HyperSpeech: Text-to-speech addon for HyperSpin 1.x 0.9
BoOgieman
Well....unfortunately I don't have access to the ftp to get the source files, I'd be happy to try and help with this if someone could somehow send me those source files......
I'm lovin my arcade
  • Replies 536
Absolutely my friend, here you go.
AHK Sources.7z
handleExec := checkFile( A_ScriptDir . "\handle.exe" )
If A_OSVersion = WIN_XP  ; parses path of cb.exe of OS is WIN_XP
	cbExec := checkFile( A_ScriptDir . "\cb.exe" )
starting line 51 - ending line 55
ParseActiveSystem(){	; Figures out which video is being played in the main wheel to determine the selected system :-)
	Clipboard =
	If A_OSVersion = WIN_XP  ; Check whether OS is WIN_XP or not
		RunWait %comspec% /c %handleExec% -p HyperSpin.exe | findstr /C:"\\Media\\Main Menu\\Video\\" | %cbExec% ,,Hide	; Fill the Clipboard
	}Else
		RunWait %comspec% /c %handleExec% -p HyperSpin.exe | findstr /C:"\\Media\\Main Menu\\Video\\" | Clip ,,Hide	; Fill the Clipboard
	Clipboard = %Clipboard%
	If ( Clipboard != "" ) ; If there is content in the Clipboard
		IfNotInString, Clipboard, "Override Transitions" 	; determines if an override video is playing which we don't want to act on
			Loop, parse, strHSSystems, `, 	; Parse the string with your systems, split by the comma character
				x := "\" . A_Loopfield . "."
				IfInString, Clipboard, %x%
					system := A_Loopfield
					Break
	}Else
			RunWait %comspec% /c %handleExec% -p HyperSpin.exe | findstr /C:"\\Media\\Frontend\\Video\\No Video" | %cbExec% ,,Hide	; Check whether there's a "no video" video found
		}Else
			RunWait %comspec% /c %handleExec% -p HyperSpin.exe | findstr /C:"\\Media\\Frontend\\Video\\No Video" | Clip ,,Hide	; Check whether there's a "no video" video found
			system = "Sorry`, Cannot determine this system. No matching system video found"
		Else
			system :=
	Clipboard =
	Return %system%
starting line 240 to ending line 282
these are the area of the code in hyperspeech that need editing to make it work again.
i will try to make changes so that eds can provide the necessary cli input that needed for this program to function again
i am going to be removing the call for handle.exe and cb.exe which was a hack way of receiving the information needed to declare what system and game being active.
the way hyperspin is in it currect version does not require these two programs anymore as a aid,
cb.exe = clipboard copy and paste monitoring.
handle.exe = scan and application process for certain activities.
right now i trying to figure from the source of hyperspeech and how it take LEDBlinky's cli input properly then make the adjustment with what eds provide.
so that is the intial plan as of right now
with EDS/Hypermarquee
hypermarquee already had voice speech capiability already
i was able to make a database that does system bios and game bios
here just a proof of concept that this database i have adapted over from hyperspeech does the job nicely
this can be done with text or without text...
it load speech based on LEDBlinky event triggers
https://onedrive.live.com/redir?resid=B589ED803582B702!2356&authkey=!AC1o6uCO9wLiWvA&ithint=video%2cmp4
if you are interested in the setup for your cab/pc for hyperspin, i will post a setup tutorial to help
there is a lot work to make it function the way it used to.
so i took a break and made it work with Hypermarquee, the result above is what i got so far
but i can still looking at fixing hyperspeech if there many that that want it done.
just wondering, from hyperspeech users, what were the important feature you like about it, so that i see that it still maintain?
Cool! For hyperspeech it was very flexible since you could enter whatever you wanted.
