New Unified Megatheme - Other systems
KlopjerO
I can't animate it with the limited 120 frames HS gives me.
Not sure I'm understanding you, but there is no frame limit to Hyperspin.
I'd like to have a look at the background. I'll gladly help animating.
  • Replies 374
wait,what ?! I tried that once but after 120 frames it would just freeze and then when it completed the animation it would play the first 120 again. Anyway I'll look up wich quote this was and ..wait.. I'll throw all my PSDs on the FTP.
I've never experienced this and a lot of themes are way past the 120 mark. Might be a misunderstanding. We usually tell people to set flash to run at 120 frames per second (which is max) because it's the closest resemblance to how HS animates it. Although truly it's all performance based and different from PC to PC.
its clearly flash causing the issue you need a good pc for the latest flash i to have problems with my themes sometimes it works and sometimes they freeze up unless you move the cursor is there a way to turn off the mouse cursor in hyperspin
sig.png 100%
Well maybe I have been using flash wrong, what I usualy do is import the PSD in flash, keep my layers editable, convert the bitmaps that I want to animate to Objects(F8) set a keyframe (usualy at 120) make a Motion tween and start to go about my business.
You can't really do anything wrong as long as you keep things simple. I'll have a look at the background if it's available on the FTP now.
thanks guys!
How about Sega Naomi? I know a couple people have said they were working on it, but I'd be excited to see it since it's the only one I need for mt setup. lol
Yes...my whole life revolves around making themes for people on the net that I've never met.
I have the main theme done but I don't have the system setup on my PC and from the videos, there are some games at 4:3, some at 16:9 and some vertical, meaning you need game specific themes to accommodate the different video sizes. I've been working a lot of late hours at work this past month so I haven't had any time to work on this, and lets be honest, after spending the whole day in front of a computer, the last thing I want to do at home is be in front of a computer again.
Have you tried making one? It's quite easy.
Why would it be any different than the ones done for say, Atomiswave? There are vertical games for that system as well (not sure about aspect ratios). I've tried making one myself, but don't have the programs to be able to do it.
hi bro, i think Naomi theme can be required alternative characters (guilty gear, canon spike, capcom...). And maybe change one chars by an official Cabinet? and a panel? That could be a good idea?
Post some of those pics below ashu, give me something to work with :) make them hi-res and transparent if possible... Yes I'm lazy :) I had Sega skeet shoot cab earlier but I thought it looked absolutely crap...
What do you think about this? Bro
Not a 16:9 Version!
Are any of these themes available now? Thanks for any answer - and GREAT job. I love the obscure stuff and you have really given it a shine!
Thanks
The ones I tested can be found on the ftp Upload here\unified megatheme\themes\submissions folder so you might want to bring a ball gag ;)
Not a 16:9 Version!
Usable, where ca n Ifind this theme so I can cannibalize it.
Do you want psd file? or finished zip theme?
Psd file Upload in /Upload Here/Ashurax/klopjero/!
Maybe I gonna make another theme in this style for atomiswave.
I was searching for cave themes and I read that THK had made a render of those fancy white plasticy cabs.. maybe I can do something with those
Two exemples of new Atomiswave main theme.
Cabinet need some redraw!
Maybe incrust the video on the cab
Or like this?
Final Naomi Theme!
Animated backgrounds could be a good thing!
I always liked the original AAE theme
Thank you. I personally always thought it was just OK
I like it. Hard system to work with. Increase the size of the title though :)
+1 +1 +1
