blur Posted October 11, 2011 Posted October 11, 2011 I'm looking for some good free command line image rotator?????? I need it to rotate screen shots. I've made the code that reads the description of running table from xml, adds one hot key for print screen, on press of that key saves print screen image in hyperpin\media\blabla\table desc. I just need to rotate it (since hp needs 180 degrees rotated images). Found some image converter plus but it is commercial. Found some linux tools also, but ... So any body knows free windows program that will do this? My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
bent98 Posted October 11, 2011 Posted October 11, 2011 http://annystudio.com/software/jpeglosslessrotator/ will that work?
pinballlooking Posted October 11, 2011 Posted October 11, 2011 I cannot find the link to download HyperSettings program I see the screen shots it looks great. My Pinball Cabinet:http://www.hyperspin-fe.com/forum/showthread.php?t=15290
Numiah Posted October 11, 2011 Posted October 11, 2011 That's why you have focus problems. nt comp. mode solves focus problems. Thanx for the tip O'Mighty Blur ! I'll give it a go. **Each pinball machine is a tiny universe... that we control** My Build Overview My Computer Specifications
Numiah Posted October 11, 2011 Posted October 11, 2011 I'm looking for some good free command line image rotator??????I need it to rotate screen shots. I've made the code that reads the description of running table from xml, adds one hot key for print screen, on press of that key saves print screen image in hyperpin\media\blabla\table desc. I just need to rotate it (since hp needs 180 degrees rotated images). Found some image converter plus but it is commercial. Found some linux tools also, but ... So any body knows free windows program that will do this? I always use Windows for this to bulk rotate files. Win 7 and XP both have that function built in. for Win 7 : Select multiple files, open file menu, click rotate left twice. Easy peasy. XP I have to look up, but I know it's capable of doing the same. **Each pinball machine is a tiny universe... that we control** My Build Overview My Computer Specifications
Darkfall Posted October 11, 2011 Posted October 11, 2011 I always use Windows for this to bulk rotate files.Win 7 and XP both have that function built in. for Win 7 : Select multiple files, open file menu, click rotate left twice. Easy peasy. XP I have to look up, but I know it's capable of doing the same. He needs it to be a command line tool, so he can execute it from the FPLaunch script, though. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
Numiah Posted October 11, 2011 Posted October 11, 2011 He needs it to be a command line tool, so he can execute it from the FPLaunch script, though. Crap, I wasn't paying attention. Whoopsy. **Each pinball machine is a tiny universe... that we control** My Build Overview My Computer Specifications
mameman Posted October 11, 2011 Posted October 11, 2011 He needs it to be a command line tool, so he can execute it from the FPLaunch script, though. I think Irfanview can do this, its free and has a batch mode. PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
samwyze Posted October 12, 2011 Author Posted October 12, 2011 (edited) as for ahk_l i don't think it's a good idea to jump into it, thousands of bugs could appear I've been using it for the current wip, then been adding necessary changes to convert back to ahk_standard, as long as you stick with ansi, the only differences as far as the end user is concerned are added features, most of the bugs in ahk_l were ironed out long ago, hence why ahk_l is the main developement branch now. yes :: was wrapped in #ifwinactive but still it makes ahk stop, something similar is reported for modules - if you put :: to early in the module code script just stops on that row Ahh, so another ahk bug regards #IfWin hotkeys, why does that not surprise me! It's possible to remap keys using the Hotkey command for slamit with something like: Hotkey, $%StartKey%, sendS Hotkey, $%StartKey% Up, sendSUp ;... sendS: send {Blind} {s DownTemp} Return ;... sendSUp: send {Blind} {s Up} Return Edited October 12, 2011 by samwyze