The features that itd like to hear are the following
Upon launch, after the video intro, an introduction to tell me how great looking I am
Then upon hovering over a system, it should say the system, description
Then upon giving over a game have it say a game description. It used to use a dat file for mame
Upon launching a game it should say something
Upon backing out a wheel say something
Upon entering genre or favorite say something
Upon exiting hyperspin tell me how much she will miss me
Upon getting back to hyperspin. After a game tell me how I did
I think that pretty much covers things
HyperMarquee & EDS Speech Tutorial Guide
06/05/2016 - Antos had done the work to replace HyperSpeech with HyperMarquee/EDS
THIS GUIDE IS MEANT TO HELP YOU NAVIGATE THROUGH THE MENU AND SHOW YOU WHERE TO PRESS BUTTONS/CHECKMARK OPITIONS, ONLY FOLLOW THE BUBBLE MESSAGE DIRECTIONS TO COMPLETE EACH TASK, THE BUBBLE MESSAGE ARE THE MAIN FOCUS OF THE SETUP.
WARNING SCREENSHOTS ARE EXAMPLES OF MENU AREAS, NOT MEANT TO BE EXACT SETUP COPY.
Proof of Concept
Add Main Menu.ini to Rocketlauncher\Data\Game Info\
This was the data that was adapted over from HyperSpeech to HyperMarquee
this file here is the System's Bios that is used on the Main Menu when highlight over each system
if you have more updated system bios for current system, please feel free to share with me so that i can update it. or you can update yourself if you edit the ini file
Last updated on 06/09/2016
Main Menu.zip
Install in the Root folder of HyperMarquee
This folder contains all the messages for each event that occurs in Hyperspin, so it will speech just like Hyperspeech.
SpeechText.zip
INSTALLING and SETUP EDS with HYPERSPIN
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To Setup EDS with Hyperspin, please refer to Manual that is provide with the EDS install.
http://www.hyperspin-fe.com/files/file/7391-hyperspin-event-dispatch-system-eds/
if you need help or support please go the EDS's Thread
http://www.hyperspin-fe.com/topic/9006-hyperspin-event-dispatch-system-eds/
SETTING RESULT FOR = EDS's Speech for Bios and Events
Configure EDS
STEP 1:
STEP 2:
YOU WILL BE SELECTING BOTH APP ENTRY AS HYPERMARQUEE
STEP 3:
STEP 4:
STEP 5:
ALL done for EDS Now to HyperMarquee
SETTING FOR = Hypermarquee's Speech for System & Game Bios
To Setup HyperMarquee with EDS, please refer to Manual that is provide with the HyperMarquee install.
http://www.hyperspin-fe.com/files/file/7397-hypermarquee/
if you need help or support please go the HyperMarquee's Thread
http://www.hyperspin-fe.com/topic/9012-hypermarquee/
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
STEP 6:
STEP 7:
STEP 8:
STEP 9:
SETTING FOR = Hypermarquee's Speech for Events Speech
STEP 1 to STEP 6: Repeat from hypermarquee system and game bios
STEP 7:
STEP 8:
STEP 9:
STEP 10:
STEP 11:
DONATION:
Antos: https://www.paypal.com/ca/cgi-bin/webscr?cmd=_flow&SESSION=Eg4O-6Pswp8pbC-nX_k-t-KISdBI2vbpcgFmLIKShYRC383cNL0N7DNUQde&dispatch=5885d80a13c0db1f8e263663d3faee8dcce3e160f5b9538489e17951d2c62172
Sevenseal: https://www.paypal.com/us/cgi-bin/webscr?cmd=_flow&SESSION=xv8xt4wUB-Ju8ct4waQDQv56QHCWZsuptN5_U0jNCBDWxHYkfhOm9DzbNzm&dispatch=5885d80a13c0db1f8e263663d3faee8dcce3e160f5b9538489e17951d2c62172
when i finish this guide, i will head back to playing with the source code... i rather give something that work for mean time then have everyone wait until it complete and have nothing in the process
cheer!
This is all great work Sevenseal, thank you. I don't use EDS or HyperMarquee, well I haven't tried them again since first release, so I'll either wait to see what you come up with or try them again.
It may be my phone but I could not see your screen shots above.
viewable on browser... i dont see it either on tapatalk, i will try a different host to for the images soon... lmao just woke to use the bathroom sometime soon i will change them
tutorial guide up in progress ON POST #418 then next i will relocate the images to be hosted somewhere else so that it is easier to view
