blur Posted February 19, 2011 Posted February 19, 2011 for fp i wanted to avoid hiscores screen so that pause looks the same in vp and fp i was first sending pause and then doing the screenshot, but then fp was so slow so screenshot would be done before fp would show pause hiscores some sleep would maybe fix this and after unpausing fp would sometimes get pause sometimes not, again some sleep or winwaitactive would probably fix this will try it for flickering - it would be great to try that libs but i think major part of blitz's flickering is caused by winhide not working on windows 7 i will have to test it, i have only one win7 pc and kids play cod all the time on it i've found on the net that winmove to some offscreen location helps My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted February 19, 2011 Posted February 19, 2011 I've changed pause like sam said. First i send pause, then printscreen, then blue pause screen. I've added winwaitactive so now fp gets pause key every time, no misses. How it looks like - first you get hi scores, then few ms later blue pause. same when you close pause, first blue screen disappears, then hi score disappears. There is no any lag and you have hiscores and looks the same as in vp. Hi score table is high enough so there is no need to change blue screen position. I still have to change script a bit (closefp and showfp functions) because of this change and then will upload it. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted February 19, 2011 Posted February 19, 2011 That sounds freaking awesome! I like the idea of having the blue pause screen consistent between VP and FP and understood that was your goal but if I had to pick or choose I would have taken the high score screen so I could have fast access to the high scores. Your solution gives both. Perfect. I am looking forward to the next update. Thanks to both of you. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
blur Posted February 19, 2011 Posted February 19, 2011 (edited) Here is new version 1.294 No lag on pause in fp and hi scores visible in fp and same blue pause screen in vp and fp. This version is with images - so it's little bit bigger but you don't need to donwnload 1.28: http://www.megaupload.com/?d=GNGZV6VL For fplaunch manual check second post in this thread: http://www.hyperspin-fe.com/forum/showthread.php?p=100473#post100473 Edited February 25, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted February 20, 2011 Posted February 20, 2011 Dude, awesome. I have my cab ripped apart at the moment. Can't wait to try this out. Thanks! Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
rockyrocket Posted February 20, 2011 Posted February 20, 2011 Hi, thanks for the update works great!. In reference to getting rid of the vp nag screens the gameex front end has an app called vpauto that does just that, its launched with each table and works perfectly. Although have not had any luck getting it to play nice with hyperpin , prolly just got the wrong commandline though. Any way thats just food for thought. Starwars build Tron build Tempest build
blur Posted February 20, 2011 Posted February 20, 2011 tnx for the idea rocky i thought about checking this nag window class with winspy and then sending some ok clicks if that window class appears will see what will be easier to implement I also thought about showing any dialog box that pops up on the screen - this way you could see any error that could appear and respond to it but that's for another release My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
deadsoulz Posted February 21, 2011 Posted February 21, 2011 Everything is working great for me on this latest version, except I still can't get my pause button and Exit to work right together, its either one or the other. My Exit Key is "Esc" and my Puase key is "g" When I do get it almost working and I exit my table I notice FBLaunch is bricking my settings over in the settings.ini to defaults. Any Ideas? Here are the settings I want to use. [FPLaunch] exitScriptKey=Esc exitEmulatorKey=Esc toggleCursorKey=t pauseVPinball=g hideCursor=true hideDesktop=true hideTaskbar=true useExitScreen=true usePauseKey=true useLoadScreen=true fadespeed=25 UseExitAsPause=false #exitEmulatorKey2=1 #exitEmulatorKey3=Enter pauseFPKey=g saveFPTables=true #exitEmulatorKey2=1 #exitEmulatorKey3=Enter #exitEmulatorKey2=1 #exitEmulatorKey3=Enter #exitEmulatorKey2=1 #exitEmulatorKey3=Enter
blur Posted February 21, 2011 Posted February 21, 2011 (edited) You can't have commented options. You must have all options in settings file and change them as you wish if you comment them script will see that you don't have some of the new options and set them to defaults. so uncomment exitemulator2 ad 3 then, you have some errors in settings: - "exit script key" must not be esc - this is usually q & s - this is the key for killing everything when script freezes, it's not good to have it set to esc - it is safe to set "use exit as pause" - to true, short press on exit will be pause, long press exit321, if you set it to false exit will have only long press working - "pause FP key" can't be g - this is the key that has to be configured inside FP configuration to act as pause, since FP has only support for joystick and mouse keys acting as pause it is best to use RButton (right mouse button) - so this has to be rbutton or some other joystick key that you configured in FP you don't have to have this key anywhere on your cab, it is not used physically, it is just sent by the script physical key used for pausing fp is pauseVPinball key (name pauseVPinball is for historical reasons) - when you press this key on your cab, pausefpkey is sent to fp, so fp must be configured to do pause on pausefpkey Edited February 21, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted February 21, 2011 Posted February 21, 2011 Blur, Could you post recommended ini settings, I was having some troubles also probably due to improperly configured ini. Thanks.
