maxxsinner Posted May 2, 2012 Posted May 2, 2012 Just because I run out of things to run wires in around my house, I decided to sell my first cabinet and start all over again.Going with the time aged tradition of never going backwards, I am going with custom artwork, a lowered LED TV and some new kinds of bling thanks to Pixel and Co. So beginneth High Voltage Pin HIGH VOLTAGE! Let’s start off with the juicy bits Computer · Corsair 16GB Kit, PC-12800 (1600MHz) DDR3, Vengeance Series, 9-9-9-27 · Corsair Cooling Hydro Series H60 High-performance CPU Cooler · Creative Gigaworks T3 BLACK Speakers · Gigabyte GA-X79-UD3 · Intel Core i7 3930K · Microsoft Windows 7 Ultimate · OCZ 120GB SSD, 2.5", Vertex 3 MAX IOPS Edition · Creative Sound Blaster X-Fi Titanium HD PCIe · Corsair AX-850 850W ATX Power Supply Cabinet · Custom Cabinet from Arcadeworx · Virtuapin Ultimate widebody Cab-Builders kit · Virtuapin Button Package · Virtuapin Widebody lockdown bar · Williams/Bally coin door · Mot-ion Plunger · Extra Buttons from Ozstick · Custom Art from Shadman Displays · Sony KDL46EX720 · Asus 27" Widescreen LED monitor · Vishay DMD with Russ’s board Bling · LED strips · 10 Contactors for feedback · 10 Cree LED’s · Knocker · Shaker Motor · Gear Wiper motor Already recieved a rough diagram of the side art And the end result. Two pinballs worth of parts... and there was still stuff on back order! Screen Test - Poor old laptop didn't like to play VP for long before crashing. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
boogies2 Posted May 2, 2012 Posted May 2, 2012 Wow - Max, this is gonna be over the top - Knocker, 10x Contactor - 10x LEDs - It's sounds like SUPER BLING!!!!! BTW, ArcadeWorx has good price for new cabinet shell - Not so great for us in the states, though. Are you gonna use that High Power Booster boards from Zebulon?
maxxsinner Posted May 2, 2012 Author Posted May 2, 2012 Will be using Pixels boards when they are made available with Arduino boogies2 and Zebs boards as well as I have a few left over. Got a few ideas for how I am going to back light the side art so I am going to need a few outputs Will try and do a bit of a 'how to' mainly on the electrical stuff as I go First step for me was to put the Cree's onto the heatsinks with a bit of arctic silver epoxy. Rubber bands to hold them in place. Then time to solder. The simple trick to solder for those that haven't done it before, is to pre-solder the pads on the Cree, Then pre- solder the wire and then put the wire in place and put some heat into it until the solder flows on both the pad and the wire. Ok.. active wire done. Another 60 wires to go..... Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
chriz99 Posted May 2, 2012 Posted May 2, 2012 WOOHOOOOO, can't wait for more pics cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Dazz Posted May 2, 2012 Posted May 2, 2012 The theme is extremely fitting for ya Max. Can't wait to see what other toys/ideas you come up with.
maxxsinner Posted May 2, 2012 Author Posted May 2, 2012 Cheers gents. Seemed appropriate Dazz.... and I got a few ideas Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
mameman Posted May 2, 2012 Posted May 2, 2012 Looking good, so based on the pc parts in the pic are you building 1 or 2 machines? PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
maxxsinner Posted May 2, 2012 Author Posted May 2, 2012 2 Mameman. Building one with the same cab and similar bling but with a classic Bride of pinbot side art (at this point), similar to Granters from a while ago. I was going to build one for my brother at the same time as electropin but we got side tracked with other things, so now we are making it happen. Will be posting pics of it as we go also. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
Arkay Posted May 2, 2012 Posted May 2, 2012 He was too WIRED! All AMPed up! Couldn't RESIST! IC you've SOURCEd everything but the kitchen SINK... We're LED to believe this will outSTRIP ElectroPin. Get your GEARmotors running. It'll be FLASH. I know and ARDUI Knows Too! It's HIGH VOLTAGE! and here endeth the really poor Sparky humour!! LOL. I'm watching with intent to plagiarise and be amazed. But seriously....Just wondering why you've wired common +ve on the LED's and switching -ve. As arduino switches on +ve. Just habit from the ledwiz days or preference to still switch on -ve with Zebs boards making it possible? My LED's turned up this week which left me scratching my head on which way to wire them up. Common anode, or common cathode. The 350ma Crees I bought have +/- for each colour around the star, not all +ve's grouped like yours. Thanks for explaining to a noob. Cheers, Arkay.
