ninja2bceen Posted May 4, 2015 Posted May 4, 2015 I havnt updated yet because of complaints. Can someone else do this? Also please keep the current version up as well for a bit :-) please Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted May 4, 2015 Posted May 4, 2015 Actuall Romano can you do what ghutch is doing to his so he doesn't ever have to do this again? I'm currently working on this. Expect a new version by the end of this week. Removing HyperLaunch_Path setting. Now takes this setting from Hyperspin settings file. Added relative path support. Allow null values to be set for controls. I just need to do some testing before release. Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted May 4, 2015 Author Posted May 4, 2015 Hi , i need somebody to test if this new executable works with rocketlauncher and with hyperspin 1.4+. http://hypermachine.free.fr/HyperXMLspin.exe thanks r0m@n0
r0man0 Posted May 8, 2015 Author Posted May 8, 2015 File Name: HyperXMLspin 1.2.1 File Submitter: r0man0 File Submitted: 08 May 2015 File Category: Add-Ons Credits: r0man0 This is the 1.2.1 version of HyperXMLspin for Hyperspin +create/edit/save favorite genres that stretch across all systems in one genre wheel. +create/edit/save themed genres that stretch across all systems (ie create a Mario wheel from all systems) in one genre wheel. +create/edit/save console favorites, handheld favorites, arcade favorite genre wheels etc... +search for keywords to view a temporary search result genre. You can save the results as a genre if you like and use the results often. +as you update your media, you can sync the genres media here by pressing a button so your new media is always up to date in the genre wheels here. +New : Play directly to game found from HyperXMLspin gui results. +New : Hide/Show HyperXMLspin with an Hotkey. https://www.youtube.com/watch?v=PDMQToOECRU&feature=youtu.be To use HyperXMLspin : Enter or select at least on search term then : -> Use the "show" function (by default) for an immediate search . -> Use the "create" function to save your search results in a genre. -> Use the "Add" function to add the search results to an existing list. The last two functions are usable without search criteria: -> Use the " delete " function to delete an entire list and media. -> Use the " edit " function to sort games by genre, year , etc ... or to delete them. Then confirm with "Search" button. Folow the instructions below to try this application : 1 / HyperHQ.exe (use main menu wizard) to add new item with name "HyperXMLspin" (you can also use your own HyperXMLspin name) 2 / To the question "Does this menu item have a sub-wheel" click "yes" 3 / Select Where you want to show your HyperXMLspin Item on the list of items (select where you want) 4 / Go to wheel settings , select HyperXMLspin Wheel then "emulator" 5 / Field Executable : Select HyperXMLspin.exe file on HyperXMLspin Directory 6 / Select Execution : Normal , PC game : Disabled , Use Full Path To Roms : Disabled , Search Subfolders : Disabled 7 / Leave empty for fields : Rom Path , Params , Extensions - WinState : Hidden 8 / select "navigation/themes" , check "use xml indexes","clones use parent videos","clones use parent themes" then Close HyperHQ. 9 / Download & Extract HyperXMLspin_v1.2.1.zip 10/ Copy & Overwrite Databases & Media folder on HyperSpin Directory 11/ Run HyperXMLspin.exe and edit config as (See ReadMe.jpg) : 12/ Compulsory (1) Select your HyperSpin directory 13/ Compulsory (2) Select the HyperXMLspin's item name 14/ Optional (3) Select Parental filter to filter adults results for HyperXMLspin. 15/ Optional (3) Select your original "Hyperlaunch" renamed , that enable parental filter to all sytems. HyperXMLspin must be configured as : a/ Rename your Original HyperLaunch.exe file to another name (ex: HyperLaunch1.exe,HyperlaunchOriginal.exe,etc...) b/ Copy HyperXMLspin.exe in HyperSpin directory and rename it to HyperLaunch.exe c/ Select on step /5 : Hyperlaunch.exe file in HyperSpin directory (that one you have renamed) d/ Launch and set HyperXMLspin config (now HyperLaunch) from step 12/ 16/ Optional (4) Select emulation mouse to joystick enable configuration for joystick number and 8 buttons 17/ Optional (5) Select screen resolution for full screen/window view : 800x600/800x600 , 1024x768/1024x768 , 1280x720/1000x720 and 1920x1080/1380x1010 18/ Optional (6) Select HyperXMLspin's language : French or English 19/ Optional (7) Select fullscreen mode enable background picture selection & transparency. 20/ Optional (7) Select background picture , if none is selected , background color will be used. 21/ Optional (7) Select transparency , for background picture or color. 22/ Optional (8) Select background color and police color. 23/ Optional (9) Select the keyboard exit key , option key and Hypersearch key for HyperXMLspin. 24/ Optional (10) Select Show virtual keyboard , if you want to use integrated virtual keyboard with HyperXMLspin 25/ Optional (10) Select Parental control ,and define a PIN code to block access to configuration panel and limit HyperXMLspin in "Show" only. 26/ Optional (10) Select Show Video Artwork to enable preview of video and artwork into game search result popup before copy (need VLC 2.0 or Higher version) (http://www.videolan.org/index.fr.html) 27/ Optional (11) Select if necessary program to start on launch and on exit with if necessary their parameters. 28/ Optional (12) Select Reload Database to recreate HyperXMLspin database. 29/ Optional (12) Select Check Medias to update modified media on HyperXMLspin That's all, now : Search,play,enjoy !!! Created with Autohotkey. To help me : Donate Report me buggs or ask me your questions to : [email protected] Special thanks to beta-testers : ninja2bceen ghutch92 arshesney Click here to download this file Click here to download this file
potts43 Posted June 14, 2015 Posted June 14, 2015 Hi just updated to RL but still using HS 1.3....when I try to configure the options panel I get a red error in the bottom left saying "can't locate hyperlaunch.exe" obviously my HL is now Rocketlauncher.exe. I'm not sure if I'm the first to try this on the new RL so any help appreciated . I'm using your hyperxmlspin v 1.3 but it appears to be hard wired to look for hyperlaunch.exe
ninja2bceen Posted June 14, 2015 Posted June 14, 2015 hi ninja2bceen , i need 2 files to know modifications please post me your new "settings.ini" and one of your system.ini file (not main menu.ini) located in hyperspin/settings/ folder. I will try to enable hyperxmlspin working with rocketlauncher. r0m@n0 pots can u supply him with these?Also check post 103 (Tapatalk) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
potts43 Posted June 14, 2015 Posted June 14, 2015 pots can u supply him with these? Also check post 103 (Tapatalk) Ninja I intend to try that exe tomorrow and if no success I'll send him my ini files he requests.
