Blitz17 Posted March 11, 2011 Posted March 11, 2011 I don't get that error when running that table. Is there a reason you are running an older version of VPinMAME? Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
bent98 Posted March 11, 2011 Posted March 11, 2011 I want support added in as sometimes new versions of pinmame cause issue and you have to roll back to an earlier version. Have this error code clear will be helpful.
blur Posted March 12, 2011 Posted March 12, 2011 it can be easily added to fplaunch script you can also remove vpversion checks from table script My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
bent98 Posted March 12, 2011 Posted March 12, 2011 Thank Blur. I assume you will include that in the next build of the script?
blur Posted March 12, 2011 Posted March 12, 2011 (edited) Thank Blur. I assume you will include that in the next build of the script? yup, it's already added so to summarize there is no solution for fp backglass on newest nvidia drivers on win7? alt tab helps momentarily but when you return to playfield backglass is not visible again? And this problem happens in hp and outside of hp? and winactivate and winset always on top in fplaunch script doesn't help? Edited March 12, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
bent98 Posted March 12, 2011 Posted March 12, 2011 (edited) Blur Can you post a new link with updated script? Also can you add slam tilt support that big boss posted in other thread? Edited March 13, 2011 by bent98
Blitz17 Posted March 13, 2011 Posted March 13, 2011 yup, it's already addedso to summarize there is no solution for fp backglass on newest nvidia drivers on win7? alt tab helps momentarily but when you return to playfield backglass is not visible again? And this problem happens in hp and outside of hp? and winactivate and winset always on top in fplaunch script doesn't help? Yes, Yes, and Yes Maybe with some luck the next nvidia driver release will fix it. Everyting works with FPLaunch so if we could just get the backglass to show up on FP load. I have tested a lot of combinations of setting changes in FP and my PC display settings trying to get it to work and never found anything showed any change in the behavior. Nvidia driver 260.99 works for FP backglass but breaks FPLaunch. Any newer nvidia driver fails to show the FP Backglass on table load but all FPLaunch features work great. A bug report has been logged with nvidia. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
reko19 Posted March 13, 2011 Posted March 13, 2011 For some reason every now and then I get "pause" in the middle of the game. Anybody else noticed it?
blur Posted March 13, 2011 Posted March 13, 2011 you get fp pause or blue pause screen or both? if it is fp pause maybe you clicked right mouse buton, try using middle mouse button (wheel button) in script and fp instead? if it is blue pause screen - then it can be Esc or P or Pause button, they all invoke same function. do you have these keys somewhere is it possible that they are accidentally pressed? As for big boss changes, i've sent pm to big boss for permission few days ago. there is no answer for now until i get the answer all changes from big boss are on hold, but anybody can merge them for them self in their script. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
bent98 Posted March 13, 2011 Posted March 13, 2011 you get fp pause or blue pause screen or both?As for big boss changes, i've sent pm to big boss for permission few days ago. there is no answer for now until i get the answer all changes from big boss are on hold, but anybody can merge them for them self in their script. http://www.hyperspin-fe.com/forum/showthread.php?p=112714#post112714 as per this thread bigboss is fine with you including it in your script.
reko19 Posted March 13, 2011 Posted March 13, 2011 (edited) The only thing I noticed is blue pause while in VP. Doubt this is caused by accidental button push. It usually happens once at the beginning of the game. After I clear it by pressing esc it does not pop up any more. This is not happening every time either, tough to point out why. Edited March 13, 2011 by reko19
Blitz17 Posted March 13, 2011 Posted March 13, 2011 The only thing I noticed is blue pause while in VP. Doubt this is caused by accidental button push. It usually happens once at the beginning of the game. After I clear it by pressing esc it does not pop up any more. This is not happening every time either, tough to point out why. I experience this too on VP. I get the HyperPin table selection image and the Pause image. When I push Pause the table restores and plays fine. Doesn't happen every time. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
cyberk30 Posted March 13, 2011 Posted March 13, 2011 I'm having an issue with your FPLaunch. Whenever I exit the table from hyperpin the table is still playing in the background. What am I doing wrong.
