  • Replies 463
thanks Ninja, I was just about to ask for a non-bordered one. :thumbsup:
Romano:
Thanks for the new version! Happy to see you are still developing it. I have run into a problem. HyperXMLspin.exe works only when I run it directly, from windows explorer. All videos, searches, lists, running games, all work. Also registration works (after you run the database generation).
But in Hyperspin I can only go into the subwheel, but HyperXMLspin.exe does not start (at all, not seen in task manager). i followed your instruction, except not the optional ones. I have selected HyperXMLspin as the list item in the config.
cheers
Bastiaan
I am running Hyperspin 1.4 + the latest Rocketlauncher. But RL is just used to launch the games from HyperXMLspin, right? I have mapped RL in the config, if that's what you mean. Sorry, i am not so computer savvy, thanks for your patience.
I will upload a screen dump later when I get home.
I'm working on hyperxmlspin to update it to 1.6.1
here is the change log :
+11/11/2015 - Fixed --> Sound from game selected when playing from game result.
+11/11/2015 - Added --> Hyperxmlspin list export to a new or existing one.
+11/11/2015 - Fixed --> Artworks deleting from the games list to delete on "edit" mode.
-> When you choose "export" you can also select an existing Hyperxmlspin list and then export it to a new or existing "main" or "genre" list
      If that one already exist , you will be able to edit,delete,add or overwrite combination of the 2 lists.
you'll get the new version with link soon...
romano
edit : Bclout send me your hyperxmlspin.ini file
  • 8 months later...
Hi , i ve made an update of hyperxmlspin to 1.6.8 , here the changelog :
Version 1.6.8
+07/27/2015 - Fixed --> Bugg with VLC activeX 64b version , added new HyperXMLspin executable compiled for 64b machine.
+07/27/2015 - Fixed --> Crash of app after multi videos previewed.
Thanks to Brian for error report
r0man0
  • 3 weeks later...
Hi just for say that 1.6.9 is updated
look for read-me.txt for changelog
Package have been updated on main post.
I will update the main post informations later
i have to go
bye
Sorry , for the moment I m not at home will do that later.
I think also the background bug is not fixed for you , I want to knows if this bug appears on same config than yours. Because I ve not find an issue for that. (Exept run the app not in full screen)
Once the dat file is complete I'll try not in full screen thanks. Basically my bug is I can launch outside of the latest Hyperspin but launch at wheel I only get the transparent background to populate and the fields never appear
I've just updated to the latest hyperspin and latest hyperxmlspin and it runs fine until I click on one of the search results. Then I lose focus back to hyperspin. Tried it several times and it is consistent.
Agreed but at least you get the fields to display through Hyperspin. It works great outside of Hyperspin btw. How long did it take to create the dat file?
I never had to do the dats. Just overwrote my old folder.
Hi , i m back again to try to solve the focus problem again and database creation
here is a new exe with attempt to solve this problem , i've also add the old database creation function if creation duration is more than 10mn.
please report me if buggs are solved !
r0man0