maxxsinner Posted May 2, 2012 Author Posted May 2, 2012 Lol! The medium driver boards from both Pixel and Zebulon are using the ULN2803 Darlington pair driver chips, the same ones that are used on the LEDwiz so they only switch the ground out put as they have an inverter in the chip. A high input creates a low output. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
Arkay Posted May 3, 2012 Posted May 3, 2012 Lol! The medium driver boards from both Pixel and Zebulon are using the ULN2803 Darlington pair driver chips, the same ones that are used on the LEDwiz so they only switch the ground out put as they have an inverter in the chip. A high input creates a low output. Ah ok. Thanks. I've gone the lazy man approach with the high output boards so it doesn't matter what gets plugged where. But I will have to watch the switching polarity so I don't mess it up. Enough semi-relevant discussion. On with the show! Cheers, Arkay.
zebulon Posted May 3, 2012 Posted May 3, 2012 This ought to be a fun build to watch....remember to keep the empties in view as work progresses for those of us keeping score (there's gotta be a pool in this - "how many beers will it take Maxx to build a cab?") I know so much about so little that I could teach you everything there is to know about nothing....
maxxsinner Posted May 3, 2012 Author Posted May 3, 2012 Lmao Zeb. Will do my best to have a beer in every shot for you from now on. Actually if you look at the electropin build, the missus was disgusted how many stubbies were in the photos...... Meh Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
bill55 Posted May 3, 2012 Posted May 3, 2012 Can't wait to see this one come together! Art is looking good even in sketch form. My Pinball Build: Indiana Jones and the Pinball Crusade
zebulon Posted May 3, 2012 Posted May 3, 2012 Lmao Zeb. Will do my best to have a beer in every shot for you from now on.Actually if you look at the electropin build, the missus was disgusted how many stubbies were in the photos...... Meh reminds me of mine with the milk crate full of empties holding the cab up...lol....and it wasn't the beer that disgusted the missus, thought you were aware of that by now. I know so much about so little that I could teach you everything there is to know about nothing....
maxxsinner Posted May 5, 2012 Author Posted May 5, 2012 So after selling a kidney, my soul and my first born son, I managed to track down two of these rare little beauties. There was two left in a warehouse somewhere in Singapore but I am sorry gents, these were the last two. They have two of the red 8x8 matrix type like I had in my first cab but I think they are overpriced. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
maxxsinner Posted May 6, 2012 Author Posted May 6, 2012 Soldered up my resistor board. This time around I am going for a dedicated 3.3 volt rated power supply for my Cree LED's. This means my resistor size can be lower wattage. So as per the LED calculator with a power supply running at 3.7 volts (adjusment dial on the power supply to bump it up) I can run my Crees at 600 mA using a 1.2 Ohm resistor for the Green and Blue and a 2.2 Ohm for the red using the info on the Cree MC-E datasheet - @ 700mA - Red 2.3 V, Green 3.7 and Blue 3.5 (Wont be using the white on these ones) And for those keeping count...... it was a 4 stubbie job Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
zebulon Posted May 6, 2012 Posted May 6, 2012 LOL....looking good. I know so much about so little that I could teach you everything there is to know about nothing....
chriz99 Posted May 6, 2012 Posted May 6, 2012 nice1, love the pin connectors cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Numiah Posted May 6, 2012 Posted May 6, 2012 Funny to see you drink anything that you get your hands on lol Luckily there was no Windex laying around **Each pinball machine is a tiny universe... that we control** My Build Overview My Computer Specifications
maxxsinner Posted May 6, 2012 Author Posted May 6, 2012 Already drank the Windex Numiah.... Just out of the shot to the left Variety is the spice of life. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
zebulon Posted May 6, 2012 Posted May 6, 2012 Probably eats the solder paste too.... I know so much about so little that I could teach you everything there is to know about nothing....
maxxsinner Posted May 16, 2012 Author Posted May 16, 2012 Bit of an update. Cabinet design all sorted with Arcadeworx. Troy is unbelievable on how much work he puts into to getting the cabinet just right. This is just a render from the software he uses so it's close to what the finished product will look like with the obvious minor things corrected. Still haven't worked out why I seem to be the only one that starts with the wiring side of things first... Power supplies - 12, 3.7 & 24 Volt Rats nest 1..... Rats nest 2..... Now I just have to work out what those wires all do?? Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
Arkay Posted May 16, 2012 Posted May 16, 2012 Tangle Well. It would if I tried to make something like that...
