HyperMarquee
Antos
Hi Antos,
Thanks for the beta version v.0.4.0 Revision H, Ive updated this morning and set the DMD shad settings as per you guide earlier. I can see in the general TXT preview box that this has been applied but when I exit out to commit and launch via EDS it is not applying the filter. I spoke with sevenseal and he has also seen the issue on the Revision H as well , so I'm wondering if this is a bug ?
Cheers
  • Replies 1.3k
Hi Antos,
Cheers
HyperMarquee cannot use transition shader and artwork shader at the same time (mutually exclusive). I assume that you have transition shader enable. Desable it. I will see if I can implement few shader layers if there is a demand for that. Let me know if it works now! :-)
HyperMarquee & Event Dispatch System
Well that sorted it, just need to sort out how to read one file to show game info rather than on txt file per game. Also how do you setup eds / hyper marquee to show system marquees on the main hyperspin wheel i.e mame, snes, nes etc
hi zorg
I was like to ask you to follow the post #298 on this thread and go there
sevenseal
SevenSeal was wondering if you could help me
i think i have eds working as it passes pipes server test but it wont launch any artwork
heres a attachment of settings in eds and hm
thanks
chris
[ATTACH=CONFIG]50065[/ATTACH]
I have sent you an email and pm to you as well
One clarification for HyperList files used in the HM 'Game info' config section. Recently I have noticed that different file format exists on the Hyperspin FTP site and some users have reported HM crash.
Please note that HyperMarquee is compatible with official HyperList files only.
Please used *.xml files from the Hyperspin FTP within this folder: /Gold Member Downloads/~~HyperList TEMP/XMLs Official
Enjoy!
Antos
hi zorg
sevenseal
Hi, Nope still having issues getting Hyper Marquee to work within Hyperspin main wheel and read from one file to pull through game info. Any video guides on this one ?
if you setup hsfilewatcher, along with your eds setup, you will be able to display your main menu as you hover over them, the instruction provide is well explained, please take your time to follow the steps.
your current problem is not a hypermarquee issue.
the issue at hand is directly related to how eds and hsfilewatcher are properly setup.
only until then will hypermarquee function with the main menu of hyperspin.
I have to express that hsfilewatcher is a program to help assist hyperspin the communicate with 3rd party addon; hyperspin does not have this feature in it current version.
I have to encourage you go to the eds thread like how I have pointed you previously, I must maintain the focus of hypermarquee directly related topics to this thread and keep things seperate from one another.
please follow through over on eds thread.
sevenseal
If anyone is interested I have started to make some custom Marquee's for systems, first one will be Nintendo 64, Can be found in my ftp folder :/Upload Here/zorg2000k/Hyper Marquee
This is an example :
zorg that looks great pity i dont have a marque display otherwise i would tottaly use this one
on second thought i could hook up some screen to use it ill think of something after all i do have another i5 laptop being used for gaming soon
sig.png 100%
[ATTACH=CONFIG]50142[/ATTACH]
This is an excellent initiative and looks great. One thing that will be interesting is rather to create an image, would be having access to the images separately and pull them has a theme. I haven't created theme support per say with HM (only HS theme compatibility) but that is something in the radar in order to create powerful display like HS. Until then this in an option among others;
Options, no particular order;
- Option A: Flat image marquee. Pros: very straightforward to manipulate, Cons: Static (no animation, 1 ratio format)
- Option B: Separate the images and let HyperMarquee pick the images separately and display them. Pros: flexible, Cons: no animation for now, but can support animation in future HM versions.
- Option C: Continue using HyperSpin Theme format for now within HM and see if BBB will come with a revised Theme editor that support 16/9 ratio or more.
- Option D: Tweak HS Theme format to support 16/9 ratio (and others) for HyperMarquee. Quite simple to do, need to agree on a new standard.
- Option E: Create a complete Theme Editor for HM.
Here is a sample HS theme, displayed in HyperMarquee (already some compatibility) that can be tweaked to be displayed in 16/9 ratio (or ohers)
AS of now HM support HS themes with video. But no animation yet.
Any thoughts / input?
I was going through what sounds like similar issues with my main menu. After Sevenseal and I banged heads for a little bit he noticed that the folder was set to "read-only" on the folder properties (Right click on your hyperspin folder -> properties -> and make sure to uncheck read-only). As soon as we did that everything was happy and working as it should. I was going crazy for a few days until we figured that out.
Following the guides that sevenseal posted on for setting up EDS with HSFilewatcher worked like a charm!
Thank you guys, this is an absolutely amazing product to add on to Hyperspin!!!
