Acet Posted June 26, 2020 Posted June 26, 2020 Hi all, hope someone can help me. I'm trying to set up Retroarch with the core ScummVM with Hyperspin. I followed this guide , but am stuck on a few points. 1. Where do I create my game folders? I put them in Hyperspin/Emulators/ScummVM/roms. Is this OK? 2. Where do the media folders go? E.g. Day of the Tentacle, do I put the media folder in Hyperspin/Media/tentacle? Or do I have a media folder inside the folder where I put my rom? 3. None of the media I've saved in the standard Media path currently shows up on the wheel, I'm assuming that's because the XML file has the "game/folder" structure in place, so fixing 2 will fix this? 4. I couldn't edit the settings in Retroarch for ScummVM (rom path etc) is this needed, or will the games launch anyway? They seem to work fine when I manually select the *.scummvm file 5. Finally this guide is pretty old, so is there a newer/better way to do this? Perhaps using the ScummVM apk instead of Retroarch? Thanks in advance for any help.
dark13 Posted June 26, 2020 Posted June 26, 2020 There's a bug in official RA module with scummVM, backup your RA ahk and try this one https://www.dropbox.com/s/ho93nf4vl0nguwb/Retroarch.ahk?dl=0 Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
Acet Posted June 26, 2020 Author Posted June 26, 2020 OK I'm still struggling with this. I fixed my Media issue, I just had to put sub-folders in all the Media folders for each game and move their files into it. The Wheel now works fine, but when I try to launch a game I get "warning trying to launch missing rom". By the way, these games all run directly in Retroarch when selecting the *.scummvm file. If I go through one game as an example, maybe that will show what I'm doing wrong? Let's take Curse of Monkey Island. I've got my Database file: ScummVM.xml as follows (using the folder/game structure as eplained in the guide): <?xml version="1.0"?> <menu> <header> <listname>ScummVM</listname> <lastlistupdate>05/07/2018</lastlistupdate> <listversion>2.0</listversion> <exporterversion>HyperList XML Exporter Version 1.3 Copywrite (c) 2009-2011 William Strong</exporterversion> </header> <game name="comi/comi" index="" image=""> <description>Curse of Monkey Island, The (CD Windows)</description> <cloneof></cloneof> <crc></crc> <manufacturer>LucasArts</manufacturer> <year>1997</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> </game> My Settings file, ScummVM.ini set up as below: [exe info] path=H:\hyperspin\emulators\ScummVM\ rompath=Roms/ScummVM/ userompath=true exe=com.retroarch.ra32/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=scummvm Parameters=cores/scummvm_libretro_android.so searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true [filters] parents_only=false themes_only=false wheels_only=false roms_only=false My Game image is located inside this folder: Hyperspin>Emulators>ScummVM>comi> Inside the "comi" folder, I have the comi.scummvm file, this has one line "comi" dark13, you comment, is this for Android? I can't see where I'd put this file. Do you have a guide or a quick link on what to do please? 7 hours ago, dark13 said: There's a bug in official RA module with scummVM, backup your RA ahk and try this one https://www.dropbox.com/s/ho93nf4vl0nguwb/Retroarch.ahk?dl=0
Honosuseri Posted June 26, 2020 Posted June 26, 2020 ahk files are for Rocketlauncher which is the backbone of Hyperspin on PC. You've posted in the right part of the forum but sometimes forum members don't notice it's an Android related topic. The ScummVM android app didn't support launch intent for Frontend support, I doubt that's changed. We use the "folder trick" for this system, each game has it's own folder with it's game files and a scummvm file inside. I can see that's been used from your scummVM.xml file (e.g comi/comi). The knock on effect is that all media (including theme zips) have to be in a named folder for each category (e.g wheel & video) for it to be found. There's free software called "Files 2 Folder" that can easily do this for you, taking multiple files, naming folders after them and then moving each file into it's own folder. Your rom path looks wrong to me from what you stated in the first post and what's in your comi example. Remember we have "roms_only=false" in the ini file when using the folder trick, so the games show even if the rom path is incorrect. [exe info] path= rompath=/storage/emulated/0/Hyperspin/Roms/ScummVM/ userompath=true exe=com.retroarch.ra32/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=scummvm parameters=cores/scummvm_libretro_android.so searchsubfolders=false pcgame=false winstate=NORMAL hyperlaunch=true That's my .ini file. In the ScummVM folder there is a comi folder with the game files and the scummvm file (comi is written on first line) "There is so much more and beckons me. To look through to these, infinite possibilities..."
