HyperSpin Event Dispatch System (EDS)
Antos
  • Replies 686
okay, thanks seven seal.......that makes sense, after a while it was closing which i noticed later on....i left it to see if it would close itself, so i'll change that setting from 1000 - 500 :)....just checked and it was set to 2000 so i changed it to 1000, much better all fixed :)
I'm lovin my arcade
EDS NEWS UPDATE - 2016/05/21 - EDS (Beta Release version 0.7.6) is now ready for download. ** Need advanced testers / testing **
What's New;
- This is to improve (hopefully fix completely) when EDS duplicates undesirable instances and do not close them properly). I have made some stress test at home, and it is working fine here. Can kind people test this and let me know? Many thanks!!
​- Also some performance improvements.
Version 0.7.6 Upgrade:
  • Please do a backup of your EDS files.
  • Upgrade process:
2.1- Copy and overwrite with theses files in your EDS folder.
2.2- Delete LedBlinky.exe if exists
2.3- Rename "EDS_LaunchModule (Rename me!).exe" to "LedBlinky.exe"
2.4- Important: Delete all EDS shortcuts. (this is to avoid reinstalling EDS version 0.7.5)
2.5- Create new shortcuts of "HyperSpinEventIntegrator.exe" if you like.
3. Config Process:
- Pipe does not launch [application].exe anymore, only CLI and Pipe (CLI) mode does. To continue using pipes within HyperMarquee simply check "Launch Application on Front-End start" checkbox within EDS GUI configuration module.
Please let me know, thanks!!
Antos
HyperMarquee & Event Dispatch System
it is on eds, click global setting button which is the big button on the right side and it in the middle of them
Hi Bro
I have changed to 500 already but ledblinky remain open after exiting HS.
Hi Bro
Did you update EDS to .7.6?
Freindly reminder for EDS open/close apps;
- Do not forget to put 1 (Front-end start) in the event filter column
- Do not forget to put 2 (Front-end close) in the close filter column
Cheers,
Cheers,
Hi I have updated to latest EDS but Ledblinky still remain open. Do I need set event filter for this?
Yes, but I do not have Ledblinky myself, so I am not sure. Sevenseal could tell better then me.
Can you make some test for me and tell me about your findings?
For closing;
1- Put 2 in the event filter to tell Ledblinky that the F.E is closing.
2- If the first option has no success, put 2 in the close filter to force a close
Thank you,
For closing;
Thank you,
Hi Bro
I tried event filter and ledblinky wont start until exit HS.
Close filter could not exit too.
Maybe I will wait sevenseal bro to come online whenever he have time. thank you so much
Hi Bro
all open filter and close should be blank and should be place on CLI method, cbr should be checked and blank system filter... in parameter it should be [LEDBLINKY]
just be aware... if you exit too fast out of hyperspin... it does not send out the command to exit out 3rd party programs as such as ledblinky or eds
I did same setting and exit very slowly but still remain open. Now it opens more than 2 ledblinky
well it not multiple instance open.... if you hover over... its actually just one... they disappear as you hoverover unless it the one running
Yes you are right haha,
I've bought full version ledblinky last night and waiting email from developer.
Will see what difference with full version and if can solve the closing problem and others or not.
After this problem I will have to start working on the pending issue with ledblinky and rocketblinky.
WIthout you guys developing such a master piece software,  today we will not have what we was  dreaming during our childhoods.
Hope one day we do not need to pay in game centers and have this damm thing in our home.
WIthout you guys we cannot have our dream come true and never imagined that we will owe arcade machine in our house with all those expensive systems in one machine.
if you are interested, i might be able to help with a lot more if yyou like, just reach me like before?
EDS NEWS UPDATE - 2016/05/23 - EDS (Beta Release version 0.7.7) is now ready for download. ** Need advanced testers / testing **
What New;
Version 0.7.7 Setup:
  • Upgrade process:
3. Config Process:
- Pipe does not launch [application].exe anymore, only CLI and Pipe (CLI) mode does. To continue using pipes within Hyper Marquee (recommended option) simply check "Launch Application on Front-End start" checkbox within EDS GUI configuration module, put '1' in the Open filter and '2' in the Close filter.
Cheers,
Sure bro, maybe weekend will catch you.
Very kind of you.
Tapatalk を使用して私の A0001 から送信
What New;
  • Upgrade process:
3. Config Process:
Cheers,
Surely will try this out tonight if can solve my problem. Thank you so much.
Hi Sevenseal
EDS is sending wrong parameters to Ledblinky. Have tried above way and also tried as per photo
Below is the message from arzoo
Hi,
I believe we've been corresponding via email and there's something wrong with the way you have HS configured - it's passing "ledblinky" as the ROM/Game parameter rather than actually game selected. I would suggest posting a question on the HS forum and make sure to mention that HS is passing the wrong parameters to LEDBlinky.
I have attached debug.log of ledblinky https://dl.dropboxusercontent.com/u/13336875/Debug.log
Ledblinky can launch perfectly from RL and HQ directly by the help of newoski brother.
As soon as I change to launch thru EDS have this problem.
What is the problem can you help me thanks
Hi Sevenseal
Hi,
for one thing.... the parameter for ledblinky should only be
[LEDBLINKY]
nothing else
it has been discuss before how configure ledblinky with eds
if seen post #461 i had mention it
also in additions, dont use cbr with ledblinky.... my mistake
just to mention, if you have eds setup for ledblinky you shouldnt setup ledblinky for rocketlauncher... that is a double command that doesnt need to be done... it causes more trouble then good.
so pick one or the other and not both at the same time
Just checking, shitoken... when you tried it the 'other way' as in 'not the photo', you did use the brackets ([ and]) around ledblinky, right?
I would expect your photo to not work at all, since your ledblinky there has no brackets, and since you're mixing ledblinky AND individual parameters, I would expect your photo example to send a command line like this:
C:\LEDBlinky\LedBlinky.exe LEDBLINKY "joust" "Atari 2600"
That sounds like that would not work.  I would think you either use [ledblinky] (with brackets) OR just use the event (which is not in your photo), game, and system parameters.  Both combined seems strange.
From my experience, with [ledblinky] you should not need any filters.  If using [event] "[game]" "[system]", you'd need open and close filters defined.
majority of what you stated is correct
[LEDBLINKY]
nothing else
Yes dear I followed as per before advise and with tick in CBR but it was causing above errors that's the reason we tried RL independently and tried adding game in parameter but was out of luck. Will try again tonight without tick and just change to LEDBLINKY.
Do I need include the the brackets?
Thank you for help
Thank you for help
yes with brackets
should look like this
[ledblinky]
Hi Sevenseal
I have set already and now it launches the lit fine, but still small problem.
1) Some time will speak the games name and sometime not.
2) Whenever HS in main themes 2 buttons will lit up in P1 & P2. Looks strange to me. (1st Photo)
3)Sometime 8 buttons in P1 and 4 Buttons in P2 (2nd Photo)
I have attached photo for your easy understanding.
