craiganderson Posted November 18, 2014 Author Posted November 18, 2014 glad to hear it is working melu669 In order to be certain that everything is truly working, double check by following the method in the pic below. Because the save state files will load a game and look good to go even if they can't find Roms (ie no text in floppy drives). But if the text is in the floppy drives you are truly good to go. See red arrows in pic. Thanks for trying it out. link to real pic http://craigandersonthemes.weebly.com/sharp-x68000.html http://craigandersonthemes.weebly.com/
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 are u asking if i have one? i do not have one. sorry http://craigandersonthemes.weebly.com/
dougan78 Posted November 20, 2014 Posted November 20, 2014 are u asking if i have one? i do not have one. sorry That collage would be good.
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 i agree. i dont use many fade screens. i actually like seeing the "guts" happening. I like seeing emulators popping open. windows clicking. things loading etc....but thats just me http://craigandersonthemes.weebly.com/
Melu Posted November 20, 2014 Posted November 20, 2014 Ohhh good idea. It can work for Fade Screen. Maybe it's very colorful, but I like the idea. Thank you.
jcm9800 Posted November 20, 2014 Posted November 20, 2014 hello craig i have setup your sharpx 68000 its really cool system thanks for your hard work the only really big problem that i have with it, if you must search for yourself for the xm6 file while the roms window pops up most of the time hyperlaunch dont close correctly anymore. how have you handle this for you? [sIGPIC][/sIGPIC]
alexminasepm Posted November 20, 2014 Posted November 20, 2014 hello craig i have setup your sharpx 68000 its really cool system thanks foryour hard work the only really big problem that i have with it, if you must search for yourself for the xm6 file while the roms window pops up most of the time hyperlaunch dont close correctly anymore. how have you handle this for you? Man... if this is happening (search xm6 file) its because your roms directory is wrong.
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 hello craig i have setup your sharpx 68000 its really cool system thanks foryour hard work the only really big problem that i have with it, if you must search for yourself for the xm6 file while the roms window pops up most of the time hyperlaunch dont close correctly anymore. how have you handle this for you? this does not happen on my system you should not have to do any of this we will fix it for u are you using an ENGLISH version of window? or another language?? also........ when you go looking for a XM6 file what is written in the windows "window"?? for example, mine says "Open" what does yours say? thanks craig (also lots of credit to gamesmame and others .. not just me) http://craigandersonthemes.weebly.com/
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 Man... if this is happening (search xm6 file) its because your roms directory is wrong. yep that is possible too either way, we will get it working for him thanks craig http://craigandersonthemes.weebly.com/
jcm9800 Posted November 20, 2014 Posted November 20, 2014 no i dont think so alexmina for the most games rom loading works normal but for same you must search the xm6 file for yourself too. i think this is for some specif games where multiple disk must be loaded for startup. craig writes something about this on his side [sIGPIC][/sIGPIC]
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 no i dont think so alexmina for the most games rom loading works normal but for same you must search the xm6 file for yourself too. i think this is for some specif games where multiple disk must be loaded for startup. craig writes something about this on his side actually...it does not matter that the other games are loading OK they WILL be able to do that even if the VIRTUAL DRIVE is mapped wrong because HLHQ points to the physical location of the roms....but then the VIRTUAL drive is where the save state files will look make sense? (i know it sounds weird but it is true) are you using a VIRTUAL DRIVE or REAL DRIVE? what is the location of your roms? english or dutch? windows vesion? thanks http://craigandersonthemes.weebly.com/
jcm9800 Posted November 20, 2014 Posted November 20, 2014 i have the german version of windows 7 64 bit craig my window says öffnen [sIGPIC][/sIGPIC]
jcm9800 Posted November 20, 2014 Posted November 20, 2014 my drive location is real on letter S: [sIGPIC][/sIGPIC]
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 i have the german version of windows 7 64 bit craig my window says öffnen ok...i will adjust the module (.ahk file) try this (file deleted, did not work) http://craigandersonthemes.weebly.com/
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 and then..... In order to be certain that everything is truly working, double check by following the method in the pic below. Because the save state files will load a game and look good to go even if they can't find Roms (ie no text in floppy drives). But if the text is in the floppy drives you are truly good to go. See red arrows in pic. Thanks for trying it out. link to real pic http://craigandersonthemes.weebly.com/sharp-x68000.html http://craigandersonthemes.weebly.com/
jcm9800 Posted November 20, 2014 Posted November 20, 2014 with the new module is always the same the windows window pops up and i must take for myself the xm6 file then everything boots up normal and i have the two fields from your picture filled with the disks and its blinking red in this field and everything works normal [sIGPIC][/sIGPIC]
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 ok try this thanks (EDIT: anybody who is using a NON-ENGLISH version of windows try this module) german module two.zip http://craigandersonthemes.weebly.com/
jcm9800 Posted November 20, 2014 Posted November 20, 2014 really big thanks craig this now works perfekt and now i can really enjoy all your work big thanks from me [sIGPIC][/sIGPIC]
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 glad to hear its working! (and lots of credit to gamesmame and others) http://craigandersonthemes.weebly.com/
craiganderson Posted November 20, 2014 Author Posted November 20, 2014 fyi added the module for non-english windows to the download page as well thanks craig http://craigandersonthemes.weebly.com/
jcm9800 Posted November 21, 2014 Posted November 21, 2014 hy craig i try out now to setup your vector c6 system its run so far but when i start a window to save pop ups what can i do to chance this [sIGPIC][/sIGPIC]
wahoobrian Posted November 21, 2014 Posted November 21, 2014 Hi Craig - Just wanted to give you thanks for setting this all up and sharing. I finally got around to setting it up and it works great for me. You've obviously spent a ton of time on this, well done! Suggestion: Include Japanese RosettaStone in your download, so we know what the heck we're playing with some of these!
floatingyeti Posted November 23, 2014 Posted November 23, 2014 Hi Craig - Just wanted to give you thanks for setting this all up and sharing. I finally got around to setting it up and it works great for me. You've obviously spent a ton of time on this, well done!Suggestion: Include Japanese RosettaStone in your download, so we know what the heck we're playing with some of these! I'm about half way done filling in all the database info. Soon we will all be able to filter by shmup,shooter,platform,sports,translated etc. it will be easier to find playable games. up to line 4322 of 9107 in xml.