samwyze Posted October 12, 2011 Author Posted October 12, 2011 I'm looking for some good free command line image rotator??????I need it to rotate screen shots. I've made the code that reads the description of running table from xml, adds one hot key for print screen, on press of that key saves print screen image in hyperpin\media\blabla\table desc. I just need to rotate it (since hp needs 180 degrees rotated images). Found some image converter plus but it is commercial. Found some linux tools also, but ... So any body knows free windows program that will do this? gdi+ with ahk will do this, just need to include gdip.ahk and read some of tics examples also, the CaptureScreen function from wip4 is using gdip to convert image format and could be modified to rotate 180 before saving...give me some time and I'll look at it
samwyze Posted October 12, 2011 Author Posted October 12, 2011 (edited) part post deleted - shouldn't leave web page open while kids on holidays Edited October 12, 2011 by samwyze
samwyze Posted October 12, 2011 Author Posted October 12, 2011 (edited) @Blur If you add these functions to wip4: ;##################################################################################### Gdip_CreateBitmapFromClipboard() { if !DllCall("OpenClipboard", "uint", 0) return -1 if !DllCall("IsClipboardFormatAvailable", "uint", 8) return -2 if !hBitmap := DllCall("GetClipboardData", "uint", 2) return -3 if !pBitmap := Gdip_CreateBitmapFromHBITMAP(hBitmap) return -4 if !DllCall("CloseClipboard") return -5 DeleteObject(hBitmap) return pBitmap } Gdip_CreateBitmapFromHBITMAP(hBitmap, Palette=0) { DllCall("gdiplus\GdipCreateBitmapFromHBITMAP", "uint", hBitmap, "uint", Palette, "uint*", pBitmap) return pBitmap } Gdip_GetImageDimensions(pBitmap, ByRef Width, ByRef Height) { DllCall("gdiplus\GdipGetImageWidth", "uint", pBitmap, "uint*", Width) DllCall("gdiplus\GdipGetImageHeight", "uint", pBitmap, "uint*", Height) } ; RotateNoneFlipNone = 0 ; Rotate90FlipNone = 1 ; Rotate180FlipNone = 2 ; Rotate270FlipNone = 3 ; RotateNoneFlipX = 4 ; Rotate90FlipX = 5 ; Rotate180FlipX = 6 ; Rotate270FlipX = 7 ; RotateNoneFlipY = Rotate180FlipX ; Rotate90FlipY = Rotate270FlipX ; Rotate180FlipY = RotateNoneFlipX ; Rotate270FlipY = Rotate90FlipX ; RotateNoneFlipXY = Rotate180FlipNone ; Rotate90FlipXY = Rotate270FlipNone ; Rotate180FlipXY = RotateNoneFlipNone ; Rotate270FlipXY = Rotate90FlipNone Gdip_ImageRotateFlip(pBitmap, RotateFlipType=1) { return DllCall("gdiplus\GdipImageRotateFlip", "uint", pBitmap, "int", RotateFlipType) } Gdip_SaveBitmapToFile(pBitmap, sOutput, Quality=75) { SplitPath, sOutput,,, Extension if Extension not in BMP,DIB,RLE,JPG,JPEG,JPE,JFIF,GIF,TIF,TIFF,PNG return -1 Extension := "." Extension DllCall("gdiplus\GdipGetImageEncodersSize", "uint*", nCount, "uint*", nSize) VarSetCapacity(ci, nSize) DllCall("gdiplus\GdipGetImageEncoders", "uint", nCount, "uint", nSize, "uint", &ci) if !(nCount && nSize) return -2 Loop, %nCount% { Location := NumGet(ci, 76*(A_Index-1)+44) if !A_IsUnicode { nSize := DllCall("WideCharToMultiByte", "uint", 0, "uint", 0, "uint", Location, "int", -1, "uint", 0, "int", 0, "uint", 0, "uint", 0) VarSetCapacity(sString, nSize) DllCall("WideCharToMultiByte", "uint", 0, "uint", 0, "uint", Location, "int", -1, "str", sString, "int", nSize, "uint", 0, "uint", 0) if !InStr(sString, "*" Extension) continue } else { nSize := DllCall("WideCharToMultiByte", "uint", 0, "uint", 0, "uint", Location, "int", -1, "uint", 0, "int", 0, "uint", 0, "uint", 0) sString := "" Loop, %nSize% sString .