11 hours ago, Roadrunner said:
Awesome. I have the themes and will export them into PNG files. I will put them together this week. I'll start with the Marvel group and send that then follow it up with the Star Wars and then Zen. That work for you or would you rather have everything at once?
As you prefer. Like @Bungles said, the script is just a call to a folder, and it will convert to squeezed swf everything inside of that location that has a png extension, so if it is one zip file with 200 pngs, or 10 zips with 20 pngs, I dont mind; I leave the script running in the background.
I have a ver good internet connection, so its up to you whether you rather send me multiple small files, or a big file.
I normally use wetransfer.com, as they let you send up to 2GB free in one take,
Just a quick update: i added PNG_to_SWF_Wheel_Only_Scripts download on the first page.
Hyperspin 1.5 now support .swf wheel, you can use those script to massively convert .png wheelset image to .swf wheelset image with smooth flag enabled. Basically I just set the stage to 1*1 and did some math to get the image on the correct position. I did just a quick test and it worked as wheel .swf images were correctly centered, let me know if you have problems with it (yeah, i suck at math lol)
Once again, thanks to dark13 for putting this together. I can't use the scripts myself but Kondorito was kind enough to convert my files for me so I was able to put together the Pinball FX2 themes in widescreen. Thanks guys.
Hello Dark13 I really like the png to swf no scale smooth script, but everytime i use it it breaks my animations!? Im using flash CS6 its breaking pixelate? Please help its driving me crazy.  Thanks in advance!
Some animations and swf files don't function, not sure why but it is what it is.
If you want specific animations in hyper theme you might have to do them via your swf animation or go back to png for that artwork file.
Hi guys, I've used these scripts several times before with no issues but all of a sudden Flash is crashing whenever I try to run them on my Mac and on my PC Flash gives the error "TypeError: bmp_lib has no properties. Any ideas?
Quote
Have you changed your Flash version? Is it happening with any png file you are converting?
I don’t think I have, I’m on CS6. I also tried with a png file I’ve used before but same error. I’m going to see if I can get a hold of Flash CC.
Strange, because I have CS6 and I have no problems with it.
Have you installed another Adobe program lately? Maybe some of their common/shared files are giving you problems.
I do not know about that error though. Maybe @dark13 knows how to go about it.
I installed a fresh copy of flash on another PC that has never had any adobe products installed and got the same error ?
Weird. Share with me the pngs you are trying to convert and I will test them tomorrow on my Flash.
I installed Adobe Animate CC 2017 and it works with that!
  • 9 months later...
16 minutes ago, adamgp said:
Does anyone still have these scripts please? All previous links seems dead.
It seems there are problems downloading stuff from the board, added a dropbox link in the first post
  • Like 3
2 hours ago, Krakerman said:
FYI ... This script has error when loading into Adobe Animate PNG_to_SWF_Zero_Dreams_1920x1080_to_1024x768
Will check tomorrow, is the problem related only to that script?
Yeah soon as it launches Adobe Animate it comes up with a window that describes why it crashed.
Ok, new dropbox link, now it works.
  • 9 months later...
Hola amigos, ¿alguien sabe como cambiar el aspect ratio de 4:3 a 16:9 en un archivo SWF?.
Hello friends, does anyone know how to change the aspect ratio from 4: 3 to 16: 9 in a SWF file ?. Thx
Load the swf in animate cc/flash pro and from the library select the image and "modify in photoshop", save the image as .png then run the script to make it a swf with ratio correction
Hello again dark13, thanks for responding so quickly. Forgive me because yesterday I asked the question wrong. I have some Sega 32X boxes with movement in SWF 4: 3 format and what I want is to move it to SWF 16: 9. Thank you so much.
Example.swf
I'm thinking of starting to convert all Nintendo game themes from 4:3 to 16:9. Just Wonder if this is already done by someone and want to share it?
The Atari 2600 themes should already been converted but can't find them, Mega link is boken.
Are people still using SWF's? Or are you using video files instead.. Heard that it was the new thing ;)
  • 11 months later...
Hi, I want to create themes in 1080. I've seen that the solution is to create them in 1080 in Photoshop. Then give it to resize image within photoshop to 1024x768 and save it as png. And then the internet videos say to pass him the script of PNG_to_SWF_dark13_NO_SCALE_SMOOTH
Is this really the best option so you don't lose quality?
I also want to test with 4k, although I'd most surely use cinematic videos for this. But with a 4k image can I use the same script or will it have no effect?
Thank you.
Hola, quiero crear temas en 1080. He visto que la solución es crearlos en 1080 en Photoshop. A continuación, dale para cambiar el tamaño de la imagen dentro de photoshop a 1024x768 y guardarlo como png. Y luego los videos de internet dicen que le pasan el script de PNG_to_SWF_dark13_NO_SCALE_SMOOTH
¿Realmente esta es la mejor opción para que no pierda calidad?
También quiero hacer pruebas con 4k, aunque lo mas seguro que usase videos cinemáticos para esto. ¿Pero con una imagen 4k puedo usar el mismo script o no tendrá efecto?
Gracias.
