blur Posted May 23, 2011 Posted May 23, 2011 there no manual first page, second post of this thread My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Guest tornado Posted May 23, 2011 Posted May 23, 2011 i dont see any of this in settings Options: useExitScreen = true This options controls if Exit321 screen is used. usePauseKey = true This option controls if Pause key (pauseVPinball) is used useLoadScreen = true This options controls if loading screen is used. UseExitAsPause = true This option controls if short press on exit is used as Pause. saveFPTables = true This option controls if we save FP table after change of table position with Scroll Lock. fadespeed = 25 This is actually length of sleep command that is used on slider on loading screen and on Exit 321 screens. It is time in milliseconds script will sleep before going on to the next loop. If it is smaller wait is shorter and slider on loading screen and exit 321 screens will be faster. If it is larger wait is longer and loading slider and exit 321 screens are slower.
HyphyCus Posted May 23, 2011 Posted May 23, 2011 Hipi this is a great find and it works. Check you code and after: WinWaitActive, ahk_class VPPlayer ;Wait for vp to be Ready before killing Gui blackScreen just add: Send {F3} I've tried to add winactivate of vpplayer in loading screen loop but it completely breaks nag screen removal functionality. I've tried also clicking on mame window and on vpplayer but it is so unreliable So try this and let me know if it works on all tables, and i will put it in next release. It's working perfect now.
HyphyCus Posted May 23, 2011 Posted May 23, 2011 i dont see any of this in settingsOptions: useExitScreen = true This options controls if Exit321 screen is used. usePauseKey = true This option controls if Pause key (pauseVPinball) is used useLoadScreen = true This options controls if loading screen is used. UseExitAsPause = true This option controls if short press on exit is used as Pause. saveFPTables = true This option controls if we save FP table after change of table position with Scroll Lock. fadespeed = 25 This is actually length of sleep command that is used on slider on loading screen and on Exit 321 screens. It is time in milliseconds script will sleep before going on to the next loop. If it is smaller wait is shorter and slider on loading screen and exit 321 screens will be faster. If it is larger wait is longer and loading slider and exit 321 screens are slower. After you install the latest FPLaunch MOD script and run HP once, go into your Settings directory of HP, and at the bottom of the Settings.ini you'll see the [FPLaunch] section.
HyphyCus Posted May 23, 2011 Posted May 23, 2011 So its blank after the [FPLaunch] section? Or there is no section in your Settings.ini?
Guest tornado Posted May 23, 2011 Posted May 23, 2011 (edited) found set all to true still no text text only show on wheel menu this is settings [FPLaunch] exitScriptKey=q & s exitEmulatorKey=e toggleCursorKey=t pauseVPinball=p hideCursor=true hideDesktop=true hideTaskbar=true useExitScreen=true usePauseKey=true useLoadScreen=true fadespeed=25 UseExitAsPause=true exitEmulatorKey2=1 exitEmulatorKey3=Enter pauseFPKey=RButton saveFPTables=true Edited May 23, 2011 by tornado
HyphyCus Posted May 23, 2011 Posted May 23, 2011 The text is there if you don't have a wheel image for the table. Where else are you expecting text to be for?
blur Posted May 23, 2011 Posted May 23, 2011 tornado did you installed images from fplaunch 1.294 version? My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted May 23, 2011 Posted May 23, 2011 It's working perfect now. Great My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Guest tornado Posted May 23, 2011 Posted May 23, 2011 tornado did you installed images from fplaunch 1.294 version? it's working now to quit i push E (pause) than enter.
blur Posted May 23, 2011 Posted May 23, 2011 Great! you can also hold e for few seconds to exit My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
mwong168 Posted May 24, 2011 Posted May 24, 2011 I have a few glitches and wondering if anyone has experienced the same thing. 1. When I am scrolling through tables in HP and hold down one of the flipper buttons and scroll through say 20-30 tables, when I let go I can't do anything anymore. 2. When I load a table the rendering table animation appears and then it stay on screen while ROM is loaded up on my third display. To fix this I exit the table and open it again and sometimes it takes 2-3 tries before it finally works. Never had these and not sure if it is just a Win7 issue or FPlaunch cause I never had these issues before on my XP setup.
