freezy Posted September 1, 2013 Posted September 1, 2013 So I've been working on something the last few months and I think it's time to announce it here so you guys can take a look at it. Check out pind.ch Not all features are implemented yet but every screenshot is from the real deal, no mockups. I use it on my cab and it saves me a sh**load of time. Feel free to comment here, this is going to be the official thread. The GitHub project can be found here, along with installation instructions here. See also known issues before you submit bugs. Once you get it running, you should probably do the following (in that order) Click on the admin icon on the top right side of the page Fill up the database by: Resync with HyperPin Match with IPDB.org Update High Scores Update Audits [*]Download index from VPF under sources.
djvj Posted September 1, 2013 Posted September 1, 2013 Very cool. I don't have a pincab, but would surely use this if I did. I would like to see support for HS on this in the future. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
mikekim Posted September 1, 2013 Posted September 1, 2013 Looks cool Freezy, will have to give this a try Sent from my GT-N7100 using Tapatalk 4
connorsdad Posted September 1, 2013 Posted September 1, 2013 Awesome, I can see this saving me some time Spent a few hours today installing only 6 tables. So time consuming finding and downloading the tables/flyers/instruction cards/hp video/uvp/wheel art etc etc. Got a long way to go to finish my hyperpin install so this should come in very handy Sent from Amstrad CPC464
matty_g_8 Posted September 1, 2013 Posted September 1, 2013 This look awesome will have to try it out tonight
mameman Posted September 2, 2013 Posted September 2, 2013 Stunning work mate WWW.Xtremepinball.com PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
Dazz Posted September 2, 2013 Posted September 2, 2013 I'm working on installing and checking this out... there are soooo many things that need to be installed, at least 8 different installations required of different softwares. This is a LOT of installing for one program. So far this has taken up about 2.5gb of space on my cabs SSD drive. All of these programs have different installation options. I'm assuming that we just leave all of them at their default settings when installing, correct? I think for Git I selected the option for Windows Command Line. I left everything as default for Node, Python, VC and WinSDK so far. In the directions for installing Node it states "Also, make sure node.exe and npm.cmd are in your PATH (per default atC:\Program Files\nodejs)." Does this mean to just check that file and make sure that those files are in it? In the installation directions for GraphicsMagik; when you say "verify that the installer adds the directory to your PATH." What exactly is the PATH that you are talking about? Ok, I made it to step 5-4, Install Dependancies and getting an error. Please see the attached text. pind_err.txt
MisterB Posted September 2, 2013 Posted September 2, 2013 I managed to get it up and running - starting to play around with it now. I wasn't able to install the dependencies until I added the Python27 directory into my path. Not sure if I missed in installation step along the way, but once I added that in manually, I was able to get though the install process. Really slick interface....looking forward to playing with this!
Dazz Posted September 2, 2013 Posted September 2, 2013 What do you mean by add the directory into your path?
punter1 Posted September 2, 2013 Posted September 2, 2013 Open Control Panel, Open System, Click on Advanced System Settings on left, Click on Environment Variables. In the System Variables section, select Path and click Edit. In the Variable Path field, go to the end and add ";C:\Python27" Don't put the ; if you see one at the end. Click on OK, Click on OK, Click on OK. Open a new cmd window for the change to take effect. you can verify it worked, if you type Python and press enter, and it display the Python version I am still downloading and installing, will see how it goes...
MisterB Posted September 2, 2013 Posted September 2, 2013 I'm referring to the system path used by Windows (http://en.wikipedia.org/wiki/PATH_(variable)). You can view the current path setting in a Command Prompt window by simply typing "path". If you want to add additional directories to that path, you can enter the following into the Command Prompt: SET PATH=%PATH%;<additional directories separated by semicolons here> The above code will append your new directories to the already existing path (that is what the %PATH% variable is for). The only caveat with the above approach is that it only works while your Command Prompt is open. If you close the window, your custom settings will be lost. To make the changes permanent, do the following: - In the Start Menu or Explorer, right-click on Computer and select "Properties". - On the left side of the System Information window, select "Advanced System Settings". - In the System Properties window, select "Environment Variables". - In the System Variables section, scroll down to the "Path" variable. - Double-click on "Path" to edit it. You can view the current directories in the path in the "Variable value" field. If you scroll to the end of it, you can append any additional directories that you need, separated by semicolons. - Once done, close/OK out of all of the windows. - Close any open Command Prompt windows. Next time you open a new one, the new PATH settings will be applied to it. Again, you can verify by typing in the "path" command.
