Taito Type X Files
gigapig
I was able to basicly set up every game.
except for otemedius. If i want to select the Exe file for that i got a "you got no rights to do that error". So i will have to check that...maybe set as admin or something.
But i got a problem with the other games that you set in your xml and torrent.
I took contra...extracted it....entered it in the launcher menu.
It runs....but on closing the exe file keeps active in task manager. So if i test the game a few times....it won't load cause there are like 5 instances in there.
If all works well i got a screenshot inserted on my settings.
bat file has been changed to make it full screen in stead of windowed. That is the only change i made from the files in your torrent for it. I saw no files for it on your ftp folder like the other games
Any ideas ?
  • Replies 369
[ATTACH=CONFIG]39941[/ATTACH]
Any ideas ?
Contra was self contained and didn't need any additional files. Have you tried a different exit method?
i tried the Exit button i setup ....or if it as a window closing it with the red X in the bar.
restult is the same....it closes but part of it keeps resident as i see in taskmanager
Did you know I meant this? Sorry I should have posted this before.
I'm having an issue with my Bluetooth device not being able to disable it. In Device manager sometimes I can see the "disable" option and sometimes it's not there. I'm using the ASUS BT211 with Microsoft stack, I've also tried the Toshiba stack but the disable option always disappears when I use Toshiba. I've been going around in circles for days trying to find a solution, anybody have any ideas???
Thanks
Thanks
You've been through this I assume?
http://www.hyperspin-fe.com/forum/showthread.php?28587-Taito-Type-X-blutooh-fix-and-resolution-to-dolphin-wiimote-issue
Yeah, that was the reason I got that adapter, cause I thought it would just work, but the script doesn't disable the adapter when the "disable" option is missing in Device Manager...
Any ideas ?
[ATTACH=CONFIG]39947[/ATTACH]
this worked for me, I originally had a "WinClose Aplication"
I was able to load and exit Contra Multiple times and load a game from a different emulator with the Contra exe running.
When I launched Contra the exe would stay in the task bar
I tried all the possible ExitMethods in the drop down menu eventually the "Process Close Application" removed the exe from the task bar.
Try them all and see what works best for you.
OMFG... days of digging and I finally figured it out! :)
I'll post this for anybody who has future issues with the disable Bluetooth scripts.
My Bluetooth keyboard was causing the issue, apparently when you pair a Bluetooth keyboard windows automatically disables the option to disable the Bluetooth adapter in Device Manager.
That's one of the most ridiculous things I've ever tried to troubleshoot...
  • 3 months later...
why this problem? how fix this?[ATTACH=CONFIG]42723[/ATTACH]
lol i fix ... because im not install the xml database x.X now work
Ive got most of the games working now apart from king of fighters XIII which crashes on booting and KOF - Maximum Impact Regulation A, also daemon bride gets flagged up as having a trojan exe and gets deleted by my anti-virus.
And Arcana heart 3 the music plays shortly but then stops.
gigapig you mentioned in your video you found a torrent with the full set on, is there a link to this in the ftp? I cant find it.
Hello friends,
I am back with good news. Last time i popped in to say that Silent Hill had been dumped and emulated. Today I mentioned that Deathsmiles 2 has been dumped and emulated. Sadly this one also requires a bit of configuring. Have fun googling the files and loader. Please no PMs. I will not respond
Here is the english instructions if you are lucky enough to find it.
The game itself comes in two files E: (os) and F: (game). The os goes into your E: drive (make one if you dont have one) and the game goes into your F: drive (make one if you dont have one). placing the files into any other drives will not work
1.find the files
2.Extract the mycv archive
3.Open the folder vspd
4.Install vspdxp_install.exe
5.Launch vspdconfig.exe
6.Set to Port COM1 and COM3 together in the drop down and pair them
7.Deactivate COM1 in Windows Device Manager
launch b.exe
launch cvgame.exe
coin=3
start=1
arrows are d-pad
button 1 and 2 are Z and X
It plays on my win7 64bit but im getting some graphical glitches. I havent tried it on my better pc. hopefully those go away
happy hunting!
Hello friends,
1.find the files
launch b.exe
launch cvgame.exe
coin=3
start=1
arrows are d-pad
happy hunting!
FYI.... A New Playable Loader Based on Romhack's EX-board xb_loader has been released..No need for Vspd
Flood.
Sure thing gents, I may just extract it all and put it all together. It's now the easiest TTX game you've ever tried to get working.
Big thanks to Superrama, Langersld and whoever dumped the game.
Anyone else had problems launching kofXIII in windows 8.1? mine says game.exe stopped working.
Also with Deamon Bride and Arcana heart 3, the music starts but then quickly stops.
I'll send you something for your troubles.
Hello friends,
1.find the files
launch b.exe
launch cvgame.exe
coin=3
start=1
arrows are d-pad
happy hunting!
Thanks for the heads up. A side from it being a little glitchy it's a pretty fun game. With all the goings on you barely notice it!!
