Hyperlaunch 2.x slow....
martijnsx
I just upgraded to Hyperlaunch 2.x. It is a plus that you can add systems one by one.
However i notice a few seconds delay when i start games. With Hyperlaunch 1.05 games started instandly. Now i push the button and a few seconds nothing happens and then the game starts. It is with different systems.
Any suggestions?
I noticed that when windows update installs windows defender many programs take 10 seconds before they start. I did do not install defender anymore. So that could not be the problem.
As more and more features get added into HL, it will naturally slow down the launch slightly if everything is turned on. The longest load times usually are with cd based systems because DT is slow.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I just moved back to the old Hyperlaunch 1.05. I don't want to wait 3 seconds for games to load because it changes the experience. What happens if other people play is that they think they did't press the button and they press again. Sometimes this causes the game to load twice and hyperlaunch gets confused and you will not be able to escape the game anymore. A reset is needed.
I like a foolproof setup, just as if it were a real arcade machine. Sorry to see that the new hyperlaunch is a step back out of the box when it comes to stability.
Is there any way to remove the long waiting times in the script or to disable loading screens? I tried to remove them per system in the hyperlaunch file with no succes.
When I launch a simple emu like bsnes, loading is next to instant. What emu takes long?
Also understand that you have to educate your users on how to use your cab. If you want highly compressed roms so they dont take up as much space, naturally it will take longer to uncompress them. At the same time, mounting an iso in DT is not instant, which will add 1-2 seconds to launch.
Depending on how fast your machine is including HD, how fragmented it is, other running processes all also play into the speed of anything you do.
Any emu on my machine that is rom-based, like all cartridge based consoles all load instantly. If this is not the case for you, then you have a problem with your setup. You should look over your settings to see if anything stands out that might add to the delay.
The multiple launches has been brought up many times, and has been addressed. I added code long ago that prevents this from happening in all scenarios except a user mashing the buttons like a jack rabbit on first launch. But if you have users using your machine this way, then maybe you shouldn't let them.
Sent from my Samsung Galaxy S3
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I notice it with starting NES, SNES, N64 and GAMEBOY games. Not tried it with others. When i replace the Hyperlauch.exe with the old one everything goes fast. So i think it has nothing to do with factors as defragmentation and background processes. It is i think due to the difference between the old and new hyperlaunch.
Any way to debug or determine what hyperlaunch is doing during the 2-3 seconds? Can i disable options in the basic huperlaunch file?
You really should take a chance on the loading screens martinjnsx. It helps with the button mashing when launching games and just looks really cool. There are systems theme loading screens made for everything. You can change the background color on them as well. I personally made custom loading screens for over a hundred systems on my htpc.
I moved back to Hyperspin 2.25 to give it a try :)
djvj, could you give some advice on how to get NullDC for the naomi to work with hyperspin? I really need that one for Virtua Tennis 2.
  • 2 years later...
I'm using the newest beta, and I'm seeing about a 4 second delay to starting the game in Hyperspin. I'm using retroarch to run all my games. Could it be the culprit?
I had similar trouble recently with mame which was taking around 30 seconds to load. rfancella reminded me to turn the logging level back to false and that fixed it, I'm not sure if that works for other systems.
I usually tell people who have problems to post there log set to troubleshooting, but i need to also tell them to switch off again.
Thank you Austin, that solved my problem.
For those who are using retroarch and the games are delaying to start, I recommend following Austin's suggestion, it solved my problem instantly.
Aorin