punter1 Posted September 2, 2013 Posted September 2, 2013 Got it running. Nice interface - Will be interested to see how it comes along - thanks for developing and look forward to updates. So far parsed my VP table list, Identified missing media/videos, Lists all cab tables available on VPF. Issues found: Administration-VPF Sources - could not figure out how to sort the tables alphabetically Not able to test ipdb info feature as it crashes on original table not found on ipdb. "Searching at ipdb.org for "El Bueno el Feo el Malo" av can not
freezy Posted September 2, 2013 Author Posted September 2, 2013 I know that the build process sucks. It's basically for the SQLite driver that is used for caching data locally. I'll write up an FAQ soon that explains also how to use MySQL instead of SQLite. Dazz I think GraphicsMagick simply has an option "add to PATH" when installing, that does the process MisterB described for you.
freezy Posted September 2, 2013 Author Posted September 2, 2013 Got it running. Nice interface - Will be interested to see how it comes along - thanks for developing and look forward to updates.So far parsed my VP table list, Identified missing media/videos, Lists all cab tables available on VPF. Issues found: Administration-VPF Sources - could not figure out how to sort the tables alphabetically Well I could add that, however I don't really see the point - search is much faster if you're looking for something specific. Not able to test ipdb info feature as it crashes on original table not found on ipdb. "Searching at ipdb.org for "El Bueno el Feo el Malo" av can not Can you open an issue at GitHub and copy+paste what the console says? I need some more context, specially a stack trace would be useful. Generally, if the type of the game is "OG", it won't search on IPDB.
matty_g_8 Posted September 2, 2013 Posted September 2, 2013 oh ive never installed something like GraphicsMagick from source...is there a easy way to install?
freezy Posted September 2, 2013 Author Posted September 2, 2013 oh ive never installed something like GraphicsMagick from source...is there a easy way to install? There are binary releases.
matty_g_8 Posted September 2, 2013 Posted September 2, 2013 There are binary releases. yeh I did see that after writing the post...almost finished the install cant wait to try it
matty_g_8 Posted September 2, 2013 Posted September 2, 2013 ok after bout 1 1/2 hours of installing I seem to be stuck. I copied the config and renamed to setting-mine. Then edited the settings @ to suit my setup then command node create-schema then node app I open http://localhost and it comes up with pind-a pinball daemon but just shows a grey screen ive attached the log file and pind.db pind.txt pinddb.txt
freezy Posted September 2, 2013 Author Posted September 2, 2013 Which browser? Any error in the Javascript console? Looks like Pind started ok to me.
matty_g_8 Posted September 2, 2013 Posted September 2, 2013 Which browser? Any error in the Javascript console? Looks like Pind started ok to me. internet explorer 8...ill try using chrome... not sure what javascript console is
freezy Posted September 2, 2013 Author Posted September 2, 2013 Yeah I forgot to put that somewhere. Get your hands on a real browser for god's sake. Seriously, I have done a quick test with IE9 I think, but I strongly suggest Firefox or Chrome. In Chrome, press ctrl+shift+i and click on "console". If there's anything red, that would be interesting. I'll update the project page with the browser notice tonight.
