sandog Posted October 10, 2015 Posted October 10, 2015 can someone point in the right direction for the retroarch setup.. I have hyperspin setup but not retro
reznnate Posted October 10, 2015 Posted October 10, 2015 can someone point in the right direction for the retroarch setup.. I have hyperspin setup but not retro If you have a Shield device, Retroarch setup is really easy. Basically you need to go into the online updater and download all the cores. The controller settings are detected and work by default. Assuming you have retroarch cores assigned in your hyperspin .ini files, it 'should just work'.
sandog Posted October 10, 2015 Posted October 10, 2015 I guess that's the point I'm at .. I have hyperspin working and retro installed... I have to setup the ini's to the retro settings.. On The shield TV is that the best emu to use is the retroarch is does something else work better
reznnate Posted October 12, 2015 Posted October 12, 2015 I guess that's the point I'm at .. I have hyperspin working and retro installed... I have to setup the ini's to the retro settings.. On The shield TV is that the best emu to use is the retroarch is does something else work better Retroarch is a great emulator but it's evolving fast so some cores are broken and some bugs exist. A bug that confounds many of us is the problem of two distinct retroarch.cfg files. It has one when you launch from within RA and a separate file when you launch from Hyperspin, Arc Browser, Gamesome, etc. SO, in order to set the bios folders and other .cfg options, you must successfully launch RA at least ONCE (using a system that isn't dependent on bios files), THEN make your config changes. At the moment, 3d emulators like PPSSPP and N64 launch from RA but fail when launched from a front-end. It's a new bug/regression I hope they fix soon. Read the sticky post regarding emulator setup -- lots of other emulator options. The 2600.emu, nes.emu, etc. emulators are well-regarded.
crom Posted October 23, 2015 Posted October 23, 2015 Hello!, i am getting problems setting up this thing, i have downloaded and installed Hyperspin and retroarch in my shield pro,created the folder hyperspin and downloaded everything into it,edited the .ini and moved the Hyperspin folder to the root of the shield. In the ini (super nintendo) i have like this, /sdcard/hyperspin/Emulators/Super Nintendo Entertainment System/roms/ , that´s the path it´s supposed where hyperspin must search for the roms, isn´t it?. So hyperspin launch ok, but it says no rom.... Can anyone help me please?
crom Posted October 23, 2015 Posted October 23, 2015 exe info] path=H:\hyperspin\emulators\Super Nintendo Entertainment System\ rompath=/sdcard/Hyperspin/Emulators/Super Nintendo Entertainment System/roms/ userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=zip parameters=cores/bsnes_mercury_performance_libretro_android.so searchsubfolders=false pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false roms_only=false [themes] use_parent_vids=false use_parent_themes=false animate_out_default=false reload_backgrounds=true [wheel] alpha=.15 small_alpha=1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD
crom Posted October 23, 2015 Posted October 23, 2015 just removed, still no luck, is there any step am i missing?, must i configure the emulator path?, must i configure something in retroarch, i already updated all cores and these things...
sevenseal Posted October 23, 2015 Posted October 23, 2015 just make sure your path label right, it is case sensitive.... caps and lowcase matters
crom Posted October 23, 2015 Posted October 23, 2015 Sevenseal, i hace edited the rompath like you told me, but the One it says only path, must i edit it?, must i write un the .ini where the emulator is?, if you can post an example Of your ini?
sevenseal Posted October 23, 2015 Posted October 23, 2015 also through hyperspin, i believe rhe games cant be archieve. and have to be in it raw form due to cli command is unable to use zip and 7z, has to be extracted out
Sting Posted October 23, 2015 Posted October 23, 2015 Have you got any systems working??? What is it saying when you launch rom???
Sting Posted October 23, 2015 Posted October 23, 2015 Also have you named your ROMs exactly the same as your .XML???
crom Posted October 24, 2015 Posted October 24, 2015 Sting i have not edited the XML, so maybe there is the problem. Hyperspin launch ok the main menú, and then says trying to Play ROM not existing ir somerhing like that, i didnt know nothing about the xml , thank you, i will try to make muy Rom's names to match with the xml,anda will post the results, again, than you.
Sting Posted October 24, 2015 Posted October 24, 2015 Don't edit the .XML you'll make loads of problems for yourself!!! Go here (http://hyperlist.hyperspin-fe.com) download the latest database for the system you need, and make sure your ROMs match game name exactly as it is
crom Posted October 24, 2015 Posted October 24, 2015 Sorry i mean edit the name Of my roms to match the XML,isnt that? , thanks
crom Posted October 24, 2015 Posted October 24, 2015 I suck,i downloaded the XML file from here, replaced the original One, put muy roms un the roms folder,and then usted the dons to rename them to match the XML file un database. Then i open the hyperspin con shield tv and again it says the ROM doesn't existe,could anyone upload a step by step con images,i dont know where am i failing. I have tried romd un zip and 7z
Sting Posted October 24, 2015 Posted October 24, 2015 When you unzipped them did you put the file extension to the ROMs in your setting .ini??? Example SNES (romextension=zip,smc) Just concentrate on one rom, and make sure it works by loading it outside of Hyperspin also
natedogny Posted October 25, 2015 Posted October 25, 2015 Any luck crom? I'm having the same exact problem with N64 ROMs.
crom Posted October 26, 2015 Posted October 26, 2015 i have no luck, and i am doing this tut step by step, and my roms are renamed exactly as the xml file says with don´s tool, so i don´t know what the fuck is the problem,i copy the Hyperspin to my shield root folder, and i have tried several times editing the roms path, but it doesn´t worl either, always says trying to launch missing rom. could it be the emulator (retroarch) path the problem?, i copied the android_settings exactly as the tut says: [exe info] path=H:\hyperspin\emulators\Super Nintendo Entertainment System\ rompath=Emulators/Super Nintendo Entertainment System/roms/ userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=zip parameters=cores/bsnes_mercury_performance_libretro_android.so searchsubfolders=false pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false roms_only=false [themes] use_parent_vids=false use_parent_themes=false animate_out_default=false reload_backgrounds=true [wheel] alpha=.15 small_alpha=1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=360 [video defaults] path=H:\hyperspin\Media\Super Nintendo Entertainment System\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=true remove_info_text=true use_last_game=false last_game=Wario's Woods (E) random_game=false start_on_favorites=false [special Art A] default=true active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [special Art C] active=false x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active = true show_year = true show_manf = true show_description = true text_color1 = 0xFD070B text_color2 = 0xFD070B stroke_color = 0x000000 text_font = Style3 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640
