Hyperspin stops working on Windows 11 Home/Pro (version 24H2) after update
I just upgraded from Windows 10 pro to Windows 11 pro with latest updates with TPM.  Hyperspin seems to be working without any issues.
  • Super Like 3
Gorgeous Jesfknrys thanks for the Info then i wll Update too and give it a Try
[sIGPIC][/sIGPIC]
Hello Guys i have also updated to the newest Version of Windows 11 Pro with all Updates and can confirm that Hyperspin is working without any Problems
[sIGPIC][/sIGPIC]
I'm so happy HS1 has magically come back to life. I would love to know what Microsoft broke - and then fixed - though. 🤔
The update which allows Hyperspin to work on WIndows 11 is "2025-05 Cumulative Update Preview for Windows 11 Version 24H2 for x64-based Systems (KB5058499)"
@Dime333 I have not tried it on Windows 11 Home, but it should be pretty much the same. Give it a try. If it doesn't work ,you can always revert back to your previous built within the 10 days after updating.
All working fine here too on Windows 11 Pro - 24H2 Build 26100.4202 (fully updated) 👍
  • Super Like 3
Great news, no need of a Launchbox clone for now then. 🤭
 Just checked my Hyperspin, It's working now also, I've been in process of switching to launchbox, but a lot of bureaucracy is still there (the shit i was trying to get away from). However, with a bit of tweaking and some willingness to do without a few features on my part, I think I could come out a little better by the time I have everything set up. Here is where I'm at so far with setting up Launchbox (note, Lb crashed on me in the first few minutes, but was fine afterwards) I'm in process of creating Rlauncher style loading screens and as far as the pause menu goes, I think the content deliver is a bit more efficient so most pause menus are actually not even  required.
  • Haha 1
Nobody wants to see Launchbox here on the Hyperspin forums.
If you want something that looks like Hyperspin, but actually works .... use Hyperspin 1.5 🤣
Since the red coats took HS, I've gone full troll now 🙂
Well as Hyperspin 2, is a clone of Launchbox, I dont see any problems.....LOL......
this
@jesfknkrys I haven't installed the cumulative update (KB5058499) yet so it must be something else that makes HyperSpin work. But it's good to know HyperSpin still works with that installed too. It has been a rollercoaster ride for HyperSpin 1.5 over the past few months & it also goes down to what manufactrer of PC you have whether or not HyperSpin 1.5 works or not as you know mine was working well before yours, a few weeks at least. Thanks for all info you shared with the community.
I do reccomend people do clean all there cache files & temp files though if still not working & do a re-start then a shutdown before trying again though. It made my PC with TPM work as at first HyperSpin didn't work with all updates applied until I did that.
I have 2 PC's 1 with TPM & 1 without TPM. It means I installed Windows 11 PRO on 1 PC with supported hardware & 1 PC without supported hardware. They both work with HyperSpin 1.5
Thanks to all !!
  • 3 weeks later...
For anyone now using Windows 11 (242H)
Just a heads up ....
If you have any PC games that are cracked, I suggest you check if they are working as I have gone through mine since updating and found at least 20% of them don't, mainly due to RocketLauncher now being unable to load them or the crack no longer working (all Empress ones now fail) ALL WORKED FINE ON 23H2.
I knew it was too good to be true that everything would work and I am now sifting through 700+ PC games to see what now works and what doesn't.
Windows probably removed the dlls in one of their automated scans.
No they are all still there , they are just useless with 24H2
Instalé windows 11 con todas las actualizaciones y efectivamente HyperSpin ahora está funcionando, veremos cuanto dura así jsjs
On 4/6/2025 at 20:23, shredder said:
 Acabo de revisar mi Hyperspin y ahora también funciona. He estado migrando a Launchbox, pero aún hay mucha burocracia (de la que intentaba escapar). Sin embargo, con algunos ajustes y la disposición a prescindir de algunas funciones, creo que podría mejorar un poco para cuando tenga todo configurado. Aquí es donde estoy hasta ahora con la configuración de Launchbox (nota: Lb se colgó en los primeros minutos, pero luego funcionó bien). Estoy creando pantallas de carga al estilo de Rlauncher y, en cuanto al menú de pausa, creo que la entrega de contenido es un poco más eficiente, así que la mayoría de los menús de pausa ni siquiera son necesarios.
Hace un tiempo intenté migrar de HyperSpin a LaunchBox, pero tuve problemas con la detección de ROMs de MAME. Aunque LaunchBox te permite seleccionar la versión de MAME que estás usando para que supuestamente lea bien los juegos, nunca me reconoció todos los ROMs. Probé varias veces, distintos métodos, y siempre quedaban muchos juegos afuera. Al final me aburrí y decidí quedarme con HyperSpin hasta la eternidad 😆
El problema creo que está en cómo LaunchBox maneja la detección automática. Aunque sabe qué versión de MAME usas, no trabaja directamente con el XML oficial (list.xml), sino que usa su propia base de datos y lógica de coincidencia. Eso hace que, si tus ROMs no están perfectamente nombrados o si tienes sets modificados, muchos juegos no se reconozcan.
En cambio, HyperSpin, aunque más manual y limitado, usa un sistema de XML que es más preciso: si el juego está en el XML, el frontend lo muestra sí o sí, sin depender de adivinanzas o validaciones. Es menos moderno, pero más predecible y 100% confiable si sabes lo que estás cargando.
  • 3 weeks later...
Today 7 / 15 / 2025.
After lasts update of Window 11
My Hyperspin 1.5.3 (never deleted) still works like a charm.
Create an account
Register a new account
Sign in
Sign In Now