= Chr(NumGet(Location+0, 2*(A_Index-1), "char")) if !InStr(sString, "*" Extension) continue } pCodec := &ci+76*(A_Index-1) break } if !pCodec return -3 if (Quality != 75) { Quality := (Quality < 0) ? 0 : (Quality > 100) ? 100 : Quality if Extension in .JPG,.JPEG,.JPE,.JFIF { DllCall("gdiplus\GdipGetEncoderParameterListSize", "uint", pBitmap, "uint", pCodec, "uint*", nSize) VarSetCapacity(EncoderParameters, nSize, 0) DllCall("gdiplus\GdipGetEncoderParameterList", "uint", pBitmap, "uint", pCodec, "uint", nSize, "uint", &EncoderParameters) Loop, % NumGet(EncoderParameters) ;% { if (NumGet(EncoderParameters, (28*(A_Index-1))+20) = 1) && (NumGet(EncoderParameters, (28*(A_Index-1))+24) = 6) { p := (28*(A_Index-1))+&EncoderParameters NumPut(Quality, NumGet(NumPut(4, NumPut(1, p+0)+20))) break } } } } if !A_IsUnicode { nSize := DllCall("MultiByteToWideChar", "uint", 0, "uint", 0, "uint", &sOutput, "int", -1, "uint", 0, "int", 0) VarSetCapacity(wOutput, nSize*2) DllCall("MultiByteToWideChar", "uint", 0, "uint", 0, "uint", &sOutput, "int", -1, "uint", &wOutput, "int", nSize) VarSetCapacity(wOutput, -1) if !VarSetCapacity(wOutput) return -4 E := DllCall("gdiplus\GdipSaveImageToFile", "uint", pBitmap, "uint", &wOutput, "uint", pCodec, "uint", p ? p : 0) } else E := DllCall("gdiplus\GdipSaveImageToFile", "uint", pBitmap, "uint", &sOutput, "uint", pCodec, "uint", p ? p : 0) return E ? -5 : 0 } Gdip_DisposeImage(pBitmap) { return DllCall("gdiplus\GdipDisposeImage", "uint", pBitmap) } Gdip_Startup() { if !DllCall("GetModuleHandle", "str", "gdiplus") DllCall("LoadLibrary", "str", "gdiplus") VarSetCapacity(si, 16, 0), si := Chr(1) DllCall("gdiplus\GdiplusStartup", "uint*", pToken, "uint", &si, "uint", 0) return pToken } Gdip_Shutdown(pToken) { DllCall("gdiplus\GdiplusShutdown", "uint", pToken) if hModule := DllCall("GetModuleHandle", "str", "gdiplus") DllCall("FreeLibrary", "uint", hModule) return 0 } ;##################################################################################### then you should be able to take a screenshot using CaptureScreen, rotate it 180, then save to a file like this: pToken := Gdip_Startup() CaptureScreen(3,,0) ;capture current monitor to clipboard pBitmap := Gdip_CreateBitmapFromClipboard() pBitmap := Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap, A_ScriptDir "\WhereEver\" tableTitle ".png") Gdip_DisposeImage(pBitmap) Gdip_Shutdown(pToken) (with a relevant variable for tableTitle of course) without the need for gdip.ahk theres some notes in the functions, I haven't tested but it's a start If you didn't want to do it with script, I second IrfanView - there are plenty of examples at ahk forums using it via ahk and command line Edited October 12, 2011 by samwyze
samwyze Posted October 12, 2011 Author Posted October 12, 2011 I cannot find the link to download HyperSettings program I see the screen shots it looks great. It's not finished yet It's a work in progress I'll post the settings file today if you'd like - but it doesn't relate to the current FPLaunch in this thread, it's for the upcoming release - however, you could use it to configure HyperPin settings
blur Posted October 12, 2011 Posted October 12, 2011 (edited) http://annystudio.com/software/jpeglosslessrotator/will that work? i think not, screenshots for hp are in png format, and i don't see png support in this program tnx for all hints I'll try this solution in gdi+ from sam, be back in a minute Edited October 12, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted October 12, 2011 Posted October 12, 2011 (edited) hm, hm, hm, looks like I have duplicate functions i have capturescreen utility from sean, and gdip.ahk is included with #include tried to comment whole capturescreen block - but then there is no capturescreen function in gdip ok, uncommented everything from capturescreen block except capturescreen and now there is no duplilcate functions, but... my gdip.ahk doesn't have imagerotate function, only rotate world. what gdip.ahk wrapper do you use? mine is 1.43 by tic. by the way - i have the code to get description with strx function from skan and parts of your code from some other thread so no need for you to investigate it, tnx for gdip quick intro Edited October 12, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
