HyperMarquee
Antos
@zorg2000k
look like your info bar is setup wrong... you would have to go through and see if you data game info and database is good
lol its trying to scroll the info but the text for the info is corrupted lol disable scrolling on text, or disable that in eds of text info one you set in it
  • Replies 1.3k
wow, do you have HyperMarquee window overlapping both screen and did you disable those opitions in the general setting tab?
if it still an issue, want to do a teamviewer session to troubleshoot this?
very strange indeed, me personal... I would look into your hyperspin setting hyperhq, change priority and themes setting. probably your first time having another programs that uses the screen at the same time.
well there others opitions I can help you with if you want to give it a try, I cant figure it out unless I see all your settings up front... it could be anything at this point
Well found the issue, You should be able to test yourself, HyperHQ.exe if you enable the Spinner in controls area, it causes this problem. I can replicate issue evertime I enable the spinner.
Ok, tried all that pointed to HiToText.exe box flashes up for the application, nothing in the hypermarquee window. Any video tutorials for this one ?
How do you get the digital txt to read through the supplied mame.ini to display the game description ?
E:\Hyperspin\HyperLaunch\HyperMarquee\Data\Game Info\mame.ini is the setting but all I get in the hyper marquee window is the "E:\Hyperspin\HyperLaunch\HyperMarquee\Data\Game Info\mame.ini" as scrolling txt
Also can you slow the speed of the txt in Horizontal mode ?
alright thats alot of questions in one moment, let me pm you after I get off work tonight and I will explain it to you then and I will walk you through it in the forum's pm system unless you want to do teamviewer session or any vnc/rdp session
