MazeNblue Posted April 3, 2017 Posted April 3, 2017 Is there anyway to have hyperspin run two .exe'a on launch? I already am launching hypersearch through hyperhq, but need to also add xpaader to launch on hs start because it's the only way I can get HS to recognize it. I see there is an hyperapin.ini in the HS\Settings folder that could be edited, but I have been unsuccessfully trying to do so. Thanks everyone! Sent from my SAMSUNG-SM-G928A using Tapatalk
Suhrvivor Posted April 3, 2017 Posted April 3, 2017 I use HSBezel for that (and for mixing themes with different aspect ratio).
Bungles Posted April 6, 2017 Posted April 6, 2017 You could have it launch a batch (.bat) file perhaps which in turn launches as many things as you need. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
MazeNblue Posted April 6, 2017 Author Posted April 6, 2017 That's a great idea...now I just need to figure out how to write a batch file. But I think your suggestion will workSent from my SAMSUNG-SM-G928A using Tapatalk
Bungles Posted April 6, 2017 Posted April 6, 2017 Quote You could have it launch a batch (.bat) file perhaps which in turn launches as many things as you need. This page explains how to use the START command in a .bat file to run exe files. Its pretty straight forward. http://www.computerhope.com/issues/ch001345.htm Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
MazeNblue Posted April 6, 2017 Author Posted April 6, 2017 Thanks so much Bungles!Sent from my SAMSUNG-SM-G928A using Tapatalk
Metalzoic Posted April 6, 2017 Posted April 6, 2017 You could also use Tur-Volume controller which can control the launch of HyperSpin, plus timed launches of as many other apps as you want.
MazeNblue Posted April 7, 2017 Author Posted April 7, 2017 I ended up making a batch file and pointing HS start up to it...works great! Thanks everyoneSent from my SAMSUNG-SM-G928A using Tapatalk
MajorWeirdo Posted May 24, 2019 Posted May 24, 2019 On 4/3/2017 at 10:29 PM, MazeNblue said: Is there anyway to have hyperspin run two .exe'a on launch? I already am launching hypersearch through hyperhq, but need to also add xpaader to launch on hs start because it's the only way I can get HS to recognize it. I see there is an hyperapin.ini in the HS\Settings folder that could be edited, but I have been unsuccessfully trying to do so. Thanks everyone! Sent from my SAMSUNG-SM-G928A using Tapatalk How did you manage to run HyperSearch through HyperHQ, did you make it a wheel then? On 4/6/2017 at 3:43 PM, Bungles said: This page explains how to use the START command in a .bat file to run exe files. Its pretty straight forward. http://www.computerhope.com/issues/ch001345.htm If I follow this, I would create a .bat file to run the exe files of xpadder, hypersearch and hyperspin, but where do I put this file ? In my hyperspin folder and how would my cabinet know when to launch that said .bat file?
MajorWeirdo Posted May 24, 2019 Posted May 24, 2019 @cataclysm67 that is awesome, thank you! I wil give it a go!
griffin518 Posted May 24, 2019 Posted May 24, 2019 40 minutes ago, MajorWeirdo said: @cataclysm67 that is awesome, thank you! I wil give it a go! Seriously, though... check out Tur-Volume: It's a fantastic program that I think is a must use for anyone running HyperSpin (or any front end, for that matter). It'll do what you're looking for and much more. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
MajorWeirdo Posted May 24, 2019 Posted May 24, 2019 @griffin518 And that has the startup functionalities ? I thought you misspelled or misplaced the link because of the name of the program 'Tur-Volume' I will have a look at it. Thanks for the response.
griffin518 Posted May 24, 2019 Posted May 24, 2019 1 hour ago, MajorWeirdo said: @griffin518 And that has the startup functionalities ? I thought you misspelled or misplaced the link because of the name of the program 'Tur-Volume' I will have a look at it. Thanks for the response. It's just a long name that I can never remember or want to spell out completely. Yes, it has terrific startup functionalities. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
