Grinder901 Posted February 21, 2016 Posted February 21, 2016 Hey everyone. I'm very new at this so be gentle. I am trying to insert an intro video into my Hypserspin set up. What do I need to do within Hyoerspin HQ? The video tries to come on but cuts out after a second and then Hyperspin launches. Any idea? Thanks Ryan
Avar Posted February 21, 2016 Posted February 21, 2016 Should just work. Do you have it in your :\HyperSpin\Media\Frontend\Video\ folder as Intro.flv?
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 Startup program is D:\Arcade\Media\Frontend\Video\Intro.mp4
Avar Posted February 21, 2016 Posted February 21, 2016 Go into :\HyperSpin\Settings\Setting.ini and scroll down to: [introVideo]Use_Intro=trueStop_On_Keypress=true Confirm that both values are set to true. If "Stop_On_Keypress=true" already, try to determine if your kb or controller is sending input. What control peripherals do you have plugged in?
JoyStickKilla Posted February 21, 2016 Posted February 21, 2016 Intro doesn't support mp4 from what I recall, has to be flv
Avar Posted February 21, 2016 Posted February 21, 2016 Intro doesn't support mp4 from what I recall, has to be flv I was thinking that initially but I double-checked and I've got 23 Intro vids on randomizer; half are MP4 and work fine.
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 This is child's play for you guys I know. I don't even see the folder for Hyperspin settings in my files. All I see is the Hyperspin application launch. If it is as simple as not wanting to play a mp4, how do I convert the video file to a flv?
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 I have the Hyperspin Startup Script Notepad open and I don't see an intro video option here.
epayson85 Posted February 21, 2016 Posted February 21, 2016 No need to convert. Just change the the .mp4 to .flv. It works like a charm. Both mp4 and flv are just container files.
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 Man this is frustring. I have the video intro properties open but I don't see a way to change the type of file.
Avar Posted February 21, 2016 Posted February 21, 2016 You shouldn't have to convert them. Like I said I use MP4s and they work fine. If it couldn't play MP4s your video wouldn't start to play and then stop.
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 Ok not converting them. Not even sure I can. Annoying that I open the drive and can't find the Hyperspin configuration folder to adjust the settings like you said
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 The video tries to start but something prevents it or like you said a key is being hit which cuts it
SubZero Posted February 21, 2016 Posted February 21, 2016 Wait wait wait, you downloaded the 1.4 update. you need to download the full install first. then update with the 1.4 pack. First http://www.hyperspin-fe.com/files/file/5599-hyperspin-133-full-install/ Then overwrite with 1.4 exe file http://www.hyperspin-fe.com/files/file/7500-hyperspin-14/
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 Ok I took it out. I also clicked off the option allowing to cut the video away with a button And boom! Intro video is working. It's the Iron Man/War Machine Drone battle in Iron Man 2. It's a bit long but I love it and could watch it over and over again. So now that it worked, that leads me to believe that somewhere a command or button is being recognized which is cutting the video out. I have led blinky on my computer as well as my xbox controllers hooked up to a wireless USB drive. Could either of these things be causing the issue?
Grinder901 Posted February 21, 2016 Author Posted February 21, 2016 Well thanks everyone for your help and suggestions. The video starts now. any one have any suggestions as to how to figure out if a button or command is causing it to cut the video off? If nothing else, at least I have the intro video I wanted playing and then Hyperspin can be used.
kylecp1979 Posted February 21, 2016 Posted February 21, 2016 Did you use a disc or manually install the drivers for the 360 receiver? That might cause some issues possibly.
KillaBLK Posted November 23, 2017 Posted November 23, 2017 On 2/20/2016 at 5:47 PM, Avar said: I was thinking that initially but I double-checked and I've got 23 Intro vids on randomizer; half are MP4 and work fine. I was just wondering if I could do this! Is it done through hyperhq?