samwyze Posted October 12, 2011 Author Posted October 12, 2011 (edited) hm, hm, hm, looks like I have duplicate functionsi have capturescreen utility from sean, and gdip.ahk is included with #include tried to comment whole capturescreen block - but then there is no capturescreen function in gdip ok, uncommented everything from capturescreen block except capturescreen and now there is no duplilcate functions, but... my gdip.ahk doesn't have imagerotate function, only rotate world. what gdip.ahk wrapper do you use? mine is 1.43 by tic. by the way - i have the code to get description with strx function from skan and parts of your code from some other thread so no need for you to investigate it, tnx for gdip quick intro I'm using 1.45 from tic, If you just add those functions from previous post, you don't need to include gdip.ahk - that could be duplicate functions problem. If you're using gdip.ahk anyway (make sure it's 1.45) then you should be able to use capturescreen, just don't insert the other functions from my post (they're the parts of gdip.ahk that you need) p.s. I don't know when tic added the Gdip_ImageRotateFlip, must have been 1.44 or 1.45, but wish I'd seen it earlier - can probably eliminate 1/4 of my gdip code in current fplaunch if it works! RotateWorld is a pain, cause you need to get all the new dimensions from rotation etc... whereas ImageRotateFlip works on 90 degree turns so the math is done internally - at least that looks like how it's done oh yeah, sean+tic+skan=90% of my code Edited October 12, 2011 by samwyze
samwyze Posted October 12, 2011 Author Posted October 12, 2011 @Blur, if you're playing with ahk, can you test if sending a left alt (or was it right?) to future pinball causes a pause without hiscores showing? I can't get future pinball running on my cab - having hassles with laptops onboard video and opengl and it just wont co-operate - it'll run a table (eventually) but at I'd say 1 or 2 frames per sec - no joke! Could be caused by my whacko dual monitor setup mind you, a second laptop (an old p3 I think) running MaxiVista dualscreen software serving as the backglass Anyway, the point was, I can't test FP stuff and wanted to see if that worked
blur Posted October 12, 2011 Posted October 12, 2011 yup, downloaded 1.45 - it has rotateflip function still have some problems - no image on disk, here is the code: printScreen: ; CaptureScreen(3,false,pfName) ; old function - it works but no rotation pToken := Gdip_Startup() CaptureScreen(3,"",0) ;capture current monitor to clipboard sleep 100 pBitmap := Gdip_CreateBitmapFromClipboard() pBitmap1 := Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap1, pfName) Gdip_DisposeImage(pBitmap) Gdip_DisposeImage(pBitmap1) Gdip_Shutdown(pToken) return pfname is full file name with png in the end will try to test it some more My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted October 12, 2011 Posted October 12, 2011 it looks like image rotate will not return pointer to bitmap but instead it rotates input bitmap and returns return code (not sure just guessing) so i changed code to: pToken := Gdip_Startup() CaptureScreen(3,"",0) ;capture current monitor to clipboard pBitmap := Gdip_CreateBitmapFromClipboard() Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap, pfname) Gdip_DisposeImage(pBitmap) Gdip_Shutdown(pToken) still no image My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted October 12, 2011 Posted October 12, 2011 @Blur, if you're playing with ahk, can you