thatman84 Posted June 26, 2020 Posted June 26, 2020 11 hours ago, Acet said: 1. Where do I create my game folders? I put them in Hyperspin/Emulators/ScummVM/roms. Is this OK? As @Honosuseri said your rompath looks incorrect, hence the error of hyperspin saying it cannot find them 2 hours ago, Acet said: rompath=Roms/ScummVM So this line in the ScummVM.ini should be rompath=Emulators/ScummVM/roms Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Acet Posted June 26, 2020 Author Posted June 26, 2020 Honosuseri, once again thank you! I was literally thinking (whilst munching on my sandwich at lunch, strange how this little project is taking over my free time!) about what I did on the Daphne emulator (using your video guide), where I had to put the actual path for the drive, rather than "path=H:\hyperspin\emulators\". Once I've got access to my device, I'll make the tweak.
Honosuseri Posted June 26, 2020 Posted June 26, 2020 Just now, Acet said: Honosuseri, once again thank you! I was literally thinking (whilst munching on my sandwich at lunch, strange how this little project is taking over my free time!) about what I did on the Daphne emulator (using your video guide), where I had to put the actual path for the drive, rather than "path=H:\hyperspin\emulators\". Once I've got access to my device, I'll make the tweak. We ignore the path line on Android just double check your rom path. Easy mistake to make, I don't feel I need to state the obvious as you sussed out getting this to work over your NAS. I have tested ScummVM with RA_32 and my modded Hyperspin.apk. The games do play fine, all the best with it. "There is so much more and beckons me. To look through to these, infinite possibilities..."
Acet Posted June 27, 2020 Author Posted June 27, 2020 Thanks, all working now. Also had issues with day of the Tentacle sound crackling, so just used the Mac sound file and all good now. I've spent so long fixing my Hyperspin I've not played any games. Time for a break from set ups. Will be back shortly to work on my next emulator. Any suggestions for tricky ones to look at, I like the challenge...
sanchezmike01 Posted June 30, 2020 Posted June 30, 2020 On 6/27/2020 at 12:44 PM, Acet said: Thanks, all working now. Also had issues with day of the Tentacle sound crackling, so just used the Mac sound file and all good now. I've spent so long fixing my Hyperspin I've not played any games. Time for a break from set ups. Will be back shortly to work on my next emulator. Any suggestions for tricky ones to look at, I like the challenge... Ms dos will take the most time....mess (old computer systems) are also fully compatible as long as the drivers are working for mame up to 0.197...this includes systems that dont have a hash XML like sony pocketstation or sega svm...command line will be your friend so u wont need to rename any roms
sanchezmike01 Posted June 30, 2020 Posted June 30, 2020 Day of the tentacle for msdos, u can go to the 2nd floor and on the PC play manic mansion...scummvm version doesn't allow that
Honosuseri Posted July 1, 2020 Posted July 1, 2020 On 6/27/2020 at 5:44 PM, Acet said: Thanks, all working now. Also had issues with day of the Tentacle sound crackling, so just used the Mac sound file and all good now. I've spent so long fixing my Hyperspin I've not played any games. Time for a break from set ups. Will be back shortly to work on my next emulator. Any suggestions for tricky ones to look at, I like the challenge... I did PM you warning you about the sound in some Lucasarts games, glad to hear you're done with ScummVM. My advice would be not to fall in the trap of trying to have so many wheels. You'll see guys bragging they have 300+ wheels BUT I guarantee most of them are a mess and not complete or just "garbage games" that nobody would actually want to play. Personally I focus on systems/games I enjoy or my family and friends adore, I do them and I do them well. I do love ScummVM so if you see my YT video showcase, all the games have their own theme and I used boxart for the wheel to make it look a little different. For me quality is better than quantity but each to their own. MS-DOS I wouldn't say is tricky, just a P.I.A and time consuming much like the Amiga was before the PUAE core made life easier on us all. I'd rather be playing games than setting up wheels for Hyperspin, as silly as that sounds from a guy who took on sorting out the Amiga and it's media with 3000+ games! All the best with it, enjoy your break "There is so much more and beckons me. To look through to these, infinite possibilities..."
Chewyspin Posted June 15, 2021 Posted June 15, 2021 On 6/25/2020 at 7:47 PM, dark13 said: There's a bug in official RA module with scummVM, backup your RA ahk and try this one https://www.dropbox.com/s/ho93nf4vl0nguwb/Retroarch.ahk?dl=0 Thanks a lot. It works great for me.