LiveSorcerer Posted August 6, 2018 Posted August 6, 2018 On 20/02/2016 at 11:47 PM, Avar said: I was thinking that initially but I double-checked and I've got 23 Intro vids on randomizer; half are MP4 and work fine. Sorry to be digging up this topic, could you explain how to do this, to leave the random intro? Apple iPhone 7 Silver 32GB (VIVO) / Huawei Mate 10 Pro 6GB RAM/128GB Black (TIM) Dell Inspiron i15 15.6" i5 2.2GHz+8GB DDR3L+1TB+Windows 10 Pro Apple Macbook Pro 13.3" 2012 i5 2.5GHz+16GB DDR3L+1TB (500GB SSD 850 Evo+500GB SSD 840 Evo Raid 0)+MacOS Sierra X-RetroNAS (Xbox Classic) AMD A8-5545 @2.7GHz + Radeon™ HD8510G/GALAX GT 1030 2GB 64Bits+8GB DDR3+120GB SSD+2TB+Windows 10 Pro /Kodi 18/Steam/HyperSpin PS3 Station (PS3 FAT)GA-H81N-D2H i5-4570 @3.6GHz+Intel® HD Graphics 4600+16GB DDR3+240 GB SSD+2TB HDD+Windows 10 Pro /Kodi 18/Steam/HyperSpin
thatman84 Posted August 6, 2018 Posted August 6, 2018 Check out the videos here There is one on random intro videos https://www.youtube.com/user/mjustin9 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
LiveSorcerer Posted August 7, 2018 Posted August 7, 2018 17 hours ago, thatman84 said: Check out the videos here There is one on random intro videos In that case would I have to change the extension to flv? I tried with mp4 and it did not start. Apple iPhone 7 Silver 32GB (VIVO) / Huawei Mate 10 Pro 6GB RAM/128GB Black (TIM) Dell Inspiron i15 15.6" i5 2.2GHz+8GB DDR3L+1TB+Windows 10 Pro Apple Macbook Pro 13.3" 2012 i5 2.5GHz+16GB DDR3L+1TB (500GB SSD 850 Evo+500GB SSD 840 Evo Raid 0)+MacOS Sierra X-RetroNAS (Xbox Classic) AMD A8-5545 @2.7GHz + Radeon™ HD8510G/GALAX GT 1030 2GB 64Bits+8GB DDR3+120GB SSD+2TB+Windows 10 Pro /Kodi 18/Steam/HyperSpin PS3 Station (PS3 FAT)GA-H81N-D2H i5-4570 @3.6GHz+Intel® HD Graphics 4600+16GB DDR3+240 GB SSD+2TB HDD+Windows 10 Pro /Kodi 18/Steam/HyperSpin
thatman84 Posted August 7, 2018 Posted August 7, 2018 You can try it. I believe there are some differences in mp4 videos. I dont have a collection as I have a custom one i am happy with. If you find any mp4 files uploaded here I would hope they werr tested with HS and work. Elsewhere who knows Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ninja2bceen Posted August 7, 2018 Posted August 7, 2018 Yes they need to be flv. You can change the mp4 to flv by just changing the extension! Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted August 7, 2018 Posted August 7, 2018 Also I am to release all my intros I’ve collected once I get to 1000 subs [emoji28]Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
LiveSorcerer Posted August 7, 2018 Posted August 7, 2018 1 minute ago, ninja2bceen said: Also I am to release all my intros I’ve collected once I get to 1000 subs Sent from my iPhone using Tapatalk Hi @ninja2bceen, i try to use your collection. Tell me how? https://emumovies.com/files/file/2295-hyperspin-intro-video-collection/ Apple iPhone 7 Silver 32GB (VIVO) / Huawei Mate 10 Pro 6GB RAM/128GB Black (TIM) Dell Inspiron i15 15.6" i5 2.2GHz+8GB DDR3L+1TB+Windows 10 Pro Apple Macbook Pro 13.3" 2012 i5 2.5GHz+16GB DDR3L+1TB (500GB SSD 850 Evo+500GB SSD 840 Evo Raid 0)+MacOS Sierra X-RetroNAS (Xbox Classic) AMD A8-5545 @2.7GHz + Radeon™ HD8510G/GALAX GT 1030 2GB 64Bits+8GB DDR3+120GB SSD+2TB+Windows 10 Pro /Kodi 18/Steam/HyperSpin PS3 Station (PS3 FAT)GA-H81N-D2H i5-4570 @3.6GHz+Intel® HD Graphics 4600+16GB DDR3+240 GB SSD+2TB HDD+Windows 10 Pro /Kodi 18/Steam/HyperSpin
