HyperSpin Event Dispatch System (EDS)
Antos
  • Replies 686
ok i corrected the hypersearch settings, its not completly blank, thanks. what do you want me to post now from hyper marquee??
from what i can tell from what you paste of hypermarquee setting, there are spaces in your wildcards functions some before it and some after it, remove them and it should function as should. for example [filename].zip
also look into case sensitive letter also helps, it shouldnt matter for eds or HyperMarquee but i dont know what matter of bugs that windows 10 introduce. ipcid and parameters entry has Multisystem; try with a lowercase, multisystem, because that how it label in your hypermarquee setting.
i haverenamed the multisystem now to lowercase and i found a mistake on this line
<Artwork3AlternativeLocation>G:\Hyperspin\Auto Start Programme\HyperMarquee\systemImages\.[system]png</Artwork3AlternativeLocation>
should be
<Artwork3AlternativeLocation>G:\Hyperspin\Auto Start Programme\HyperMarquee\systemImages\[system].png</Artwork3AlternativeLocation>
i guess.
but i don't understand what you mean with space in wildcards functions. i can't see any spaces to remove?
should be
i guess.
its fines thats it not there in the original, its probably forums that shows that way
!! - I found something within your HM config;
<NamedPipeID>DefaultSettings</NamedPipeID>
Your Named Pipe Id has to be the same than your file name, unless you decide to manage it differently with EDS. This is is for your hand shake between EDS and HyperMarquee. when using Pipes...​
HyperMarquee & Event Dispatch System
<NamedPipeID>DefaultSettings</NamedPipeID>​
Your Named Pipe Id has to be the same than your file name, unless you decide to manage it differently with EDS. This is is for your hand shake between EDS and HyperMarquee.​
i got it during our teamviewer session, nice caught antos buddy
I have a tricky question...
As it is now, i can see my Commodore Amiga marquee in the main menu and in the system submenu, but when i launch a game it goes black,
is it possible to display the Commodore Amiga marquee when the Amiga games are running? As those games don't have their own marquees. It looks so empty and boring now.
Yes, of course. You can display the game wheel image and the Commodore Amiga marquee at the same time. Please have a quick read at the EDS and HM documentation. It explains how work LedBlinky events when launching a game. Sevenseal might also graciously help if he has some spare time...
No, I didn't mean the wheel image.
I meant the actual marquee. As it is now i have a "Commodore Amiga" logo displayed on my marquee screen when i am in the frontend but when I launch a game it goes black as it tries to find the game's marquee but there is none, i want the "Commodore Amiga" marquee to stay.
"is it possible to display the Commodore Amiga marquee when the Amiga games are running?" - Yes.
Good! :) Does anyone kniw what settings to use?
i provided you with the setting already, copy the events overs as the original, 1,3,9 and closing as 2,4,6,11
it is actually a emulator issue that causing your problem, it hogging the gpu and only able use one display; it not hypermarquee nor eds issue
I tried some other systems now, and yupp, indeed it seems to be UAE. How sad. :/
There is no option in UAE that fixes it?
BTW, did you get a chanse to see why Hyper Marquee crashes when browsing the results list in HyperSearch yet?
I am available to help you debug if needed.
its mainly hypersearch, its hasnt been update to meet the changes of hs and also its doesnt provide hs with the right info so when it does, it crash hypermarquee
hypersearch needs to be ledblinky compatible with the way it function, currently, this bug is seen when you running the two programs together
theres a way, its just the setting you have setup, sometime it best to start a clean install in another folder to find the right setting...
requires some playing around, to find the sweet spot
sevenseal, just my luck. i am running ledblinky, hypersearch and hypermarquee together.. so.. hmm.. hypersearch doesn't seem to be in development anymore?
i guess a workaround isn't possible?
