aftermath17 Posted September 19, 2017 Posted September 19, 2017 uoYabause has been replaced by Yaba Sanshiro on Android. This is a very good Sega Saturn EMU with excellent compatibility. If you still have uoYabause as your EMU in your Hyperspin cfg you'll notice it no longer runs. http://www.uoyabause.org/blogs/46
sonkun Posted September 20, 2017 Posted September 20, 2017 The new Hyperspin exe is exe=org.uoyabause.uranus/org.uoyabause.android.tv.GameSelectActivity Not sure about the parameters line. Are you able to get into the settings? The moment I try I get force closed.
thatman84 Posted September 20, 2017 Posted September 20, 2017 Will have to check this out. Guessing it only stops if it auto updates tbe app Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
sonkun Posted September 20, 2017 Posted September 20, 2017 I just tried it again and right now I'm able to get into settings. I didn't change or do anything but somehow I got in now. Only thing i need to figure out now is what needs to go in that parameters line to auto start the games again. Also to add in, it looks like the scanline filter has been fixed. Before it gave off this weird greenish tint across the whole screen when applied, now games look a lot better although now a little darker but now games at least look like how they should with that old school crt look. Even Bulk Slash seems to be playing fine without freezing anymore (I recommend everyone here to play that game if you haven't already)
Honosuseri Posted September 22, 2017 Posted September 22, 2017 I had uoYabause sideloaded it still worked but I have now switched to Yaba Sanshiro. This works on my Shield TV setup...I'll put a snippet from my .ini file below. exe=org.uoyabause.uranus/org.uoyabause.android.Yabause romextension=bin,cue parameters=org.uoyabause.android.FileNameEx "There is so much more and beckons me. To look through to these, infinite possibilities..."
Pouteur Posted September 22, 2017 Posted September 22, 2017 Here is the new exe to use in your setting : exe=org.uoyabause.uranus/org.uoyabause.android.Yabause
funkboy27 Posted November 28, 2019 Posted November 28, 2019 Anyone have the new PARAMETER settings for yaba? I found the proper EXE as it’s different than Uoyabouse. However can’t get the games to load automatically with any of the parameters I’ve found. suppose I could use an older version but would rather not if I can avoid it.
madsonicsystem Posted February 15, 2020 Posted February 15, 2020 On 11/28/2019 at 12:33 AM, funkboy27 said: Anyone have the new PARAMETER settings for yaba? I found the proper EXE as it’s different than Uoyabouse. However can’t get the games to load automatically with any of the parameters I’ve found. suppose I could use an older version but would rather not if I can avoid it. Did you manage to get this working? Stuck with the same problem
QuinnHQ Posted March 2, 2020 Posted March 2, 2020 I am also struggling to load yaba sanshiro through Hyperspin. Does anyone have any guidance for this?
funkboy27 Posted March 12, 2020 Posted March 12, 2020 Havent tackled this since I posted, but i'll try and post the solution if i get it :)
