5thWolf Posted May 22, 2013 Posted May 22, 2013 Well, I found another version of Project 64 2.1.0.1 for those of you who missed it's release like I did Was officially released on the first according to the official site. However as ussual now, the installer from the official site is loaded with bloat ware. Get it here with bloat ware & installer removed. You can place it anywhere and just run it. PROJECT 64 2.1.0.1 ~5thWolf~
Guest xtalesx Posted June 1, 2013 Posted June 1, 2013 i am having trouble getting this to launch via hyperspin, i just see a blank screen =(
trailervert Posted June 2, 2013 Posted June 2, 2013 Thanks worked first time for me. xtalesx did you try to launch via HyperLaunch before launching in hyperspin?
irfdude Posted June 12, 2013 Posted June 12, 2013 i am having trouble getting this to launch via hyperspin, i just see a blank screen =( I had the same issues. I had to open it independently and change a setting to make sure it would open to full screen. Worked fine after that
Deadly Posted June 12, 2013 Posted June 12, 2013 Would like to hear if it's worth upgrading past 1.7 yet.
newer Posted June 12, 2013 Posted June 12, 2013 Good Infos Thanks.... Well, I found another version of Project 64 2.1.0.1 for those of you who missed it's release like I did Was officially released on the first according to the official site. However as ussual now, the installer from the official site is loaded with bloat ware. Get it here with bloat ware & installer removed. You can place it anywhere and just run it. PROJECT 64 2.1.0.1
zero dreams Posted June 12, 2013 Posted June 12, 2013 If you click the buttons at the top and scroll the system name it should lead you what you're looking for. Here. Right side. HyperLaunch | HyperWiki | HyperSearch | Intro | Evolution | FadeProject | Checker | Steam Wheel
Circo Posted June 12, 2013 Posted June 12, 2013 Is that your site rangel? ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Xenobit Posted July 15, 2014 Posted July 15, 2014 I revive this thread because I cant get Project64 2.1 start working from Hyperlaunch. It works well as a standalone application, but if I use HL it opens the Emulator and the load file dialog appears. Project64 does not support 7z, so I guess I must tell HL to open it in a temp folder and pass this file to the emulator?! Any advice or hints for me? Most of the other emulators are working fine.
yashijoe Posted July 15, 2014 Posted July 15, 2014 I revive this thread because I cant get Project64 2.1 start working from Hyperlaunch. It works well as a standalone application, but if I use HL it opens the Emulator and the load file dialog appears. Project64 does not support 7z, so I guess I must tell HL to open it in a temp folder and pass this file to the emulator?! Any advice or hints for me? Most of the other emulators are working fine. Check project64 extensions support on global settings under emulators tab. In case, just add 7z.
Xenobit Posted July 16, 2014 Posted July 16, 2014 Hi, 7z is in the list of extensions. HL unzips it in my temp folder, but that path seems not to be given to the emulator. What module do you use for v2.1?
yashijoe Posted July 20, 2014 Posted July 20, 2014 Hi,7z is in the list of extensions. HL unzips it in my temp folder, but that path seems not to be given to the emulator. What module do you use for v2.1? Sorry for late reply. I'm using Project64 2.1.0.1 with 2.0.0.14 module.
SIMPLYAUSTIN Posted July 20, 2014 Posted July 20, 2014 Nintendo 64 Why cant there just be one good emulator?? Simply Austin's YouTube
gigapig Posted July 20, 2014 Posted July 20, 2014 Nintendo 64 Why cant there just be one good emulator?? Maybe one day soon?? http://www.hyperspin-fe.com/forum/showthread.php?33382-The-state-of-N64-emulation-Thoughts&p=312079&viewfull=1#post312079
zerojay Posted July 20, 2014 Posted July 20, 2014 Maybe one day soon?? http://www.hyperspin-fe.com/forum/showthread.php?33382-The-state-of-N64-emulation-Thoughts&p=312079&viewfull=1#post312079 MESS is quite a bit further along with their N64 driver at this point. About 60-75% speed with sound at the moment in most games.
KillaBLK Posted November 29, 2017 Posted November 29, 2017 Any new thoughts on this? I couldn' get RA or standalone Mupen64 working with RL. I just got the latest version of Project64 to launch... Finally! It isn' quite right yet tho.
