Cocktail cab themes
Bill-
the theme art is already rotated, so there is no need to use irotate to rotate windows itself. Just rotating the monitor physically from horiz to vert. The game rotation is taken care of in with altering the mame settings.
You are probably right with the rotation of my monitor, again since I didn't use an existing arcade screen, it was a 50/50 shot which way to rotate it. And the the 40% diff in size is probably some guessing I was taking on sizing things with the resolution before I thought that HS would scale it. Gimme a little time and I will just do a full sized version and you can see how it scales it down and rotate it the other direction for you.
The game and wheel info can be removed manually in the settings file. Open it in a text editor and down toward the bottom you'll find the [Game text] section.
Change....game_text_active from =true to =false
that should remove it.
  • Replies 1.4k
Thanks for the info. I'll try and edit the settings manually.
The only reason I mentioned irotate is because vert support is a very requested feature of this front end. If u use that it works vertically pretty easily it seems.
No rush on redoing stuff. I am gonna try the cocktail one soon hopefully and see how that looks as well
Thanks again!
Bill
Ok, up on the ftp, in my folder i put a folder with your name, in it is a new default.zip theme, along with the same artwork2 and artwork4 folders with new adjusted artwork. It's all rotated the opposite direction then mine so shouldn't be upside down. Didn't do anything with the wheel images since I wanted to see if these changes work.
If they do work i'll post up the .psd files so you can resize any marquees and flyers you want for your cab.
Actually dudes I haven't tested the cocktail themes on my mini pacman cab yet.
I guess I'm too lazy to adjust all the settings and resize all the artwork to 480x640.
And yeah, 640x480 is an interlaced resolution on a standard 15KHz monitor, but it's still clear.
For sure a progressive (non interlaced) resolution of 384x288 would be better for the eye in terms of image stability but it would maybe give a too much low resolution for the theme art, imo.
But It definitley needs to be tested, and compared to 640x480 (480i). So, 288p or 480i ?
"Dindon" means "Turkey" in french.
Man do you mean you have resized all the theme down to fit a 384x288 res ?
Cool, I think I'll give up my lazyness tonight and give it a try.
I hate to burst your bubble but actually not really. In essence I did a default type theme that just swaps out resized marquee images and flyers. It's a little more static like the one you put together earlier.
So EvilD, when you tried it before did you leave HS at 1024x768 @ fullscreen and just let it scale everything down? Thats why the first shot at this lower rez theme I sized down, but evidently the artwork doesn't fit??
**making my brain hurt, i hate not having something to test on**
Oh i see.
No I haven't tested any vertical setup on my cab yet.
Maybe I'll test your excellent cocktail cab themes first by letting HS doing the 1024 to 640 downscale itself (when my FTP account will work again ...), and wait for HS 2.0 to work seriously on my vertical 640x480 theme set.
Contra...
gotta give credit to aabra, used the artwork he cut out in the normal theme. Was having trouble finding some that wasn't total crap.
picture.php?albumid=157&pictureid=3132
**This CPO really isn't that correct. The button labeling and color is right, but all I saw were either flat black overlays, or a jungle motive that was from the USA flyer. So i kinda went a little rogue on this one.
Gunsmoke, this was cool to do. Credit to EvilDindon, i used a few pieces of artwork that he already expertly trimmed out for his theme. Traced out the paneling to give the background some more content.
Finished it out by adding a small romstar/capcom logo at top middle, just above the screen. (after i uploaded this pic)
picture.php?albumid=157&pictureid=3149
hmm...could have something to do that you created the wheel as a main menu item instead of a sub-wheel? I'll try to mess around with it, haven't had this prob yet.
Not sure. I'll have to mess with it some this weekend. Where would I check that setting at?
Bill
Hehe cool, Gunsmoke rocks !
Some suggestions for your next themes : :)
- Mad Planets (gottlieb)
- Circus Charlie (Konami)
- Pooyan (Konami/stern)
- Nibbler (Rock-ola)
- Commando (capcom)
- Gaplus (namco)
- Cyvern
- APB (Atari)
- Toobin' (Atari)
- Punch Out ! (nintendo)
- Super Punch Out ! (nintendo)
- Arm Wrestling (nintendo)
- Vanguard (SNK)
- Astro Blaster
- Zaxxon (Sega)
Hi! Guys maybe you can help me out i am trying to set up the vertical cocktail program and i have to be doing something wrong, i used hyper hq and created a new wheel (vertical Cocktail) and used the sub menu way that added all the folders, i followed the instructions i put all the stuff from jeepguy81 folders in the hyperspin vertical cocktail folders i set up and when i open hyper spin i get Cannot Find Vertical Cocktail.XML what have i done wrong any help you all can give would be great. Thank You
You muste duplicate your mame.xml in the database/mame folder to the database/cocktail folder and renaime it cocktail.xml
Thank You EvilDindon for the info i did what you said and it worked perfect. @ Jeepguy81 Thank You for creating this theme it is awesome great job! one more question do i use the same videos that i have been using from the horzontal hyperspin that i have been using for months now or is there a set that was made for the Vetical game themes.
Thanks Again
Phew, finally got Toobin done. Used some pics of the side art for references and just kinda changed it as i went. Spent allot of time in Illy on this one.
picture.php?albumid=157&pictureid=3180
Overall I think it turned out pretty fun. I might slide that Atari logo to center and shrink just a tad.
Thank You Jeepguy81 i used the videos and they worked great, one more question i put my emulator program in the hyperspin and set up the paths in hyperQ but when i run the program and start a game i get a error saying (missing rom extension in vertical cocktail.ini) my wheel was created and named Vertical Cocktail so i am missing somethimg to allow the games to start any ideas? Thank You
Ok i went back in and i saw what you were saying, the box was blank so i added the zip, now what i get when i try to start a game is (vertical cocktail is a invalid system name or mame.exe isnt supported yet) am i using the wrong mame i have the mame141b and using windows 7 64 bit. now when i had the original hyperspin setup using the mame wheel it all worked fine so some where i am not doing or changing something. any more help would greatly be apreciated. Thanks for all the help so far.
