danwelsh Posted July 26, 2016 Posted July 26, 2016 with the current release of eds/hm; morely hm, text db related material on hm it minorly glitchy... i do have to say this issue has been fixed on HM/eds at the moment but still in testing. details show that it is working better on the current unrelease revisions that antos and I are testing, meaning not release to public. in your position i would go with pipe, remove all close filter but 2, open event filter has at least 1 or in additionally any other number event that you want want content to update onand then make sure you have checkbox launch on frontend start at the bottom of eds (this checkbox was originally intented for pipe only apps). this work best for text related hm instance for current release of HM. Okay.....pipe does work but I still have to push escape when exiting a game 2 times....the first time goes back to the game selection screen, then I have to push escape again to close the marquee....I have my close filter set to 2 and the open filters to 1,3,9 and the checkbox checked in the bottom left corner I'm lovin my arcade
sevenseal Posted July 26, 2016 Posted July 26, 2016 Okay.....pipe does work but I still have to push escape when exiting a game 2 times....the first time goes back to the game selection screen, then I have to push escape again to close the marquee....I have my close filter set to 2 and the open filters to 1,3,9 and the checkbox checked in the bottom left cornereverything depends on your HS ability to send events, sometine just wait... delay is normal due to how heavy Hs/rl handle things on return from a game
danwelsh Posted July 27, 2016 Posted July 27, 2016 everything depends on your HS ability to send events, sometine just wait... delay is normal due to how heavy Hs/rl handle things on return from a game I don't mind waiting a few seconds but I let it sit there for 15 seconds and there was no change I'm lovin my arcade
sevenseal Posted July 27, 2016 Posted July 27, 2016 I don't mind waiting a few seconds but I let it sit there for 15 seconds and there was no changestrange... i would need to see your setup in order to understand whats going on
danwelsh Posted July 27, 2016 Posted July 27, 2016 strange... i would need to see your setup in order to understand whats going on strange... i would need to see your setup in order to understand whats going on How about a TV session Thursday evening if you are available I'm lovin my arcade
shitoken Posted July 31, 2016 Posted July 31, 2016 What could be the problem with Hyper marquee whenever I launch Taito Type X games , half the marquee position will be moved to one side . after exiting it goes back to normal.
sevenseal Posted July 31, 2016 Posted July 31, 2016 What could be the problem with Hyper marquee whenever I launch Taito Type X games , half the marquee position will be moved to one side . after exiting it goes back to normal.read the last couple of post shitoken please, the amswer is thereit involves fullscreen and windows mode...
danwelsh Posted July 31, 2016 Posted July 31, 2016 I tried everything I can think of sevenseal and your recommendations and the marquee will not close without pushing the escape key when I exit a game...... I'm lovin my arcade
sevenseal Posted July 31, 2016 Posted July 31, 2016 I tried everything I can think of sevenseal and your recommendations and the marquee will not close without pushing the escape key when I exit a game...... well if you want to do a teamviewer session right now, i am here
danwelsh Posted July 31, 2016 Posted July 31, 2016 well if you want to do a teamviewer session right now, i am here I'm at work for another 6 hours.....will you be available then by any chance? I'm lovin my arcade
danwelsh Posted August 1, 2016 Posted August 1, 2016 Figured out the problem Sevenseal.....ttx was not doing that so it was something to do with mameuifx, i remembered reading about another marquee program for mala that had a problem when using hlsl shaders it would crash the marquee program.....i changed from d3d to opengl in mameuifx and opengl in RL and the problem went away.....finally I'm lovin my arcade
danwelsh Posted August 4, 2016 Posted August 4, 2016 Sevenseal I have a question for you.....where my setup was not closing after exiting a game with my original hlsl settings could I just use mame's built in marquee display for when running the game and use hm/eds for main menu and sub menu application? I really liked my hlsl settings and the Roms just don't look as good to me now using glsl......do you think that would work? I'm lovin my arcade
danwelsh Posted August 4, 2016 Posted August 4, 2016 never hurts to try, you can setup it that way Okay will try after sleep in the morning but of course I'd have to change my filters I'm lovin my arcade
sevenseal Posted August 4, 2016 Posted August 4, 2016 Okay will try after sleep in the morning but of course I'd have to change my filterssystem filter yes
shitoken Posted August 18, 2016 Posted August 18, 2016 Sevenseal Bro, I am having strange problem today , I did not change any settings in EDS. Ledblinky lit up normally at startup & the games lits when go into the subwheel of MAME games. But if I go into other system/game wheels , my lits goes off in subwheel until I start up one game and exit back to same games wheel than the lits will up when scrolling thru the games. And if choose another system again the lit goes off until I shoot up one game and exit back than lits up normally for all games . Dont know what went wrong
sevenseal Posted August 18, 2016 Posted August 18, 2016 Sevenseal Bro, I am having strange problem today , I did not change any settings in EDS. Ledblinky lit up normally at startup & the games lits when go into the subwheel of MAME games. But if I go into other system/game wheels , my lits goes off in subwheel until I start up one game and exit back to same games wheel than the lits will up when scrolling thru the games. And if choose another system again the lit goes off until I shoot up one game and exit back than lits up normally for all games . Dont know what went wrong pretty sure it not eds issue, if you add your setting here....please remind you DO NOT just paste your config... please upload the files i will check your setting to see if you your ipc method to cli, have the wild card [LEDBLINKY] in your parameters and everything else should be blank.. i do not know because i dont have your setting or logs for it. most forget that when you setup ledblinky and eds plus you use rocketlauncher... you have to pick eds or RL to use LEDBlinky. one or the other or there will be a mess
shitoken Posted August 19, 2016 Posted August 19, 2016 HI Sevenseal I have tired both settings in RL off & all the ledblinky, since I am using EDS to startup up and exit. Will upload config my dropbox tonight.
shitoken Posted August 19, 2016 Posted August 19, 2016 Hi Sevenseal Here are the links EDS Config https://dl.dropboxusercontent.com/u/13336875/EDS_Settings.config Ledblinky Debug https://dl.dropboxusercontent.com/u/13336875/Debug.zip thank you bro
sevenseal Posted August 19, 2016 Posted August 19, 2016 Hi Sevenseal Here are the links EDS Config https://dl.dropboxusercontent.com/u/13336875/EDS_Settings.config Ledblinky Debug https://dl.dropboxusercontent.com/u/13336875/Debug.zip thank you bro i would suggest use absolute path, it in the gobal setting of eds, also change the 2000 to 1000 if not done so already
shitoken Posted August 20, 2016 Posted August 20, 2016 Hi Sevenseal I just changed this path yesterday after setting up hyperspeech <Path>H:\HyperSpin\HyperSpeech\Ledblinky.exe< The problem was already exist before I changed the path. 2000 to 1000 was changed last month as per your previous instruction. Tapatalk を使用して私の A0001 から送信
sevenseal Posted August 20, 2016 Posted August 20, 2016 Hi Sevenseal I just changed this path yesterday after setting up hyperspeech <Path>H:\HyperSpin\HyperSpeech\Ledblinky.exe< The problem was already exist before I changed the path. 2000 to 1000 was changed last month as per your previous instruction. Tapatalk を使用して私の A0001 から送信 well leave it on absolute, and change the number to 1250
shitoken Posted August 20, 2016 Posted August 20, 2016 Changed the settings still the same problem. Tapatalk を使用して私の A0001 から送信
sevenseal Posted August 20, 2016 Posted August 20, 2016 Changed the settings still the same problem. Tapatalk を使用して私の A0001 から送信 just guessing at the moment, all your setting seem good, only way i can tell what it is unless i see it?