Numiah Posted May 24, 2011 Posted May 24, 2011 The 2nd issue you described happens to me as well from time to time. I'm using 1294 btw **Each pinball machine is a tiny universe... that we control** My Build Overview My Computer Specifications
mwong168 Posted May 24, 2011 Posted May 24, 2011 The 2nd issue you described happens to me as well from time to time.I'm using 1294 btw Using same version as well, oh well. I might try disabling the load animation screen in the settings.ini to see if it helps. I would go back to the older 1.1 version but I needed to re-map my exit key to "e" instead of "esc".
blur Posted May 24, 2011 Posted May 24, 2011 1, can't be due to fplaunch cause it is not executed yet, so it must be win7 issue 2. try 1.295 wip 3, try also alt-tab to see what's going on. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted May 25, 2011 Posted May 25, 2011 I have a few glitches and wondering if anyone has experienced the same thing. 1. When I am scrolling through tables in HP and hold down one of the flipper buttons and scroll through say 20-30 tables, when I let go I can't do anything anymore. 2. When I load a table the rendering table animation appears and then it stay on screen while ROM is loaded up on my third display. To fix this I exit the table and open it again and sometimes it takes 2-3 tries before it finally works. Never had these and not sure if it is just a Win7 issue or FPlaunch cause I never had these issues before on my XP setup. I experienced both of these issues regularly when I used Windows 7. I switched to XP and both issues went away completely. I have had nothing but an improved cab experience after switching to XP. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
mwong168 Posted May 25, 2011 Posted May 25, 2011 1, can't be due to fplaunch cause it is not executed yet, so it must be win7 issue If the Rendering Table animation is showing up on screen doesn that mean fplaunch been executed already? I experienced both of these issues regularly when I used Windows 7. I switched to XP and both issues went away completely. I have had nothing but an improved cab experience after switching to XP. Glad to hear I'm not the only one My problem is the opposite of yours and I have been running XP on my cab the past year. Then I added an LEDWiz to the mix and 5RGB Led flashers to my setup and then most of my tables started to stutter. I had my XP setup tweaked very well and used the 182.50 drivers and even tried a fresh install using the latest as some had posted improved performance using 270.61 in XP. I did and still had table stutter where as with a fresh Win7 64bit and 270.61 drivers installed without tweaking the OS yet, the same tables (Radical, Party Zone, Back to the Future) that would stutter immediately upon launching the ball in XP played very smooth. I didn't bother with the F11 FPS value in VP as I knew these three tables were pretty bad especially BTTF when you launch the ball it is unplayable and by the time things catch up your ball has drained. So right now I guess I just have to accept these minor glitches in Hyperpin as well as longer table exit times for much improved table performance with LEDWiz enabled. The flashing RGB LEDs really add quite a bit to the playing experience and glad I have them working smoothly now.
blur Posted May 28, 2011 Posted May 28, 2011 (edited) If the Rendering Table animation is showing up on screen doesn that mean fplaunch been executed already? 1. was the answer for problem no. 1 - scrolling though tables and freezing you have loading window while you scroll through tables? for 2. you really have to use latest version cause that code is changing all the time, as soon as i can pinpoint a bug and repeat it on my rig i fix it but, i did not tested much on win7 (i can't, kids are playing on that comps all the time ) so everything is possible Edited May 30, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
rockyrocket Posted July 9, 2011 Posted July 9, 2011 Hi blur, all working fine here on win7!. I have though observed that if i change the fadespeed value to 15 that this then breaks the "use exit as pause" functionality. This is not a problem for me but may be of interest to others. I also found these two alternative pause screens googling about... http://www.retrovicio.org/foro/showthread.php?11973-Pausa-en-Hyperpin Thanks again for all the hard work!. Starwars build Tron build Tempest build
rockyrocket Posted July 9, 2011 Posted July 9, 2011 Yep thats what i use, its only tranparent in vp though, black background in fp!. To clarify my earlier point if the fade speed is too short then a short press has no effect but a long one exits cleanly. Starwars build Tron build Tempest build
rockyrocket Posted July 9, 2011 Posted July 9, 2011 Hyphycus did you just save the image from the page or download from the links? Starwars build Tron build Tempest build
blur Posted July 9, 2011 Posted July 9, 2011 Hi blur, all working fine here on win7!.I have though observed that if i change the fadespeed value to 15 that this then breaks the "use exit as pause" functionality. This is not a problem for me but may be of interest to others. I also found these two alternative pause screens googling about... http://www.retrovicio.org/foro/showthread.php?11973-Pausa-en-Hyperpin Thanks again for all the hard work!. Tnx rocky. For fadespeed - it runs faster on faster systems. if you set it too low loop on exit key will be quicker so maybe if it is too fast you can't press esc short enough. Try just to touch it and release it. What buttons you have? For pause to be called you have to release it within first 10 loops. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Create an account
Register a new accountSign in
Sign In Now