blur Posted February 21, 2011 Posted February 21, 2011 (edited) Recomended settings are: [FPLaunch] exitScriptKey=q & s exitEmulatorKey=Esc toggleCursorKey=t pauseVPinball=p hideCursor=true hideDesktop=true hideTaskbar=true useExitScreen=true usePauseKey=true useLoadScreen=true fadespeed=25 UseExitAsPause=true exitEmulatorKey2=1 exitEmulatorKey3=Enter pauseFPKey=RButton saveFPTables=true Dont forget to configure RButton as pause in FP. (I will send screenshot later when i come home). Edited February 21, 2011 by blur picture upload My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted February 21, 2011 Posted February 21, 2011 (edited) blitz for your taskbar visible in 20% tables i found this on autohotkey site: When a window is activated immediately after the activation of some other window, task bar buttons might start flashing on some systems (depending on OS and settings). To prevent this, use #WinActivateForce. Did you ever had this problem with old scripts? If not then probably this part of the script is causing problems: IfWinActive, Visual Pinball Player,, DMD ;Check if visual pinball is Ready { WinActivate, ahk_class TBackglass WinActivate, ahk_class MAME WinActivate, ahk_class VPPlayer Break } This is in CreateLoadScreen: function, while loading screen is moving i'm waiting for vpplayer to load after vpplayer is activated, backglass, mame and vpplayer are activated AGAIN and one right after another to make mame visible over backglass. this could cause problems you can try to put command #winactivateforce instead of every winactivate or put sleep 50 before every winactivate (and then recompile) let me know if this helps Edited February 21, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted February 21, 2011 Posted February 21, 2011 Also, I've found this autoit gameex script that closes automatically every nag window that can pop up (tnx rocky for sending it, tnx gameex team for developing it): SetTitleMatchMode,2 WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Please,,1 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Player,,7 WinMaximize, Player WinWaitActive, Player,,12 WinActivate, Player WinWaitActive, Player,,5 WinWaitNotActive, Player Send,{TAB} Send,{ENTER} WinClose, Visual Pinball Exit newrom: Send,{TAB} Send,{SPACE} Send,{ENTER} WinWaitActive, Notice,,1 Send,{ENTER} WinWaitActive, dsddsds,,1 Send,{ENTER} Return ginfo: Send,{ENTER} Send,{ENTER} Exit it is autoit script but as you see commands are same as autohotkey so it will be very easy to add this to our script, somewhere inside loading screen loop (just before the code from previous post) what do you think is it better to close all these windows or to show them for user to click. not everybody has mouse on cab, or wants to see these nag messages My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted February 21, 2011 Posted February 21, 2011 blitz for your taskbar visible in 20% tables i found this on autohotkey site:When a window is activated immediately after the activation of some other window, task bar buttons might start flashing on some systems (depending on OS and settings). To prevent this, use #WinActivateForce. Did you ever had this problem with old scripts? If not then probably this part of the script is causing problems: IfWinActive, Visual Pinball Player,, DMD ;Check if visual pinball is Ready { WinActivate, ahk_class TBackglass WinActivate, ahk_class MAME WinActivate, ahk_class VPPlayer Break } This is in CreateLoadScreen: function, while loading screen is moving i'm waiting for vpplayer to load after vpplayer is activated, backglass, mame and vpplayer are activated AGAIN and one right after another to make mame visible over backglass. this could cause problems you can try to put command #winactivateforce instead of every winactivate or put sleep 50 before every winactivate (and then recompile) let me know if this helps It seems that it was doing it previous to the new release. I will try the adjustments you recommend and let you know. My cab is disassembles for upgrades currently though. I am hoping to have it up and running in a day or 2. I will test and let you know. Thanks for your help on this. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
Blitz17 Posted February 21, 2011 Posted February 21, 2011 Also, I've found this autoit gameex script that closes automatically every nag window that can pop up (tnx rocky for sending it, tnx gameex team for developing it): SetTitleMatchMode,2 WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Please,,1 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Player,,7 WinMaximize, Player WinWaitActive, Player,,12 WinActivate, Player WinWaitActive, Player,,5 WinWaitNotActive, Player Send,{TAB} Send,{ENTER} WinClose, Visual Pinball Exit newrom: Send,{TAB} Send,{SPACE} Send,{ENTER} WinWaitActive, Notice,,1 Send,{ENTER} WinWaitActive, dsddsds,,1 Send,{ENTER} Return ginfo: Send,{ENTER} Send,{ENTER} Exit it is autoit script but as you see commands are same as autohotkey so it will be very easy to add this to our script, somewhere inside loading screen loop (just before the code from previous post) what do you think is it better to close all these windows or to show them for user to click. not everybody has mouse on cab, or wants to see these nag messages I missed something, what nag screens are we talking about? Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
