Creezz67 Posted November 1, 2016 Posted November 1, 2016 Does anyone know where to find an Atari 2600 default theme that works correctly on NVIDIA SHIELD TV ? I only have one with swf files that won't show up on it, and the other older version I have won't show the boxart for artwork3 and artwork4 Thanks in advance
thatman84 Posted November 1, 2016 Posted November 1, 2016 I have one. But not online for a few hours. At work Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted November 2, 2016 Posted November 2, 2016 BadHemi posted a mega link to his theme collection on another thread. I hope he won't mind if I help you by linking it in this post. It's nearly 900MB but it's a pretty comprehensive collection, I did check and there is an Atari 2600 with png rather than swf. thatman84 might well give you the same theme (lol) or perhaps his is more to your taste. If you ever need other themes I think BadHemi has you well covered for the most part. All the best with your Shield setup https://mega.nz/#!HZMmhKAS!em43BHENgJHM--OWbtILIP7DzwckbvKF2UK1KB_iU40 "There is so much more and beckons me. To look through to these, infinite possibilities..."
thatman84 Posted November 2, 2016 Posted November 2, 2016 I grabbed @badhemithemes, not checked them out properly but they seem to be structured like main menu themes. I could be wrong. With the forum down last night I couldn't put one here. i have adjusted mine but probably is the same one. I will try and post it up here. I moved stuff around to fit my 1080 screen better. I will drop the settings file with it because I expect it has custom wheel text aswell. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted November 2, 2016 Posted November 2, 2016 6 hours ago, thatman84 said: I grabbed @badhemithemes, not checked them out properly but they seem to be structured like main menu themes. I could be wrong. With the forum down last night I couldn't put one here. i have adjusted mine but probably is the same one. I will try and post it up here. I moved stuff around to fit my 1080 screen better. I will drop the settings file with it because I expect it has custom wheel text aswell. Oh! I thought he was after main menu themes. I'll attach a default.zip for the Atari 2600 which is .png Default.zip "There is so much more and beckons me. To look through to these, infinite possibilities..."
thatman84 Posted November 2, 2016 Posted November 2, 2016 I think my next task for the Android base pack will be main menu and default theme pack, specifically for Android. I grabbed badhemi's Turbo Grafx main menu one last night but the background is screwed. He did have another one I could try though and I have all the ones I tested before. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted November 2, 2016 Posted November 2, 2016 4 minutes ago, thatman84 said: I think my next task for the Android base pack will be main menu and default theme pack, specifically for Android. I grabbed badhemi's Turbo Grafx main menu one last night but the background is screwed. He did have another one I could try though and I have all the ones I tested before. Yes some have the background as .swf but the rest of the artwork in .png. Many of the systems had alternatives to choose from and check. The Atari Default.zip I attached has everything as .png...it's an old theme though, I'm sure you guys have something better but I figured it would help out the OP for now "There is so much more and beckons me. To look through to these, infinite possibilities..."
Honosuseri Posted November 2, 2016 Posted November 2, 2016 11 minutes ago, thatman84 said: I think my next task for the Android base pack will be main menu and default theme pack, specifically for Android. I grabbed badhemi's Turbo Grafx main menu one last night but the background is screwed. He did have another one I could try though and I have all the ones I tested before. P.S I look forward to seeing your Android Base pack in time. I'm working on adding the Android games (really want a flashy way to show off ZenPinball) to my Hyperspin setup. Just wanted to thank you for all your hard work...and the tuts you've done to assist us all "There is so much more and beckons me. To look through to these, infinite possibilities..."
thatman84 Posted November 2, 2016 Posted November 2, 2016 30 minutes ago, Honosuseri said: P.S I look forward to seeing your Android Base pack in time. I'm working on adding the Android games (really want a flashy way to show off ZenPinball) to my Hyperspin setup. Just wanted to thank you for all your hard work...and the tuts you've done to assist us all Thanks man the android base pack is out. Its in upload here->templates. just realised we don't have signatures ATM. It's nothing special just and adaption of the 1.3.4 PC version of Hyperspin. there is an android games database in the works I know of, which has 11000+ games listed so far!!! Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted November 2, 2016 Posted November 2, 2016 @cataclysm67 Here is the one I use and the settings file. FYI my special art my be different to yours so dont copy that part. Box and cart art goes in Artwork 3 & 4 cant remeber which way round default.zip Atari 2600.ini Im not keen on Game text position but cant see anywhere else for it Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted November 3, 2016 Author Posted November 3, 2016 Thanks for that mate, much appreciated. Just what I was looking for.
