connorsdad Posted July 24, 2014 Author Posted July 24, 2014 How can I test everything? I have a contactor wired upto SL, both boards connected to the ledwiz. Tried out "Simple LED test" from ledblinky and nothing happens. I've found lwsend.exe but can't seem to get anything to work with that either. I want to make sure I know how things work before I install everything into my cab.
connorsdad Posted July 26, 2014 Author Posted July 26, 2014 How would I go about adding undercab rgb to my setup? https://www.dropbox.com/s/b1cwhpbwn924c42/Screenshot%202014-07-26%2011.24.08.png Would I have to lose 3 of the first 4 ports?
mikekim Posted July 26, 2014 Posted July 26, 2014 easiest solution without sacrificing any led wiz ports.. Sound to light controller
connorsdad Posted July 26, 2014 Author Posted July 26, 2014 easiest solution without sacrificing any led wiz ports..Sound to light controller I've tried sound activated leds before using the pacled and ledblinky on my arcade cab, I wasn't that impressed tbh, it would be better tied to a table event. I'll probably just link them to an external remote and use them just for decorative purpose like those on my arcade cab.
zebulon Posted July 26, 2014 Posted July 26, 2014 just use the exit, extra ball and spare outputs. Exit was never implemented as a rom controlled light, extra ball is redundant and the spare is just that, a spare. I know so much about so little that I could teach you everything there is to know about nothing....
connorsdad Posted July 26, 2014 Author Posted July 26, 2014 just use the exit, extra ball and spare outputs. Exit was never implemented as a rom controlled light, extra ball is redundant and the spare is just that, a spare. Spare?
zebulon Posted July 26, 2014 Posted July 26, 2014 on the upper board there is a spare output. have you read the documentation on the kit? There is a couple of diagrams in it that label the outputs and what one corresponds to what terminal on the ledwiz. I know so much about so little that I could teach you everything there is to know about nothing....
connorsdad Posted July 26, 2014 Author Posted July 26, 2014 on the upper board there is a spare output.have you read the documentation on the kit? There is a couple of diagrams in it that label the outputs and what one corresponds to what terminal on the ledwiz. But I have used all 32 ports?
zebulon Posted July 26, 2014 Posted July 26, 2014 Well, if you've maxxed out the ports and there is nothing that you can shift to a fixed/constant output by bypassing the board then your options are to hardwire the leds and use a controller (they usually come with a remote) or add a second ledwiz into the mix. I know so much about so little that I could teach you everything there is to know about nothing....
connorsdad Posted July 30, 2014 Author Posted July 30, 2014 So I finally got my ledwiz and dof working But.. When running led blinky simple led test and I run through the ports to test I get some strange behaviour, I thought each port would be one colour. 31 = led1 blue 30 = led1 green 29 = led1 red 28 = led1 white, led2 blue 27 = led1 white, led2 green 26 = led1 white, led2 red 25 = led1 white, led3 blue 24 = led3 green 23 = led3 red 22 = led4 blue 21 = led4 green 20 = led3 yellow, led4 white 19 = led3 yellow, led4 cyan, led5 turquoise 18 = led3 yellow, led4 cyan, led5 turquoise 17 = = led3 yellow, led4 cyan, led5 red RGB Led bar came straight from zeb so cant see it being the led soldering, the ledwiz is soldered to the adaptor so no loose connections, no connections have been soldered together by using too much solder, any ideas?
connorsdad Posted August 12, 2014 Author Posted August 12, 2014 All except 1 contactors are in, I just hope I have the location correct.
connorsdad Posted August 12, 2014 Author Posted August 12, 2014 Two pieces of 16mm mdf glued together, routed with a round over bit and covered in carbon fibre vinyl for the gap in between the lock down bar and the screen.
connorsdad Posted August 12, 2014 Author Posted August 12, 2014 Screen placement and surround completed today. The black screen surround is from here http://www.wickes.co.uk/Wickes-Angle-Black-PVC-15mmx15mm-x1m/p/188241 . 15mm on three sides and 20mm on one side due to the metal surround being larger on one side. Yes my garage is like a building site at the minute lol.
connorsdad Posted August 13, 2014 Author Posted August 13, 2014 Anyone know if this will cause me trouble, having zebs boards next to the sub ?
connorsdad Posted August 13, 2014 Author Posted August 13, 2014 Photos from today Power socket soldered and fitted, neutrik usb fitted, rear fan+guard fitted and all hardware installed (after a little customisation to the cab to fit the shaker where I wanted it) Where should I mount my final contactor bumper jet - back (less noise)? As you can see from this photo my options are limited, too far back and its position won't relate to what's happening on screen. What about under the cross member that has the other bumper jet contactors fixed to it ?
connorsdad Posted August 14, 2014 Author Posted August 14, 2014 And I'm almost done Buttons to be wired to ipac and cab graphics to do. Excuse the rubbish in the background, you should see the foreground :/ The feedback coming from the right place is phenomenal, once again thank you to Zebulon for his fantastic kit and brilliant support
connorsdad Posted August 14, 2014 Author Posted August 14, 2014 I did start off tidy with my wiring but by time I finished it looked like a birds nest
njgsx96 Posted August 15, 2014 Posted August 15, 2014 Wow, that looks amazing! great job, nice and clean!
connorsdad Posted September 1, 2014 Author Posted September 1, 2014 I've started work on the artwork, my wife has again come up with the name for my cabinet "Mistress Pinball" due to the amount of time I spend with her away from my wife Please note the side rails will be above the artwork shown here, this image is what will be in view when installed. Please critique, too plain, too dark etc. Thanks Higher Res here https://dl.dropboxusercontent.com/u/7794786/Pinball%20build/Prototype.jpg
connorsdad Posted November 15, 2014 Author Posted November 15, 2014 So I changed my mind regarding the artwork, after seeing Stuzzas Tron Composition I decided to reproduce it myself. You can grab my artwork files here https://mega.co.nz/#F!UA0wyCja!FMYopk0YhoV11SqGMIgidw
senseless Posted November 22, 2014 Posted November 22, 2014 wOw that looks great. Congratz on (almost) finalizing your cabinet. I'm still not sure which theme I will use for my cab but Tron is definitely one of my favorites. Thanks for sharing the artwork, much appreciated!
zebulon Posted November 25, 2014 Posted November 25, 2014 Nicely done!! I know so much about so little that I could teach you everything there is to know about nothing....