blur Posted March 13, 2011 Posted March 13, 2011 cyberk did you checked installation guide? reko, blitz do you get this blue pause screen in vp at the moment you start table or in the middle of playing table? bent I saw you asked bigboss about including slamit pinball, what i asked bigboss was to put support for multiple vp exe's and sound levels, any way in time i will probably put both but i will try to fix as much bugs as possible before adding any new functionality, cause with new functionalities it will be more and more code to trace for old bugs i've also noticed something while testing on windows7 with ati 4850 - first pause in fp gives me desktop instead of fp pause screen second pause and all after that are ok i found that printscreen gives desktop image instaed of fp image on first usage i tried to put one print screen at launch of fp - did not help i also tried to put two consecutive print screens and use only image from last one - also did not help, it looks like first shown image is always desktop, and second one is ok did anybody had this problem also? My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted March 13, 2011 Posted March 13, 2011 (edited) was playing new CV yesterday and pause did not pop up for a while, so it is not necessarily happening at the beginning of the game Edited March 14, 2011 by reko19
DedroK_V Posted March 14, 2011 Posted March 14, 2011 Here is the new version 1.295 wip (work in progress).Not the final 1.295 but only temporary one with all the above bug fixes. (gui destroy, exiting flag and commented taskbar) Compiled exe included, no images. Removal of nag screens is also implemented. http://www.megaupload.com/?d=1HY7QXE0 Blur Is this version only a fix for the win7 users at the moment, besides the nag screen removal? Also , the bigboss sound and version implementation will be a nice feature in future versions. Even though 9.12 works fine, I find that it stalls and locks up in HP when loading alot of the time, while 9.08 doesn't.
blur Posted March 14, 2011 Posted March 14, 2011 this is fix for taskbar for all users and fix for ipac users though to really fix ipac you should change polling rate. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
deadsoulz Posted March 15, 2011 Posted March 15, 2011 (edited) this is fix for taskbar for all users and fix for ipac usersthough to really fix ipac you should change polling rate. I saw this over on another forum from The I-PAC Developer. "The polling speed issue is not relevant. The I-PACs are full-speed USB devices and this polling speed restriction only applies to low-speed devices. The poll rate is 2ms." Edited March 15, 2011 by deadsoulz
Blitz17 Posted March 15, 2011 Posted March 15, 2011 cyberk did you checked installation guide?reko, blitz do you get this blue pause screen in vp at the moment you start table or in the middle of playing table? For me it is always at the moment I load the table. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
blur Posted March 15, 2011 Posted March 15, 2011 (edited) So we have two totally different cases? For reko I have no idea why would a pause appear one minute in the game and for blitz also no idea why it would appear on the loading but i will check both expect another wip version without new functionalities soon deadsoul - usb pooling on mame games is usually done to enable you faster response - so polling interval is decreased, this is what developer says is unneeded for ipac what i was talking about is increasing polling interval to 5 or 10 miliseconds or more to enable software to consolidate, cause with autohotkey script you get all kinds of problems when rate is one or two miliseconds. game can be slow, performance problems, locking on long key presses, too many nudges and so on this is only for usb devices, ps2 is another story. though i did not find any good instruction to change this - every page talks about changing polling interval in the end only adds idle capability to usb. does any one have good instructions? Edited March 15, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted March 15, 2011 Posted March 15, 2011 Blur, timing is totally random, was playing CV yesterday for quite some time before Pause popped up. Only happens once in a blue man, very hard to nail it down. I'll keep an eye on it.
Blitz17 Posted March 15, 2011 Posted March 15, 2011 I experience this too on VP. I get the HyperPin table selection image and the Pause image. When I push Pause the table restores and plays fine. Doesn't happen every time. Check that, it is not the Pause image but the Rendering Image that hangs. The table has loaded but does not show up until I do something like press Pause to actually Pause and then un-Pause. But it is very inconsistent. I just replaced my modified 295 with your original 295. So far I have not seen this issue again. Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
blur Posted March 15, 2011 Posted March 15, 2011 blitz that's a good news reko do you have ahk compiler installed? can you create shortcut to fplaunch.ahk and add parameters "Visual Pinball" "CV table name" in it like it is described here: http://www.hyperspin-fe.com/forum/showthread.php?p=111569#post111569 and then when you get blue pause screen you can do alt-F4 and copy key history first, and then script log so i can check what happened? My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Create an account
Register a new accountSign in
Sign In Now