Hello All,
So, I'm finally jumping into the HyperMarquee arena, but having issues. I've got the marquee itself working just fine. What I'd like is to now display some text and I'm having a heck of a time figuring that out.
I want it to look similar to THIS:
Any pointers would be greatly appreciated.
Craig
Hello All,
Craig
what is your issue exactly?
I'm trying to get any type of text to show on screen. I guess I have a question or two about it. One, can the configuration of the text live in the same configuration as the marquee or do I have to build a separate configuration for the text ONLY? Also, I did "kindof" had it working, the field was there for the text...but no text.
Basically, I'm a noob at HyperMarquee...I'll admit that. Just looking for some guidance on setting up some simple text to display along with the marquee. Once I can get the initial text going, I can probably figure out the rest from there.
would you like to do a walk through tutorial of how this is done by doing a teamviewer or any rdp/vnc session?
I'd love to, but can't from where I am right now (the boss wouldn't care for that too much!). Would you maybe be able to jot something quick a dirty down in a reply...that way I can give it a shot once I get back home.
theres is a lot of details to cover, most of it just easier to show due to all the variable that can come into play.
....list of twist....
-files/folder structure
-database/game info updated and being used
-eds + hsfilewatcher + hypermarquee config correctly
-all material present in appropriate formats
-in user secured operating location or not
-what OS
-much more....
theres are so much thats come into play because everyone computer is personally setup and unique to its specs
but to answer your questions
1. yes you have to setup HyperMarquee seperately with each type... but you are able to uses the same setting on each though.
2. the blank text could be related to not compatibility database or game info
sevenseal
-what OS
-much more....
sevenseal
I see your point. Well, what I will do is later today I will run through setting it up again and this time I'll take notes along the way. So if I run into trouble again, I'll have something better to reference.
just let me know if you would like me to be present to guide you through it? I will gladly help in any way that I can
sevenseal
Hi sevenseal, changed those setting in EDS now hers my marquee config file
<?xml version="1.0" encoding="utf-8"?>
<configuration>
   <configSections>
       <sectionGroup name="userSettings" type="System.Configuration.UserSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
           <section name="Hyper_Marquee.Properties.Settings" type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowExeDefinition="MachineToLocalUser" requirePermission="false"/>
       </sectionGroup>
   </configSections>
   <startup>
       <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5.1"/>
   </startup>
   <userSettings>
       <Hyper_Marquee.Properties.Settings>
           <setting name="WindowTop" serializeAs="String">
               <value>100</value>
           </setting>
           <setting name="WindowLeft" serializeAs="String">
               <value>100</value>
           </setting>
           <setting name="WindowHeight" serializeAs="String">
               <value>300</value>
           </setting>
           <setting name="WindowWidth" serializeAs="String">
               <value>600</value>
           </setting>
           <setting name="WindowState" serializeAs="String">
               <value>Normal</value>
           </setting>
           <setting name="DefaultSystemImages" serializeAs="String">
               <value />
           </setting>
           <setting name="SystemConfigFile" serializeAs="String">
               <value />
           </setting>
           <setting name="MarqueeTransparency" serializeAs="String">
               <value>5</value>
           </setting>
           <setting name="MarqueeStyle" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="TextFontColor" serializeAs="String">
               <value>#FFF0F8FF</value>
           </setting>
           <setting name="BackgroungColor" serializeAs="String">
               <value>#AA000000</value>
           </setting>
           <setting name="TextFontSize" serializeAs="String">
               <value>20</value>
           </setting>
           <setting name="ThemeFolder" serializeAs="String">
               <value />
           </setting>
           <setting name="DefaultTheme" serializeAs="String">
               <value />
           </setting>
           <setting name="TextAlignment" serializeAs="String">
               <value>Left</value>
           </setting>
           <setting name="HiToText" serializeAs="String">