blur Posted February 21, 2011 Posted February 21, 2011 nag screens are mame terminology - it is when pinmame says on first run: "this rom is under copyright, you can use it only if you own it" or if you get some other error message which is usually invisible so you don't know what happened and hyperpin just freezes with this additions hyperpin will just go through all messages and press enter and get you to the game, there will be no need to run every table outside of hyperpin first My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted February 21, 2011 Posted February 21, 2011 ahh, then I vote to add the code to bypass the nag screens. That is if I get a vote. I am assuming extra code will not slow down my pinball performance? Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
bent98 Posted February 21, 2011 Posted February 21, 2011 Also, I've found this autoit gameex script that closes automatically every nag window that can pop up (tnx rocky for sending it, tnx gameex team for developing it): SetTitleMatchMode,2 WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Please,,2 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Please,,1 ifWinExist, Please,, gosub, newrom ifWinExist, Game Info,, goto, ginfo ifWinExist, Notice,, goto, ginfo WinWaitActive, Player,,7 WinMaximize, Player WinWaitActive, Player,,12 WinActivate, Player WinWaitActive, Player,,5 WinWaitNotActive, Player Send,{TAB} Send,{ENTER} WinClose, Visual Pinball Exit newrom: Send,{TAB} Send,{SPACE} Send,{ENTER} WinWaitActive, Notice,,1 Send,{ENTER} WinWaitActive, dsddsds,,1 Send,{ENTER} Return ginfo: Send,{ENTER} Send,{ENTER} Exit it is autoit script but as you see commands are same as autohotkey so it will be very easy to add this to our script, somewhere inside loading screen loop (just before the code from previous post) what do you think is it better to close all these windows or to show them for user to click. not everybody has mouse on cab, or wants to see these nag messages Its probably good to include an option to turn feature on and off. I for one would want nag screens to close but if I have trying to troubleshoot have them on
reko19 Posted February 22, 2011 Posted February 22, 2011 (edited) Here is my assessment. With the ini settings posted by Blur, everything works as it supposed to. I do see a task bar for a split second when exiting VP tables but not FP tables. This is the only thing that is keeping it from being perfect. Overall great improvement especially with FP since it was losing focus every now and then going back to HP. Spiderman, the only table I was having troubles with, is working fine. Could someone explain to me high score functionality? Is the highest score displayed on DMD while the table exiting? Edited February 22, 2011 by reko19
rockyrocket Posted February 23, 2011 Posted February 23, 2011 I vote to kill all screens, you can always open a table outside hyperpin to troubleshoot any problems. This functionality alongside the dmd mover utility will save a huge amount of time on new installations. I am not sure what if any licence tom spiers released vpauto under (hopes gpl) but if the code is just used as inspiration.... Starwars build Tron build Tempest build
blur Posted February 25, 2011 Posted February 25, 2011 Yup, code is just inspiration. My code is totally different. I have nag screen removal ready for version 1.295 short blinking of taskbar i think i can solve also - there was part of the code where taskbar was made visible just before exiting ahk. I commented that since it makes no sense to make taskbar visible while we are in hyperpin. I think that BBB already commented this from 1.0 to 1.1 to solve the same problem. reko you have win 7 or xp? I'm still waiting to see if some sleep or force activate will solve blitz problem with taskbar active during vp game. there's no rush, i will probably put saving of screenshots and positioning of fp table in the next version also rocky for dmd mover there are few scripts on forum that do that, or you can just delete all vpinmame tables from registry and take one good config (which you position on screen as you like) and copy it to default key in registry then every new table will get settings from default settings (dmd position, rotation and all) My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted February 25, 2011 Posted February 25, 2011 Sorry I am taking so long. I ended up getting behind on my cab hardware update. I am working on it some tonight but it may be the end of the weekend or early next week before I am able to test. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
blur Posted February 25, 2011 Posted February 25, 2011 (edited) No prob, take your time bro I see in your previous posts that you have problem with mercury switches tilting too much in your cab. Did you tried to use "my" (I put it on vpf but many people worked on it) new core.vbs version 3.33? It has tiempo filtro - time in milliseconds during which no new nudge keys are accepted - so if you put this to 500 your mercury switch will send nudge signal but vp will not accept it until half a second passes from previous nudge. Default filter time is 200 i think, you can also try how default works for you. Edited February 28, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted February 25, 2011 Posted February 25, 2011 I am running XP, thanks for your hard work and making it better and better
Create an account
Register a new accountSign in
Sign In Now
