ericleroi Posted December 5, 2014 Author Posted December 5, 2014 Cut the main window for accessing the inlays: Made some pieces for the side pods (this will bring the total width to around 89mm): And did a test fit of the LED cluster which will sit on the downward facing rear slope of the side pods:
rfancella Posted December 5, 2014 Posted December 5, 2014 Beautiful! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
ericleroi Posted December 6, 2014 Author Posted December 6, 2014 Still working on the support structures and perimeter pieces but a bit of a diversion with the vinyl:
ericleroi Posted December 6, 2014 Author Posted December 6, 2014 I've cut enough perimeter pieces and supporting blocks to start gluing things together. The remaining blocks will be straight cuts rather than angled ones so are much simpler. I will will need to apply the glue to the pieces in 2 passes. I will complete the left pod first and then start on the right pod. The screws have been countersunk to enable them to be screwed (and glued) into the outward face once everything is ready. There will be more pieces to accept the HOTAS poles and also an additional brace running across the centre. I have also cut the hole for the Neutrik USB connector in the top panel:
ericleroi Posted December 7, 2014 Author Posted December 7, 2014 That looks like complete garbage, once you finish it up you should just go ahead and ship it here to the US to get it as far away from your sights as possible. I will even give you my address so it can be stored away to not bear the burden of it being seen by others. I dread to think how much this thing would cost to ship to the US With the glue having dried overnight, I dry assembled the left side pod. It's not perfect but I'm pretty pleased with it: I still have to put the mounting poles in place. These will slide in and out of the side pods to make the HOTAS removable. The main side piece shown in the picture will sit about 3 inches lower. The platform sitting on the poles (4mm aluminium plate which was ordered yesterday) will raise the HOTAS by 2-3 inches from the top surface of the side pods. I'll need to experiment to get the position correct:
mikekim Posted December 7, 2014 Posted December 7, 2014 one thing looking at this... i would have thought that the throttle would be mounted lower (flush with the top of the side pod) as it would probably be ergonomically better. and one more thing... damn you.. you got me looking into picking up a HOTAS now - Elite might just start taking over what little time I have available..
ericleroi Posted December 7, 2014 Author Posted December 7, 2014 Hey mikekim, glad you're getting interested Good spot - someone else commented on the height of the throttle on another forum. The whole seat will be raised by about 3 inches so the pods will sit lower than it will shown here. The approximate position of the top of the pod relative to the front of the seat is about this: I also finished cutting the perimeter pieces for the second pod:
ericleroi Posted December 7, 2014 Author Posted December 7, 2014 Rinse and repeat for the second pod. Support blocks hand cut with holes drilled for the screws. LED and Neutric holes also drilled:
ericleroi Posted December 8, 2014 Author Posted December 8, 2014 More progress and a better view of the fit:
maxxsinner Posted December 8, 2014 Posted December 8, 2014 Another brilliant build ericleroi I assume you have played Elite in the Oculus DK2 already to be building this? Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
Hyperion Posted December 8, 2014 Posted December 8, 2014 Freaking love it. My first cocktail cab: The Hyper Arcade Entertainment System Win 7 64bit | i5 3570K Overclocked to 4.2GHz | 16GB 1600MHz DDR3 | GTX 970 Strix | Samsung 250GB 840 Evo SSD + 8x4TB green drives in RAID 5 for XBMC/KODI
ericleroi Posted December 9, 2014 Author Posted December 9, 2014 I don't have the Rift at the moment maxxsinner - it's absolutely on the wishlist. New graphics card to buy first though as my 680 died on me. Thanks Hyperion! I adjusted the main sides pieces. I wasn't happy with the shape or height. I can drop the pods by a few cm now. I also adjusted the angle on the front to line up with the side pods. Arrows show where it's been modified: Before: After: I also cloned the side pieces: Tops are over-cut at the moment.
mikekim Posted December 9, 2014 Posted December 9, 2014 I assume you have played Elite in the Oculus DK2 already to be building this? damn you maxx.. I've just watched the rift demo... more expense...
Agrajag Posted December 10, 2014 Posted December 10, 2014 Eric, is your 680 still under warranty? You might be able to get your money back. I burned out a 660ti using Folding@Home, returned it to Dabs and have been promised a refund as the model is no longer available (although they seem to be having trouble actually getting the money back onto my credit card). HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
ericleroi Posted December 10, 2014 Author Posted December 10, 2014 Eric, is your 680 still under warranty? You might be able to get your money back. I burned out a 660ti using Folding@Home, returned it to Dabs and have been promised a refund as the model is no longer available (although they seem to be having trouble actually getting the money back onto my credit card). It's out of warranty unfortunately The artwork arrived an I mounted it behind some acrylic:
maxxsinner Posted December 11, 2014 Posted December 11, 2014 That looks brilliant! Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
ericleroi Posted December 11, 2014 Author Posted December 11, 2014 Cheers maxx Draw everything up, drill access holes, rough cut the insides, cut and attach the guides and flush trim. Things are going well. How wrong could I be ... Aaaaaarrrrrrrrrgggggghhhhhhh. The window is massively overcut, extending down to the side pod. Options: a. Stuff it and carry on b. Do it again I did it again, correctly: I'm glad I did.
ericleroi Posted December 11, 2014 Author Posted December 11, 2014 I've routed the inside bevels on the windows and also inserts for both the mesh and the aluminium bars which are now fitted: I still need to cut the bars for the other side. I'm almost out of mesh - just enough for one side - so will have to order some more of that.
ericleroi Posted December 12, 2014 Author Posted December 12, 2014 I completed the vinyl backing and mesh on the right hand side window:
Hyperion Posted December 12, 2014 Posted December 12, 2014 I feel like scrapping my Batmobile project and making one of these with a dash and wheel that slides into place in front of it. Could even make it motorised... (abruptly walks away muttering excitedly). My first cocktail cab: The Hyper Arcade Entertainment System Win 7 64bit | i5 3570K Overclocked to 4.2GHz | 16GB 1600MHz DDR3 | GTX 970 Strix | Samsung 250GB 840 Evo SSD + 8x4TB green drives in RAID 5 for XBMC/KODI
ericleroi Posted December 13, 2014 Author Posted December 13, 2014 A motorised version would be very cool indeed - I wish I knew more about that kind of stuff. I'll have to look into it some day soon.
ericleroi Posted December 13, 2014 Author Posted December 13, 2014 Dry assembling is going slowly but well: I use some very large batons and 6cm screws for the connection into the base. This structure isn't going to shift or creak:
ericleroi Posted December 13, 2014 Author Posted December 13, 2014 That's me done for today. Just a couple of batons I needed to complete but I will do those tomorrow: The seat raiser will need to be re-cut. It's too wide.
ericleroi Posted December 14, 2014 Author Posted December 14, 2014 You are gonna sit on a hump? It's been re-cut and re-covered now. I've made the first blanking panel for the front of the seat. Shaped the pieces: Applied some craft foam to provide an amount of give and also to round off the edges: Covered with material: In-place:
