reko19 Posted March 22, 2011 Posted March 22, 2011 Gave it a try last night. Fplaunch works well for me, no task bar or any other undesired behavior. Did not play long enough to see if my "pause" issue still there. Tested big boss functionality. Had no issues launching certain tables with vp908, while my vpinball.exe was 9.12. After that I decided to keep 9.08 as my base vpinball.exe and have only certain tables load with 9.12 since there is only a handful of new tables available. That is when I got into troubles. I only tried it with the roadshow, but it would not load just stays on rendering table screen. Did not try other tables, planning to do it today. Great performance overall, thank you for this great update.
blur Posted March 22, 2011 Posted March 22, 2011 do you have exe name in vp908tables file? that's new and diff. from big boss script. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted March 22, 2011 Posted March 22, 2011 Yes, my vp911tables.txt looks like this: Roadshow_VP911_1.0FS vpinball912.exe and it works just fine when I was trying vp908tables.txt with TOTAN_VP9_3.0FS vpinball908.exe i'll play with it some more to see if it is only a problem with the RS
blur Posted March 22, 2011 Posted March 22, 2011 file has to be named vp908tables.txt inside that file you can have different exe names like this: Roadshow_VP911_1.0FS vpinball912.exe TOTAN_VP9_3.0FS vpinball908.exe and so on. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted March 24, 2011 Posted March 24, 2011 Installed latest beta. Works great. The added Big Boss code is great. I can now play Who Dunnit! Thank you! Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
blur Posted March 24, 2011 Posted March 24, 2011 great, tnx i've added some info to fplaunch manual - in the second post of this thread new info is added in download links and version history, install guide is pretty much unchanged My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted March 26, 2011 Posted March 26, 2011 Blur, everything works as a charm, huge thank you for this update
mandelbloom Posted March 27, 2011 Posted March 27, 2011 (edited) anyone have an issue when exit Future Pinball tables the hyperpin is "frozen". Doesnt seem like future pin exits properly. However VP does fine. Edit - Never mind I needed to disable the exit in the FP program itself Edited March 28, 2011 by mandelbloom
bent98 Posted March 28, 2011 Posted March 28, 2011 Blur Works awsome for me also. Thats for adding code to by pass vpinmame error. Thanks for all your hard work on this. I do have a question for you. I still have esc mapped in my ipac and in exit emulator. I am not having any issues. Should I remap it to e or o like you say or just leave well enough alone?
blur Posted March 28, 2011 Posted March 28, 2011 if it works leave it as it is some controllers have this problem that ahk can't stop esc key (or any other key) on others ahk normally stops all keys and vp never gets esc My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
reko19 Posted March 29, 2011 Posted March 29, 2011 how does the high score functionality works? is it for VP or FP only? thanks guys
treveism Posted March 29, 2011 Posted March 29, 2011 Thank you Blur! The new code works great, and I'm now able to play all of my tables without issues! I'm also someone that had issues exiting with the Esc key, so mapping it to "e" did the trick for me. I'm running Win 7 64 bit if that makes a difference?
blur Posted March 29, 2011 Posted March 29, 2011 great treveism, tnx for info reko high scores work only in fp, they are shown during pause because fp shows them vp doesn't have this feature My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
firefoxian Posted March 31, 2011 Posted March 31, 2011 upload to download section of site so this code does not get lost in the jumble.
DedroK_V Posted April 7, 2011 Posted April 7, 2011 Blur, when it loads the vp908 table, the table loads but it is the HP preview of the table. I also hit Alt f4 to check the vp version, but it closes when i hit play again. The VP912 stuff still works fine. There was somethin else strange that i cant remember, so i'll have to check it again on the weekend. I'm using XP.
DedroK_V Posted April 10, 2011 Posted April 10, 2011 Blur, when it loads the vp908 table, the table loads but it is the HP preview of the table. I also hit Alt f4 to check the vp version, but it closes when i hit play again. The VP912 stuff still works fine. There was somethin else strange that i cant remember, so i'll have to check it again on the weekend. I'm using XP. OK, All working fine. Didn't have the .exe after the version in the vp908table settings file. Sopranos FS vpinball908 Due to the fact that i have known files extensions hidden, and copy / paste everything, small oversight on my part. It did however lock up HP upon restarting the table after minimising with Alt f4 with the vp908 table.
bent98 Posted April 10, 2011 Posted April 10, 2011 Blur Did you add big boss slam it big score support?
blur Posted April 12, 2011 Posted April 12, 2011 (edited) ups, i missed this questions bent: nope, big score support is not in the fplaunch dedrok: alt-f4 is specially programed key in fplaunch and it should: - close vp/fp player - show cursor - show taskbar - show vp/fp editor - suspend all ahk hot keys - wait for you to finish editing and start vp/fp player again to hide everything again so if you do alt-f4 on a table and then close vp/fp editor instead of pressing play you will freeze HP cause there will be ahk script active waiting for vp/fp player, you can kill this ahk script in taskbar and then hp will continue maybe, maybe i can find a way for HP to not freeze. maybe i can wait in one thread for player to appear and in other for editor to close, and in first case continue with ahk and in the second case kill ahk Edited April 12, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
gwjrabbit Posted April 12, 2011 Posted April 12, 2011 blurCan you please add it? What I really want (while we're asking for ponies and unicorns), is the ability to launch Mame games out of Hyperpin (grin).
lstrunk Posted April 12, 2011 Posted April 12, 2011 Why not use hyperspin. Works great for mame Lonnie
gwjrabbit Posted April 13, 2011 Posted April 13, 2011 What I'm looking for is a frontend that lets me run 10 or so mame games, and segues seamlessly to launching hyperpin to play pinball (the 90% use of the cab). Yes, Spin works great on my Mame cabinet. I'm looking for something integrated. More to the point -- I have this working now in my cab (the fplaunch mod), and it works AWESOME, but it doesn't seem to kill UVP on UVP tables when I exit. I only use UVP on certain pre-DMD tables to render the scores, and on those few DMD tables that use it informatively (Dr. Who), but it just doesn't quit. Any ideas?
gwjrabbit Posted April 13, 2011 Posted April 13, 2011 Another hour or so tinkering, and I've kind of given up. I can make it work, but not with UVP. With the old fashioned hyperlaunch, I just added "Joy8" to the top of the file for exit and everythign works, without having to involve AHK or Joy2Key or anything. Seems like whatever the old script does for exiting, the new script should be able to do too, but I'm just not smart enough to figure it out. I really appreciate the work you've put into this, and I hope at some point I either have a keyboard mapper that works right for it (like an iPac) or someone smarter than me figures out how to make it work with the nanotech board without a dozen hoops. Thanks again for all the effort and support.
Create an account
Register a new accountSign in
Sign In Now