               <value />
           </setting>
           <setting name="BorderThickness" serializeAs="String">
               <value>5,5,5,5</value>
           </setting>
           <setting name="BorderColor" serializeAs="String">
               <value>#AAFFFFFF</value>
           </setting>
           <setting name="AutoClose" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="DisplayUnderFont" serializeAs="String">
               <value>False</value>
           </setting>
           <setting name="TextOrientation" serializeAs="String">
               <value>Vertical</value>
           </setting>
           <setting name="DisplayHeader" serializeAs="String">
               <value>True</value>
           </setting>
           <setting name="TextEffect" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="TextOutlineColor" serializeAs="String">
               <value>#00000000</value>
           </setting>
           <setting name="TextOutlineThickness" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="TransitionEffect" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="ImageStretch" serializeAs="String">
               <value>Uniform</value>
           </setting>
           <setting name="System" serializeAs="String">
               <value />
           </setting>
           <setting name="TextInfoFolder" serializeAs="String">
               <value />
           </setting>
           <setting name="TextScrollingOrientation" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="ScrollingSpeed" serializeAs="String">
               <value>0</value>
           </setting>
           <setting name="CloseAfterScrollingCompleted" serializeAs="String">
           </setting>
           <setting name="HiFolder" serializeAs="String">
               <value />
           </setting>
           <setting name="NvramFolder" serializeAs="String">
               <value />
           </setting>
           <setting name="SnapToGrid" serializeAs="String">
           </setting>
           <setting name="HTImageHeightBypass" serializeAs="String">
               <value>160</value>
           </setting>
           <setting name="HTImageBypass" serializeAs="String">
           </setting>
           <setting name="MarqueeFileName" serializeAs="String">
               <value />
           </setting>
       </Hyper_Marquee.Properties.Settings>
   </userSettings>
</configuration>
<HyperMarqueePreferences xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
 <MarqueeFilename>mame-hs-marquee_artwork</MarqueeFilename>
 <WindowTop>13</WindowTop>
 <WindowLeft>14</WindowLeft>
 <WindowHeight>305</WindowHeight>
 <WindowWidth>1091</WindowWidth>
 <WindowState>Normal</WindowState>
 <WindowTopMost>true</WindowTopMost>
 <EditMode>false</EditMode>
 <DefaultSystemPath />
 <SystemConfFile />
 <BackgroundImageFile />
 <ForegroundImageFile />
 <ForegroungBrush />
 <ThemePath />
 <DefaultThemePath />
 <ThemeVideoPath />
 <ThemeTransitionPath />
 <DisplayVideoThemeFrame>false</DisplayVideoThemeFrame>
 <PlayVideoTheme>false</PlayVideoTheme>
 <PlayVideoTransitionTheme>false</PlayVideoTransitionTheme>
 <VideoVolumeTheme>0</VideoVolumeTheme>
 <VideoTransitionVolumeTheme>0</VideoTransitionVolumeTheme>
 <VLCpath />
 <VideoFile />
 <VideoTransitionFile>e:\HyperSpin\Media\[system]\Video\Override Transitions\[FileName].flv</VideoTransitionFile>
 <UserShaderinsteadOfVideo>false</UserShaderinsteadOfVideo>
 <MarqueeTransparency>0</MarqueeTransparency>
 <MarqueeStyle>0</MarqueeStyle>
 <TextFont>Pump LET Plain</TextFont>
 <FontBrush><SolidColorBrush xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation">#FF000000</SolidColorBrush></FontBrush>
 <FontShaderEffect>false</FontShaderEffect>
 <TextFontSize>72</TextFontSize>
 <HorizontalAlignment>Left</HorizontalAlignment>
 <VerticalAlignment>Top</VerticalAlignment>
 <BackgroungBrush><SolidColorBrush xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation">#BE000000</SolidColorBrush></BackgroungBrush>
 <BorderBrush />
 <HiToText />
 <BorderThikness>
   <Left>0</Left>
   <Top>0</Top>
   <Right>0</Right>
   <Bottom>0</Bottom>
 </BorderThikness>
 <AutoCloseDelay>0</AutoCloseDelay>
 <StartDelay>0</StartDelay>
 <TextOrientation>Vertical</TextOrientation>
 <TextScrollingOrientation>0</TextScrollingOrientation>
 <TextScrollingSpeed>0</TextScrollingSpeed>
 <DisplayUnderFont>false</DisplayUnderFont>
 <DisplayScoreHeader2>false</DisplayScoreHeader2>
 <CloseAfterScrollingCompleted>false</CloseAfterScrollingCompleted>
 <TextEffect>2</TextEffect>
 <GifRepeatBehavior>0</GifRepeatBehavior>
 <TransitionEffect>0</TransitionEffect>
 <FontOutlineThickness>2</FontOutlineThickness>
 <FontOutlinedBrush><SolidColorBrush xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation">#FF000000</SolidColorBrush></FontOutlinedBrush>
