aginc81 Posted April 5, 2016 Posted April 5, 2016 I just signed in last night for the first time since 2010 and I see that there's a newer version or I should say a few newer versions since then. I'm not sure what version I have at this point, but it seems to still be doing just fine. Are there any advantages/disadvantages to upgrading?
progets Posted April 5, 2016 Posted April 5, 2016 If you're happy, just leave it alone. If you're not, there is a lot of great new emulators, games, artwork, videos, features, etc.. An upgrade from 2010 will be a lot of work since it would mean: - upgrading to RocketLaucher - upgrading your databases - renaming a lot of your roms - updating most of your emulators Let's face it, you're better off starting a new build from scratch. At least this way if your think it's too much work you can just revert back to your old build. You might try the pre-built image in the download section and see if that might be an option.
Spawk Posted April 5, 2016 Posted April 5, 2016 Wow 2010! A whole lot has changed since then. New versions of almost everything! RocketLauncher adds a bunch of features to the now defunct Hyperlaunch. That being said... if your setup works good and looks great to you, why bother? Maybe if you eventually find something that just won't work, then look at upgrading. Just saying, you may end up jumping through many hoops to get the simple things that already work in your rig working. Before you even get to a point of look at what you were missing. Actually, just noticed you are platinum. Download Giga's 51 system build onto a separate drive for a test spin!
32assassin Posted April 5, 2016 Posted April 5, 2016 LOL, you are not upgrading. You are replacing your entire system. if you don't care for the new features keep your system. the only thing you should upgrade is the Media their should be better looking media available now compared to what you have. You will not be able to upgrade your videos since they are now in MP4 format, and you are running FLV videos.
gigapig Posted April 5, 2016 Posted April 5, 2016 I assume you won't have HyperSync to download any missing media. You could give the Hyperbase Live beta a try but it's best not to add it to you current setup at this stage. It also does not work with XP if that is your OS.
badboo Posted April 5, 2016 Posted April 5, 2016 I would build a new system with Rocketlauncher from scratch and just use the media and roms from the old system.
aginc81 Posted April 5, 2016 Author Posted April 5, 2016 Rebuild it is! I just gotta remember how to do it, 6 years is a long time!
badboo Posted April 5, 2016 Posted April 5, 2016 ..... and don't forget emulators like the pcxs2 and epsxe are way better now
aginc81 Posted April 6, 2016 Author Posted April 6, 2016 Ok good to know! I'm actually gonna try out the pre built on another drive first as suggested and go from there.
aginc81 Posted April 6, 2016 Author Posted April 6, 2016 Ok I played around with the pre built and decided I don't really have the time right now to configure everything. Will the wheels and themes from the newer versions work with my old version? I think I'd just like to change it up for now until I have time to start over with the new version
32assassin Posted April 6, 2016 Posted April 6, 2016 Out of curiosity but are you running Hyperlaunch 1 or Hyperlaunch 2? if you are running Hyperlaunch 2 then your life will be much easier. You can keep your current system, Update: Database Media (hold of on the videos if you are using an older version of HS 1.3) Rename your roms to match the latest XMLs Emulators (don't delete your current emulator until you made sure your HL2 module works with the latest emulator version) You can keep your current system as is and yo will not break anything ( you will probably just need to update emulator paths in HyperspinHQ) If or when you are ready to upgrade to the latest version of Hyperspin and RL You can Drag and drop your: Media folder Data Base folder Settings folder into GigaPigs pre built system you will keep all your System Settings. the only ting you will have to do is Configure Rocketlauner
aginc81 Posted April 7, 2016 Author Posted April 7, 2016 Out of curiosity but are you running Hyperlaunch 1 or Hyperlaunch 2? if you are running Hyperlaunch 2 then your life will be much easier. You can keep your current system, Update: Database Media (hold of on the videos if you are using an older version of HS 1.3) Rename your roms to match the latest XMLs Emulators (don't delete your current emulator until you made sure your HL2 module works with the latest emulator version) You can keep your current system as is and yo will not break anything ( you will probably just need to update emulator paths in HyperspinHQ) If or when you are ready to upgrade to the latest version of Hyperspin and RL You can Drag and drop your: Media folder Data Base folder Settings folder into GigaPigs pre built system you will keep all your System Settings. the only ting you will have to do is Configure Rocketlauner Whatever version was out in December 2009. When I click on about, it doesn't show anything. Is there somewhere else to look for the version?
THK Posted April 7, 2016 Posted April 7, 2016 Artwork content hasn't changed except flv is now mp4 (I believe they'll both run on either version but at some point crash HS) ..........................back with a vengeance........................
32assassin Posted April 7, 2016 Posted April 7, 2016 Whatever version was out in December 2009. When I click on about, it doesn't show anything. Is there somewhere else to look for the version? I have no idea when Hyperlaunch 2 was released did you set this up, or did someone set this up for you? they are very distinct set ups, one requires you to modify code for each emulator and compile your Hyperlaunch.AHK the other requires you to download specific pre built modules for each emulator. the more I think about it, you can do what I have described in my previous post even if you are in Hyperlaunch 1 the only problem you will have is with the multi disc systems Hyperlaunch 1 = Disc Name (Disc #) (Region) Hyperlaunch2, hyperlaunch_3, Rocketlauncher =Disc Name (Region) (Disc #) only the naming convention and launching on your multi disc base systems will be broken if you update to the most current databases. (if you are on Hyperlaunch 1) (and you are probably better of keeping your current emulators)
aginc81 Posted April 8, 2016 Author Posted April 8, 2016 I have no idea when Hyperlaunch 2 was released did you set this up, or did someone set this up for you? they are very distinct set ups, one requires you to modify code for each emulator and compile your Hyperlaunch.AHK the other requires you to download specific pre built modules for each emulator. the more I think about it, you can do what I have described in my previous post even if you are in Hyperlaunch 1 the only problem you will have is with the multi disc systems Hyperlaunch 1 = Disc Name (Disc #) (Region) Hyperlaunch2, hyperlaunch_3, Rocketlauncher =Disc Name (Region) (Disc #) only the naming convention and launching on your multi disc base systems will be broken if you update to the most current databases. (if you are on Hyperlaunch 1) (and you are probably better of keeping your current I built the system myself back then. Unfortunately my drive went out earlier today, and I can't find the backups that I had from that time. I guess I will be completely starting over at this point which makes me sick.
gigapig Posted April 8, 2016 Posted April 8, 2016 I built the system myself back then. Unfortunately my drive went out earlier today, and I can't find the backups that I had from that time. I guess I will be completely starting over at this point which makes me sick. Well help is at hand Bro. As you are a platinum member you can get started with the 51 system build from the downloads section. You may need to read the support thread and maybe some guides but all is not lost.
aginc81 Posted April 10, 2016 Author Posted April 10, 2016 Ok so I've been working on this for the past day. Where do I find the wheels and themes to download? Also, I remember that I was able to filter out all of the junk games on MAME and other systems, and only display the good ones, how do I do that? I'll create another thread for help as I go, but I figured I'd reach out on this one real quick.
aginc81 Posted April 10, 2016 Author Posted April 10, 2016 Never mind on the wheels and themes... duh!! The filtering though, please help!
