nate67000 Posted February 22, 2017 Posted February 22, 2017 Mame64 v0.183 no nag screen View File **Reported as having issues, unconfirmed. Any problems please report with specific details** Here is mame64 v0.183 "no nag screen" enjoy Submitter nate67000 Submitted 02/22/2017 Category Other Credits 6
robmcc83 Posted February 26, 2017 Posted February 26, 2017 Hi, Do i just extract and use this or do i need to replace the exe from the original mame binary. Thanks
defiance187 Posted March 21, 2017 Posted March 21, 2017 Mame just crashes when I use this exe. I'm on win10. any ideas?
Guest Posted March 22, 2017 Posted March 22, 2017 Are you guys downloading be official MAME download then replacing the exe with this one? The other components need to be up to date too.Sent from my iPhone using Tapatalk
joe35car Posted March 22, 2017 Posted March 22, 2017 I use and have the official MAME64 .183 and would replace the exe with yours and it crashes. Never launches.
Guest Posted March 22, 2017 Posted March 22, 2017 I use and have the official MAME64 .183 and would replace the exe with yours and it crashes. Never launches.mame.ini recreated and set correctly? Does MAME open outside of RL/HS?Sent from my iPhone using Tapatalk
joe35car Posted March 22, 2017 Posted March 22, 2017 I can't even create a new MAME ini in command line. Just crashes. Won't launch a game in command line or even open when double clicking on the MAME exe to try and get to the built in ui. You might have to create a new MAME but just wait til next week when the new release is out. I appreciate these builds.
Turranius Posted March 22, 2017 Posted March 22, 2017 Crashes for me to. Very strange error. I did move everything to a different drive to be sure that was not it. Faulting application name: mame64.exe, version: 0.183.0.0, time stamp: 0x58ce946d Faulting module name: mame64.exe, version: 0.183.0.0, time stamp: 0x58ce946d Exception code: 0xc000001d Fault offset: 0x00000000032c6d20 Faulting process ID: 0x17f4 Faulting application start time: 0x01d2a33ad65f1e2d Faulting application path: C:\Temp\MAME\mame64.exe Faulting module path: C:\Temp\MAME\mame64.exe Report ID: 5ec07e00-13cf-4adc-a787-11352f54dda3 Faulting package full name: Faulting package-relative application ID: ----------- Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program Multiple Arcade Machine Emulator because of this error. Program: Multiple Arcade Machine Emulator File: The error value is listed in the Additional Data section. User Action 1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again. 2. If the file still cannot be accessed and - It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted. - It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer. 3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER. 4. If the problem persists, restore the file from a backup copy. 5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance. Additional Data Error value: 00000000 Disk type: 0 1 Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
vaderag Posted March 28, 2017 Posted March 28, 2017 I'm also getting a crash. No error just window crash and searching for issue. Win 10 Latest standard version works no issues...
Create an account
Register a new accountSign in
Sign In Now
