Uploaded Hartung Game Master XML/Theme/Wheels/System Intro/Videos
I couldn't resist working on this barely playable crappy system:bird:
Emulate with MESS (Three game as playable so far: Falling Blocks, Hyper Space, and Urban Champion)
Special Thanks to Tattoopete84 for instructions to launch this system in Hyperspin
http://www.hyperspin-fe.com/forum/showthread.php?30319-Boot-MESS-cart-Games-without-HyperLaunch-(in-HS)-amp-Remove-MESS-MAME-nag-screen
XML --> /Upload Here/Floatingyeti/Databases with Genres/Tiger Game.com
Wheels --> /Upload Here/Floatingyeti/Hartung Gamemaster/Wheel
Themes + Main Menu Wheel + INI --> /Upload Here/Floatingyeti/Hartung Gamemaster
Emumovies FTP
Videos --> /Upload Here/Floatingyeti/Hartung Gamemaster/Videos
System Intro --> /Upload Here/Floatingyeti/Hartung Gamemaster/System Intro
  • 3 weeks later...
Er... why wouldn't you just add the console to the MESS module?
It's such a simple process that I set it all up for myself and created an updated module to support it properly that will hopefully be accepted in the official module: http://www.hyperspin-fe.com/forum/showthread.php?26394-Mess-Module&p=291524&viewfull=1#post291524
And yeti, thanks for work of getting everything together for the console. Nice little addition to my wheel. :)
Guys, correct spelling of the system is: Hartung Game Master
So make sure you update your names so the module will work for you. I updated the thread's title, but the rest you need to do.
Also, not a good idea to distribute an ini with roms_only set to true, as HS crashes when entering a wheel and not having the roms or not a valid rom path. This can lead to confusion as to why this is occurring.
Your video doesn't fill the screen in the console window on the main menu theme btw. its cut off and dis-proportioned, which even your screenshots above show that.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Also, please remember that theme zip files should have compression set to Store, otherwise Hypertheme cannot open the zip file.
I'll see what I can do to fix this one up a bit.
EDIT: It's not great, but it's better, also added a little animation to the logo to give it a bit of life.
Download: Hartung Game Master.zip
Thanks zero, much better video. Still feel like the theme is missing something though, what's there looks good, but bland.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I absolutely agree. I went looking for a company logo but the only ones I could find were for other companies that put out the same hardware.
Thanks, I'll give it a shot. Not sure it'll be enough to help this theme though, but it's something.
EDIT: Found a better source for the logo. Took a few of the simplistic graphics and threw them in. The blocks rain down, the shooter hovers slowly horizontally. Looks a lot more lively. Still not great, but hey.
awesome improvements! This is what I hoped would happen when I uploaded these projects.
djvj - I will name everything correctly from now on
zerojay - I will zip themes correctly
I appreciate the module help, I don't know enough to write them
could the theme have blocks and characters falling instead of hovering? Just a random cascade of game characters?
The reason I have the character hovering left and right is kind of to simulate how you would run across him in-game. The blocks do rain down.
I'm not a theme expert, so I couldn't really answer you on the random part.
I made some alterations. The logo seemed to be too distracting center top. I shrank it and left it with a white border instead of box. added a falling "flying" spaceship along with the blocks (has a kind of asteroids feel). took the white opacity down to 65 so it clashes less with the other elements. pulse effect and soldier removed (felt too busy).
better or worse?
uploaded new theme to my ftp folder
  • 3 months later...
[ATTACH=CONFIG]36128[/ATTACH]
[ATTACH=CONFIG]36129[/ATTACH]
[ATTACH=CONFIG]36127[/ATTACH]
Emumovies FTP
unless im blind, i dont see a folder for you at emumovies?
do u still have the videos?
thanks
craig
my videos don't fit the format and standards of emumovies (or a least that's what I assume). My folders been deleted multiple times so I stopped sharing videos. I'm not upset about it, standards are important. I only make videos for myself now.