test if sending a left alt (or was it right?) to future pinball causes a pause without hiscores showing?I can't get future pinball running on my cab - having hassles with laptops onboard video and opengl and it just wont co-operate - it'll run a table (eventually) but at I'd say 1 or 2 frames per sec - no joke! Could be caused by my whacko dual monitor setup mind you, a second laptop (an old p3 I think) running MaxiVista dualscreen software serving as the backglass Anyway, the point was, I can't test FP stuff and wanted to see if that worked tested left and right alt in fp - no pause My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted October 12, 2011 Posted October 12, 2011 (edited) i did it there is some problem with capture screen to clipboard, it doesn't work so instead of getting bitmap over clipboard - i switched to getting it from file, and it worked on first run - yeeee - so expect print screen in next release here is the final code (there is also some code where description is pulled from xml - it is not here - if you want it i can post that part also): printScreen: CaptureScreen(3,"",pfName) pToken := Gdip_Startup() pBitmap := Gdip_CreateBitmapFromFile(pfName) Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap, pfName) Gdip_DisposeImage(pBitmap) Gdip_Shutdown(pToken) return Edited October 12, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
samwyze Posted October 12, 2011 Author Posted October 12, 2011 You posted while I was writing this - glad you found a workaround it looks like image rotate will not return pointer to bitmap but instead it rotates input bitmap and returns return code (not sure just guessing) so i changed code to: pToken := Gdip_Startup() CaptureScreen(3,"",0) ;capture current monitor to clipboard pBitmap := Gdip_CreateBitmapFromClipboard() Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap, pfname) Gdip_DisposeImage(pBitmap) Gdip_Shutdown(pToken) still no image OK, I'll have a closer look tomorrow, I've got to get some sleep now! Possibly CreateBitmapFromClipboard is wrong coz I've never used it or ImageRotateFlip. In the mean time you could try along these lines (coz I forgot to drawimage before): pToken := Gdip_Startup() CaptureScreen(3,"",0) ;capture current monitor to clipboard pBitmap := Gdip_CreateBitmapFromClipboard() ;---or instead of those 2 lines------- pBitmap := Gdip_BitmapFromScreen() ;--------------then----------------- pBitmap2 := Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Width := Gdip_GetImageWidth(pBitmap2), Height := Gdip_GetImageHeight(pBitmap2) G := Gdip_GraphicsFromImage(pBitmap2) Gdip_DrawImage(G, pBitmap2, 0, 0, Width, Height, 0, 0, Width, Height) Gdip_SaveBitmapToFile(pBitmap2, pfname) Gdip_DisposeImage(pBitmap), Gdip_DisposeImage(pBitmap2) Gdip_DeleteGraphics(G) Gdip_Shutdown(pToken) tested left and right alt in fp - no pause Ok, damn, must have been a fluke on my desktop
blur Posted October 12, 2011 Posted October 12, 2011 see you tomorrow/tonight (depends how you look) My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
samwyze Posted October 12, 2011 Author Posted October 12, 2011 (edited) Cool, how about: pToken := Gdip_Startup() pBitmap := Gdip_BitmapFromScreen(1) Gdip_ImageRotateFlip(pBitmap, 2) ;rotate 180, flip 0 Gdip_SaveBitmapToFile(pBitmap, pfName) Gdip_DisposeImage(pBitmap) Gdip_Shutdown(pToken) to avoid the extra file write? I think pBitmap := Gdip_BitmapFromScreen() or pBitmap := Gdip_BitmapFromScreen(0) is all screens, pBitmap := Gdip_BitmapFromScreen(1) is monitor 1 pBitmap := Gdip_BitmapFromScreen(2) mon 2 etc... Edited October 12, 2011 by samwyze
blur Posted October 12, 2011 Posted October 12, 2011 we can't rely on monitor 1 being the playfield i have for example monitor 2 for pf, will test this though, tnx My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Create an account
Register a new accountSign in
Sign In Now
