hs[/YOUTUBE HD]