 <ImageStretch>Fill</ImageStretch>
 <ForegroundImageStretch>None</ForegroundImageStretch>
 <BackgroundImageStretch>None</BackgroundImageStretch>
 <VideoStretch>None</VideoStretch>
 <VideoTransitionStretch>None</VideoTransitionStretch>
 <MarqueeSystem>MAME</MarqueeSystem>
 <TextInfoFolder />
 <HiFolder />
 <NvramFolder />
 <HighSocreTitleHeader1 />
 <HighScoreTitleHeaderPadding />
 <SnapToGrid>false</SnapToGrid>
 <HTImageBypass>false</HTImageBypass>
 <HTImageHeightBypass>180</HTImageHeightBypass>
 <DigitalTextClosing>0</DigitalTextClosing>
 <ArtworkPathLocation>E:\Hyperspin\Media\[system]\Images\Marquee\[FileName].png</ArtworkPathLocation>
 <Artwork1AlternativeLocation>E:\Hyperspin\Media\[system]\Images\Marquee\[FileName].jpg</Artwork1AlternativeLocation>
 <Artwork2AlternativeLocation>E:\Hyperspin\Media\[system]\Images\Wheel\Old\[FileName].png</Artwork2AlternativeLocation>
 <Artwork3AlternativeLocation>E:\Hyperspin\Media\HS Marquee\[system].png</Artwork3AlternativeLocation>
 <Artwork4AlternativeLocation />
 <ArtworkEffectShader />
 <VideoArtworkVolume>0</VideoArtworkVolume>
 <GameInfoLocation />
 <HyperListLocation />
 <GameInfoText>E:\Hyperspin\HyperLaunch\HyperMarquee\Data\HyperList\[system].xml</GameInfoText>
 <DigitalTextSourceOption>1</DigitalTextSourceOption>
 <DigitalTextScrollingOption>0</DigitalTextScrollingOption>
 <MarqueeSpeak>false</MarqueeSpeak>
 <SpeakRegEx />
 <SpeakRegExReplacement />
 <TransitionOption>1</TransitionOption>
 <ArtworkShader>0</ArtworkShader>
 <TransitionShaderName>Transition_RippleEffect</TransitionShaderName>
 <TransitionShader><Transition_RippleEffect Progress="0" xmlns="clr-namespace:Shaders;assembly=Shaders" xmlns:av="http://schemas.microsoft.com/winfx/2006/xaml/presentation"><Transition_RippleEffect.Texture2><av:ImageBrush ImageSource="pack://application:,,,/Icons/EDS.ico" /></Transition_RippleEffect.Texture2></Transition_RippleEffect></TransitionShader>
 <ForegroungShader />
 <BackgroungShader />
 <SuperShader />
 <TransitionShaderDuration>1000</TransitionShaderDuration>
 <NamedPipeID>MAME-HS-Marquee_Artwork</NamedPipeID>
 <AutoCloseEventList>2, 4, 6, 11</AutoCloseEventList>
 <ArtworkCycling>false</ArtworkCycling>
 <ArtworkCyclingInterval>5</ArtworkCyclingInterval>
</HyperMarqueePreferences>
<configuration>
   <configSections>
       </sectionGroup>
   </configSections>
   <startup>
   </startup>
   <userSettings>
               <value>100</value>
           </setting>
               <value>100</value>
           </setting>
               <value>300</value>
           </setting>
               <value>600</value>
           </setting>
           </setting>
               <value />
           </setting>
               <value />
           </setting>
               <value>5</value>
           </setting>
               <value>0</value>
           </setting>
           </setting>
           </setting>
               <value>20</value>
           </setting>
               <value />
           </setting>
               <value />
           </setting>
               <value>Left</value>
           </setting>
               <value />
           </setting>
           </setting>
           </setting>
               <value>0</value>
           </setting>
           </setting>
           </setting>
               <value>True</value>
           </setting>
               <value>0</value>
           </setting>
           </setting>
               <value>0</value>
           </setting>
               <value>0</value>
           </setting>
           </setting>
               <value />
           </setting>
               <value />
           </setting>
               <value>0</value>
           </setting>
               <value>0</value>
           </setting>
           </setting>
               <value />
           </setting>
               <value />
           </setting>
           </setting>
               <value>160</value>
           </setting>
           </setting>
               <value />
           </setting>
   </userSettings>
</configuration>
 <SystemConfFile />
 <ForegroungBrush />
 <ThemePath />
 <ThemeVideoPath />
 <VLCpath />
 <VideoFile />
 <BorderBrush />
 <HiToText />
 <BorderThikness>
   <Left>0</Left>
   <Top>0</Top>
   <Right>0</Right>
   <Bottom>0</Bottom>
 </BorderThikness>
 <TextInfoFolder />
 <HiFolder />
 <NvramFolder />
 <SpeakRegEx />
 <SuperShader />
did you read post #313
@zong2000k
Yes read the read only post and have undertook that as well. When i'm on HS main page I see blank marquee, when I go into a system i.e sega 32x it shows me graphics. If I exit out to main HS menu that sega 32x graphic stays active, if I enter another system that new graphic shows, but then carries back over into my HS menu when I exit.
Getting frustrated now LOL