matty_g_8 Posted September 2, 2013 Posted September 2, 2013 Yeah I forgot to put that somewhere. Get your hands on a real browser for god's sake. Seriously, I have done a quick test with IE9 I think, but I strongly suggest Firefox or Chrome. In Chrome, press ctrl+shift+i and click on "console". If there's anything red, that would be interesting. I'll update the project page with the browser notice tonight. haha yeh usally I use chrome but on the pincab I always downloaded tables thru the laptop
MisterB Posted September 2, 2013 Posted September 2, 2013 So, I decided to get a little greedy with the app, and restored the default Visual Pinball.xml file that comes with HyperPin, and use it to download the assets of the 50 or so games that are in there. I've run into a couple of situations where the app completely crashes, and I need to restart it. It looks like these errors are not getting handled cleanly, so the error is only thrown in the console, and not in the log file. I'll send along more details as I'm able to recreate them (I also have a VPF media download error that regularly pops up). But here is what I am seeing when trying to update the IPDB data for all of these tables: Again, since the log doesn't capture the error, here is the tail end of the console output: info: ? rpc:5 pind.fetchIpdb info: [announce] "ipdb.processingStarted": {"id":"ipdbsync"} ? event:channels:[admin] ipdb.processingStarted info: SELECT * FROM `tables` WHERE type != 'OG'; info: [announce] "console": {"msg":"Searching for \"Agents 777\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Agents 777" info: [announce] "console": {"msg":"Searching for \"Airborne\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Airborne" info: [announce] "console": {"msg":"Searching for \"Airborne Avenger\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Airborne Avenger" info: [ipdb] Found title "Agents 777" as #26 (distance 0) info: [announce] "console": {"msg":"Searching for \"Alien Star\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Alien Star" info: [ipdb] Found 2 hits for "Airborne Avenger". info: [ipdb] Figured best match is "Airborne Avenger" (33) info: [ipdb] Found title "Airborne Avenger" as #33 (distance 0) info: [announce] "console": {"msg":"Searching for \"Amazon Hunt\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Amazon Hunt" info: [ipdb] Found 17 hits for "Airborne". info: [ipdb] Figured best match is "Airborne" (3783) info: [ipdb] Found title "Airborne" as #3783 (distance 0) info: [announce] "console": {"msg":"Searching for \"Back to the Future\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Back to the Future" info: [ipdb] Found title "Alien Star" as #49 (distance 0) info: [announce] "console": {"msg":"Searching for \"Barracora\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Barracora" info: [ipdb] Found 3 hits for "Barracora". info: [ipdb] Figured best match is "Barracora" (177) info: [ipdb] Found title "Barracora" as #177 (distance 0) info: [announce] "console": {"msg":"Searching for \"Beat The Clock\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Beat The Clock" info: [ipdb] Found 6 hits for "Amazon Hunt". info: [ipdb] Matches are now sorted: name=Amazon Hunt, year=1983, ipdbid=66, distance=0, name=Amazon Hunt, year=1985, ipdbid=5691, distance=0 info: [ipdb] Figured best match is "Amazon Hunt" (66) info: [ipdb] Found title "Amazon Hunt" as #66 (distance 0) info: [announce] "console": {"msg":"Searching for \"Black Belt\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Black Belt" info: [ipdb] Found 2 hits for "Back to the Future". info: [ipdb] Figured best match is "Back to the Future" (126) info: [ipdb] Found title "Back to the Future" as #126 (distance 0) info: [announce] "console": {"msg":"Searching for \"Black Hole\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Black Hole" info: [ipdb] Found 3 hits for "Beat The Clock". info: [ipdb] Matches are now sorted: name=Beat the Clock, year=1985, ipdbid=4518, distance=0, name=Beat the Clock, year=1985, ipdbid=212, distance=0, name=Beat the Clock, year=1963, ipdbid=211, distance=0 info: [ipdb] Figured best match is "Beat the Clock" (4518) info: [ipdb] Found title "Beat the Clock" as #4518 (distance 0) info: [announce] "console": {"msg":"Searching for \"Black Jack Bally 1977 SS \"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Black Jack Bally 1977 SS " info: [ipdb] Found 5 hits for "Black Belt". info: [ipdb] Figured best match is "Black Belt" (303) info: [ipdb] Found title "Black Belt" as #303 (distance 0) info: [announce] "console": {"msg":"Searching for \"Black Knight\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Black Knight" info: [ipdb] Found 14 hits for "Black Hole". info: [ipdb] Matches are now sorted: name=Black Hole, year=1981, ipdbid=307, distance=0, name=Black Hole, year=1980, ipdbid=4087, distance=0 info: [ipdb] Figured best match is "Black Hole" (307) info: [ipdb] Found title "Black Hole" as #307 (distance 0) info: [announce] "console": {"msg":"Searching for \"Black Rose\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Black Rose" warn: [ipdb] Game "Black Jack (Bally 1977 SS)" not found in HTTP body. info: [announce] "console": {"msg":"Searching for \"Bone Busters\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Bone Busters" info: [ipdb] Found title "Black Rose" as #313 (distance 0) info: [announce] "console": {"msg":"Searching for \"Breakshot\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Breakshot" info: [ipdb] Found 2 hits for "Bone Busters". info: [ipdb] Figured best match is "Bone Busters Inc." (347) info: [ipdb] Found title "Bone Busters Inc." as #347 (distance 0) info: [announce] "console": {"msg":"Searching for \"Class of 1812\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Class of 1812" info: [ipdb] Found 9 hits for "Black Knight". info: [ipdb] Figured best match is "Black Knight" (310) info: [ipdb] Found title "Black Knight" as #310 (distance 0) info: [announce] "console": {"msg":"Searching for \"Dolly Parton\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Dolly Parton" info: [ipdb] Found title "Class of 1812" as #528 (distance 0) info: [announce] "console": {"msg":"Searching for \"Eight Ball\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Eight Ball" info: [ipdb] Found 3 hits for "Breakshot". info: [ipdb] Figured best match is "Breakshot" (3784) info: [ipdb] Found title "Breakshot" as #3784 (distance 0) info: [announce] "console": {"msg":"Searching for \"Eight Ball Deluxe\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Eight Ball Deluxe" info: [ipdb] Found title "Dolly Parton" as #698 (distance 0) info: [announce] "console": {"msg":"Searching for \"El Dorado\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "El Dorado" info: [ipdb] Found 9 hits for "Eight Ball Deluxe". info: [ipdb] Matches are now sorted: name=Eight Ball Deluxe, year=1981, ipdbid=762, distance=0, name=Eight Ball Deluxe, year=1984, ipdbid=5021, distance=0 info: [ipdb] Figured best match is "Eight Ball Deluxe" (762) info: [ipdb] Found title "Eight Ball Deluxe" as #762 (distance 0) info: [announce] "console": {"msg":"Searching for \"Elvira and the Party Monsters\"","timeout":30000} ? event:channels:[admin] console info: [ipdb] Searching at ipdb.org for "Elvira and the Party Monsters" info: [ipdb] Found 51 hits for "Eight Ball". TypeError: Cannot read property 'distance' of undefined at findBestMatch (C:\Games\node-pind\server\modules\ipdb.js:500:23) at Request._callback (C:\Games\node-pind\server\modules\ipdb.js:260:16) at Request.self.callback (C:\Games\node-pind\node_modules\request\index.js:148:22) at Request.EventEmitter.emit (events.js:98:17) at Request.<anonymous> (C:\Games\node-pind\node_modules\request\index.js:891:14) at Request.EventEmitter.emit (events.js:117:20) at IncomingMessage.<anonymous> (C:\Games\node-pind\node_modules\request\index.js:842:12) at IncomingMessage.EventEmitter.emit (events.js:117:20) at _stream_readable.js:920:16 at process._tickCallback (node.js:415:13)
freezy Posted September 2, 2013 Author Posted September 2, 2013 Yep, need to find a way to add the stack trace into the log. Thanks for the console dump, will have a look at it. Are those 50 games all recreations? Title matching is actually one of the next big challenges, so far I've only tested it on my ~30 titles I have locally, but with the mass of tables around this will need some improvement.
