Honosuseri Posted August 2, 2018 Posted August 2, 2018 19 minutes ago, thatman84 said: On the compat sheet theres a note in the cell by the other guy saying it crashed on loading inventory in Broken Sword II. You move the cursor to the very bottom of the screen and it brings up the items in your inventory to select and use. I've not played through the game completely but seems a ok to me. I experienced no crashes "There is so much more and beckons me. To look through to these, infinite possibilities..."
kylecp1979 Posted August 2, 2018 Posted August 2, 2018 It was the Hyperspin Android Base Pack 1.1 I was trying to use the ini from
thatman84 Posted August 2, 2018 Author Posted August 2, 2018 1 hour ago, kylecp1979 said: It was the Hyperspin Android Base Pack 1.1 I was trying to use the ini from Good to know. That base pack needs a revisit I think there is an issue with mame also....I was inexperienced when I done that Please comment on the file if poss so I remember when the time comes Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted August 3, 2018 Posted August 3, 2018 8 hours ago, thatman84 said: Good to know. That base pack needs a revisit I think there is an issue with mame also....I was inexperienced when I done that I think some members would be surprised to know you're relatively new to this emulation game. What you've achieved speaks volumes for what people can do if they put a little effort in my friend! Doing a base pack is ambitious. We have different preferences to what emulators to use and what systems we want to play. Updates can mean the ini files need editing over time which doesn't help. Might be better to "advertise" it as a stepping stone rather than a base pack. "Noobz" do need to understand there is tweaking and maintenance in store for them when taking on this hobby. It's not really a plug and play situation "There is so much more and beckons me. To look through to these, infinite possibilities..."
Yorkie88 Posted October 1, 2018 Posted October 1, 2018 Thanks for the guide on this, im brand new to hyperspin but I've got the games running now...... which I wouldn't have been able to do without your guides @thatman84 (and the others too!) I put the games in sub-folders as per the links to keep it neat, but I can't get the box art to display. I've downloaded the 3d ones from here and put those in the Media/ScummVM/Images/Artwork1/<gamename>/<gamename>.png I've tried using Artwork1 and Artwork3, i read something about it using the numbers to layer images up. Do need to use a specific subfolder (1/2/3/4) or is it because I'm missing a config file somewhere that would tell it which to use? Cheers!
Spawk Posted October 2, 2018 Posted October 2, 2018 Which artwork folder to use is dependant on what the theme for that system is setup for... ie: the theme creator could have arbitrarily used any one of the four for boxart.I would just try each folder till they show up. I guess its also possible the theme was created without any boxart in mind.Sent from my SM-A520W using Tapatalk
Honosuseri Posted October 2, 2018 Posted October 2, 2018 17 hours ago, Yorkie88 said: Thanks for the guide on this, im brand new to hyperspin but I've got the games running now...... which I wouldn't have been able to do without your guides @thatman84 (and the others too!) I put the games in sub-folders as per the links to keep it neat, but I can't get the box art to display. I've downloaded the 3d ones from here and put those in the Media/ScummVM/Images/Artwork1/<gamename>/<gamename>.png I've tried using Artwork1 and Artwork3, i read something about it using the numbers to layer images up. Do need to use a specific subfolder (1/2/3/4) or is it because I'm missing a config file somewhere that would tell it which to use? Cheers! If you're using the unique themes for each game the box art won't show. I used the box art media as the wheel art instead which works very well. All the best, glad we helped you out! "There is so much more and beckons me. To look through to these, infinite possibilities..."
Yorkie88 Posted October 2, 2018 Posted October 2, 2018 The issue was that I didn't have a system theme but I got the box art working by changing a default.zip file I found in the downloads section (added an Artwork3 line with a right aligned position), but it doesn't look great.......I can play around with it a bit now that I know where the files sit I might also see if I can find some game specific themes to try out, do packs exist for this? I don't have that many games so won't be too big of a task if they need to be done individually, and I'll probably remove/comment out any missing games from the database file to tidy it up a bit. Cheers!
Honosuseri Posted December 3, 2018 Posted December 3, 2018 On 10/2/2018 at 11:23 PM, Yorkie88 said: I might also see if I can find some game specific themes to try out, do packs exist for this? I don't have that many games so won't be too big of a task if they need to be done individually, and I'll probably remove/comment out any missing games from the database file to tidy it up a bit. Cheers! That's exactly what needs to be done. As you have to set the ini file to "roms only=false". It will put everything that's listed in the xml database file on the ScummVM wheel. Keep your original "full game list xml" , I'd just rename it. Then name your "favourite games xml" you make, to be used in it's place. You can see my setup in the video below, I had this done long before the guide. I intended to only do a few classic games too BUT I got carried away with it "There is so much more and beckons me. To look through to these, infinite possibilities..."
