dmark468 Posted April 2 Posted April 2 50 minutes ago, jgkings said: Hello, I'm not a native English speaker, so my writing might not be perfect. In any case, you can right-click and select "Translate" if needed; it's not complicated. Regarding my previous response, I meant that before installing the mentioned update, HyperSpin wasn’t working. After installing it, it worked for a few days, but then suddenly stopped working. I decided to uninstall the update, and after doing so, HyperSpin started working again. So far, that has been the definitive solution. However, I will continue testing future updates to see if anything changes. I figured, but the thing is that translating added another layer of uncertainty about what you wrote. Google or whatever you use can easily screw up the meaning, so I just wanted your English take on this. Thanks!
rik81 Posted April 2 Posted April 2 Heard a report that the lastest update hyperspin started working again? Anybody confirm this is true? Not working on my side.
jesfknkrys Posted April 2 Posted April 2 I'm just updated my laptop from Windows 10 to Windows 11(24h2). Hyperspin was running fine on Windows 11(24h2) until it took update (KB5053598). I believe there will be a lot more updates to be blocked. I'm assuming Windows 11 is requiring a digital signature from Hyperspin to run. Problematic update(s) on Windows 11(24h2) Uninstall the below update(s): KB5053598 KB5053656 Installed the Microsoft Show or Hide Updates Troubleshooter(link below) and hide the updates to avoid auto installation. https://download.microsoft.com/download/f/2/2/f22d5fdb-59cd-4275-8c95-1be17bf70b21/wushowhide.diagcab 3
jesfknkrys Posted April 8 Posted April 8 @Agard Windows 11 is working as long as you don't intsatll the above mentioned updates.
Agard Posted April 8 Posted April 8 @jesfknkrys Someone said a clean install of windows 11 / pro that you have to update everything first then start HyperSpin is that still true ? if not do you know the exact copy of windows 11 to install e.g. Windows 11 Pro 23H2 Build 22631.3296
jesfknkrys Posted April 8 Posted April 8 I will try updating all latest Windows 11 and report back tomorrow 2
jesfknkrys Posted April 9 Posted April 9 I just tested Windows 11 again. Here is the outcome Windows 11 23h2 - WORKING Windows 11 24h2 - WORKING, minus the updates I mentioned above. Windows 11 24h2 - NOT WORKING, if all updates are up to date. Windows Error Received: Faulting application name: HyperSpin.exe, version: 1.5.1.0, time stamp: 0x5aec9b23 Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc0000005 Fault offset: 0x734235a4 Faulting process id: 0x1EC8 Faulting application start time: 0x1DBA984E7A10728 Faulting application path: D:\Hyperspin\HyperSpin.exe Faulting module path: unknown Report Id: bdace66b-746c-45bb-8ab8-ba8a16cb1a54 Faulting package full name: Faulting package-relative application ID: Fault bucket 1969799237737599578, type 1 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: P1: HyperSpin.exe P2: 1.5.1.0 P3: 5aec9b23 P4: StackHash_38d9 P5: 0.0.0.0 P6: 00000000 P7: c0000005 P8: PCH_BC_FROM_ntdll+0x00079B4C P9: P10: Attached files: \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.a35079c7-a212-49f7-be61-831697570aa5.tmp.mdmp \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.1b6e4432-ccae-4d02-8963-f81da3220ed2.tmp.WERInternalMetadata.xml WPR_initiated_DiagTrackMiniLogger_OneTrace_User_Logger_20240808_1_EC_0_inject.etl \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.b9a347fc-3405-4219-8058-fede7137b2a1.tmp.etl WPR_initiated_DiagTrackMiniLogger_WPR System Collector_inject.etl \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.41b8766e-8b65-4d80-adf6-cbf0d59fae3c.tmp.etl \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.5038d84f-ee18-45c7-b196-679b67fe92c3.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.012b58da-ed8f-47f5-b9ff-9f7dad2a9738.tmp.txt \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.afa578bb-3bb8-4abe-8dcf-9846809a8b4b.tmp.xml These files may be available here: \\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_HyperSpin.exe_175bb5e6274229b21fd285aa81e12c607761b3_1556631f_8ed45617-f933-4243-aced-95e0a5df342d Analysis symbol: Rechecking for solution: 0 Report Id: 92523cdc-d4c4-409f-ac9c-27ce05e9f01b Report Status: 268435456 Hashed bucket: c97b09a748859aac8b5621f8642f525a 1 1
baddeolv Posted 10 hours ago Posted 10 hours ago 1 Beer Me! Instagram : baddeolv Kik : baddeolv Facebook : Brian Addeo www.facebook.com/thecorepunk