ninja2bceen Posted June 14, 2015 Posted June 14, 2015 Best of luck. If all those tools work for u I'm definitely upgrading. The #s are ones I think will work no problem? **hyperspeech, **hyperxml, ***hi score ***hypersearch #Hypertools #rlauncher, #multi script, #randomizer #hyperspin 1.4 (Tapatalk) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
potts43 Posted June 15, 2015 Posted June 15, 2015 Swapped the exe over but when running it for the first time there is no option to point it to the Rocketlauncher.exe and then an error comes up saying can't find hyperlaunch.exe or not defined. You can't trick it by using an older ini as when you run it you are told the ini appears to be corrupt and asks to delete it. I guess we need the option page to ask where the Rocketlauncher.exe is and we should be fine.
ninja2bceen Posted June 15, 2015 Posted June 15, 2015 Pm romano (Tapatalk) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
potts43 Posted June 16, 2015 Posted June 16, 2015 Pm romano (Tapatalk) Already emailed him and he is now on the case!
potts43 Posted June 17, 2015 Posted June 17, 2015 Pm romano (Tapatalk) Just tested v 1.4. Romano has done a super job. Works awesome...I've let him know so I'm sure he will release it ASAP. Cheers
potts43 Posted June 17, 2015 Posted June 17, 2015 Pm romano (Tapatalk) Just tested v 1.4. Romano has done a super job. Works awesome...I've let him know so I'm sure he will release it ASAP.Working with beta 15 and RL Cheers
ninja2bceen Posted June 17, 2015 Posted June 17, 2015 Cool. What are the new features (Tapatalk) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
potts43 Posted June 17, 2015 Posted June 17, 2015 Works like hypersearch and original hyperxmlspin . Launcher is configurable and searches very quickly! He is going to release it soon. He's done a fine job!
ninja2bceen Posted July 12, 2015 Posted July 12, 2015 Hey Romano, I just tested ur new version, boy lots changed. Looks good. I like the hypersearch mode. I think I found a bug in that mode though. I have hypersearch mode on and I have a wheel for hyperxml spin. When I enter that wheel, the app flashes as it loads and is minimized. I must click one of the option keys to get to the search. Is there a way to allow upon entering the wheel to open the app under full search mode? Then from there I can choose to do the quick search? Basically I'm just trying to take out the ugliness of launching from the wheel and see the app flash only to find I have to push a button to get the search back up Also if you go to options and then press cancel, you'll find the background disappears when it was transparent. Pressing ok doesnt remove the background Nice job btw Sent from my iPad using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted August 13, 2015 Author Posted August 13, 2015 Thanks ninja2bceen , i've update & fixed problems on hyperxmlspin version1.5. r0man0
ninja2bceen Posted August 14, 2015 Posted August 14, 2015 perfection, thanks Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted November 8, 2015 Author Posted November 8, 2015 Hi Export option will be added soon , but this option will be unlocked only for donaters. You will be able to export results as a new main wheel or genre wheel and you will not have to set up each games to be launched with rocketlauncher or hyperlaunch because of the hyperxmlspin game name format that allows to launch each games from anysystem from any exported main or genre wheel. I've also fixed windows font size & caret problem for virtual keyboard. New version will be uploaded in 2-3 days...
spotUP Posted November 8, 2015 Posted November 8, 2015 Will those exported systems be launchable even without hyperxmlspin installed?
r0man0 Posted November 9, 2015 Author Posted November 9, 2015 No , because of the game name tag on xml files created by hyperxmlspin ,exported systems need hyperxmlspin fully installed to be launched directly. Is it a problem ? r0man0
potts43 Posted November 9, 2015 Posted November 9, 2015 Glad that this is still being actively developed [emoji106]
ninja2bceen Posted November 9, 2015 Posted November 9, 2015 Romano, the biggest complaints folks have is the duplicated media, that's probably one of the reasons they are asking. I don't like the forced approach to donate, how will you manage those who donated on future updates from prior donations? Sent from my iPad using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted November 9, 2015 Author Posted November 9, 2015 hi ninja2bceen , since the beginning of hyperxmlspin , there was 3 donators for more than 900 download , the forced approch to donate 10 or more will keep this project alive as far as i can. Hyperxmlspin is still fully free & all options are availlable without donation, exept the export option. Of course, beta testers & old donators will have full version , no problem ;-) For the moment duplicated medias are necessary because of hyperspin configuration that not allows to do that. r0man0
