  • Replies 463
So only the 32bt version has the plugins?
Yes , activex plugin have not been ported to win64 ,
but i've got Windows 7 64bits and with 32 bit version of vlc activex : that works fine.
Vlc will be installed in program files x86 folder.
r0m@n0
Ok, I uninstalled x64 and installed the x32 version. Now when I run it from HyperSpin it searches and filters and a black window with a cone is on the right (vlc plugin) but as soon as you click a game hyperspin disappears and the Hd screen resolution is now 800x600 and I have to go into the task manager to close hyperspin. Any ideas?
Does this problem disapear if you disable video artwork preview on parameters panel ?
It does but then you don't get the video. When I re enabled it sometimes it plays and sometimes it crashes hyperxmlspin
Ok it seems something get wrong with vlc activex ,
try to fully uninstall vlc and then reinstall it with all components (during installation select videos flv & mp4 for associated videos)
For me this method works without errors otherwise i don't know what could it be...
r0m@n0
r0m@n0
Hi , i've fixed activex bugg , problem comes during game selection with no video associated.
Some problems fixed from previous version (1.0.4) :
+04/01/2015 - Fixed --> Artwork4 Preview during game selection.
+04/02/2015 - Fixed --> Reload Database Button now works.
+04/02/2015 - Fixed --> ActiveX crash during game selection with no video associated.
r0m@n0
Hi not sure if it is an oversight but it says it is version 1.04 not 1.05 in the title bar when it runs
Hi , it's a mistake ;-)
That's really the 1.0.5
r0m@n0
Hi my system runs at 1920 x 1080 but your program runs at 800 x 600. Is there is simple way to force it to run at full HD? At 800 x 600 the results window is huge and difficult to navigate. I've tried enlarging the bgd image but that didn't work.
I reinstalled everything and now those crashes have gone. Nice job
Yes it's an option already asked , I will made it as soon as possible.
Another good feature will be also added...
R0m@n0
R0m@n0
That's brilliant can't wait- things are getting interesting [emoji16]
Hi just wanted to say I've used this quite a bit this week and it works well. However may I ask that when you run it from standalone that it gives you an option to close down rather than having to rerun it to perform another search.
How is the revised version coming along? I'm trying to be patient [emoji54] but it is frustrating to have to adjust the size of the results fields every time.
Thanks
Thanks
Hi , i will add the option to let hyperxmlspin open on mode "show" and standalone in next release , i think also it's necessary.
I will enlarge hyperxmlspin gui to not frustrate when many results appears with 3 more résolutions : 1024x768 , 1280x720 and 1920x1080.
I will also add a new button very usefull (surprise)
But in order to not frustrate everybody with a fully bugged version i need between 2 to 7 days more working on it.
r0m@n0
r0m@n0
Please take whatever time you need. I appreciate the time things take. I'm looking forward to its release [emoji51]
I've copied the files over but the exe refuses to run and generate the ini. As soon as I run it I get the error.....ran it on two pcs running win7 64bit
Ok , sorry , the pack have been updated with new executable.
same link as before
r0m@n0
Ok...now it's up and running. What does the validate button do? When I click it from running standalone it just closes down the program. Love the new size screen. Would it be possible to have the system logo displayed along side the artwork also?
Also...(sorry) is it possible to make the columns remember their sizing. Ideally I would love to have more control over that table as there seems to be a lot of wasted space and I'm constantly resizing the column headers when I load it up....that's every time .
Great update btw. Love being able to play from the search results!
Thanks again
Hi there! I have upgraded to v1.1, but after the search the program show several notification windows with script errors. I think it has to do with the game videos, because this does not display. All other artworks does show in the screen.
I love the new additions! I hope you can solve this though. Thanks.
Hi , for video preview you need vlc 2.0 or higher version and enable activeX during install. If problem is still not solved after that , show me a screenshot of your window error.
R0m@n0
R0m@n0
Hi did you get chance to review my post above? Thanks
R0m@n0
Yep, that did it! I just realized that the vlc is mentioned in the first post. But i did not read the optional notes. Anyway, thanks for the fast reply, just send you a little donation. Searching through 40 000 games is now a breeze! Thank you.
