Beaps Posted March 4, 2012 Posted March 4, 2012 Hi all, Can someone knock me up the latest version of MAME, no nag please Dos MAME & MAMEUI Ta! RELAX and just have fun!! Remember, it's all about the games.
Mr Black Arm Posted March 4, 2012 Posted March 4, 2012 http://headsoft.com.au/index.php?category=mame&page=mc64 Ridiculously easy.
Beaps Posted March 4, 2012 Author Posted March 4, 2012 I know, I always mess it tho. If someone can post me a mediafile link I would appriciate it RELAX and just have fun!! Remember, it's all about the games.
pomme Posted March 4, 2012 Posted March 4, 2012 I think that's actually against the forum rules. I've seen people ask in other threads and have the links removed. What kind of problems are you having when you compile? Maybe someone can fire off a quick fix if you get stuck. Time Waster (2010), Donkey Kong (2011), Defender (2012)
Drkdweller Posted March 5, 2012 Posted March 5, 2012 its against the rules of mame as well, not just here.
Beaps Posted March 8, 2012 Author Posted March 8, 2012 This is there I am getting... src/osd/windows/video.c:257: error: redefinition of 'void windows_osd_interface::update_hi(bool)' src/osd/windows/video.c:235: error: 'virtual void windows_osd_interface::update_hi(bool)' previously defined here make: *** [obj/windows/osd/windows/video.o] Error 1 RELAX and just have fun!! Remember, it's all about the games.
chunksin Posted March 8, 2012 Posted March 8, 2012 Hi, Keep your eye on this thread: http://www.hyperspin-fe.com/forum/showthread.php?t=14925 - I used version 1 and compiled different versions with no problems. Version 2 is promised shortly ... cheers, Rich
mclarkin9681 Posted May 16, 2013 Posted May 16, 2013 Just curious how long it should take to apply patches? Following the above instructions using lastes files, and the first diff file (0148u1.diff) i apply has been running for about 10 min...is that normal?
MontyQ Posted May 16, 2013 Posted May 16, 2013 Just curious how long it should take to apply patches? Following the above instructions using lastes files, and the first diff file (0148u1.diff) i apply has been running for about 10 min...is that normal? ya its normal I ran it on 2 vertex 4 SSDs in Raid0 and it took 10 minutes or so, if your on a normal hdd could be 30-40 minutes
mclarkin9681 Posted May 17, 2013 Posted May 17, 2013 I am indeed on normal HD...thanks for the reply.
MontyQ Posted May 19, 2013 Posted May 19, 2013 I am indeed on normal HD...thanks for the reply. no problem, takes ages as it seems to compile like tens of thousands of files lol
jeracoo Posted February 15, 2014 Posted February 15, 2014 Thanks Polemicist, though managed to get it working via this french mame compiler called MCAS.
Polemicist Posted February 15, 2014 Posted February 15, 2014 Google it or if you have Gold member or higher here goto Jumpstile's FTP folder.
alcoatjez Posted February 16, 2014 Posted February 16, 2014 its against the rules of mame as well, not just here. I don't think so. You only have to include the source if you distribute a binary. Verstuurd vanaf mijn GT-I9300 met Tapatalk
ninja2bceen Posted September 19, 2014 Posted September 19, 2014 Google it or if you have Gold member or higher here goto Jumpstile's FTP folder. Hi, I found a no nag exe, what do I do with it now? Grant it I still have to 7z it, I assume it will create all sorts of folders and essentially replace the folder location of original mame? Do I need to extract the new in the old folder? Also how do I turn on high score? I found mame ui fx 149 Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Polemicist Posted September 19, 2014 Posted September 19, 2014 Install Mame normally. Run it make it work. Put your new Mame exe in the folder. Now run that exe. That's pretty much it.
ninja2bceen Posted September 19, 2014 Posted September 19, 2014 Thanks. Ill just drop the new exe in my current mame folder. How do I activate high scores? I have the dat already Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Polemicist Posted September 20, 2014 Posted September 20, 2014 If your exe supports high scores that's pretty much it. As for normal dat high score support you find those instructions on the official site for it.
ninja2bceen Posted September 21, 2014 Posted September 21, 2014 Thanks I got it to work Is it worth downloading aae and cave? Do they use the same roms as mame, I think I'm reading they do? Where can I find the cave emulator? I have a compiled version of mame no nag and cave but I don't know how to tap the cave part :-) help?! Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Agrajag Posted September 22, 2014 Posted September 22, 2014 AAE is not really worth the hassle as the same ROMs are used by MAME. Somewhere on the forum there are some suggested HLSL settings to reproduce the vector glow that you get in AAE. You don't need anything other than plain vanilla MAME to play the Cave games since support was reinstated in version 0.154,. You can either just find them in the MAME wheel or set up a separate Cave wheel with its own XML file and use MAME as the emulator. Sent from my phone using Tapatalk, probably while at work... HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
albert_c Posted September 22, 2014 Posted September 22, 2014 If you ever need a new version of MAME with no-nag and high scores, just get GroovyMAME. GroovyMAME also has code in it for better A/V sync and improved latency. You will have create/edit the mame.ini file to enable the 'disable_nagscreen_patch' and 'disable_loading_patch' but that is no big deal. I can't see how there is ever any value in using the UI version of MAME in that we are launching games with HyperSpin anyway but to each his own. Since GroovyMAME is an offshoot of MAME, no one ever gets upset about pointing to it thus the MAME Team's wishes against distribution of custom MAME compiles aren't violated, which is cool. I can confirm that the Cave shooters play great on GroovyMAME 1.54. Also, I like these HLSL settings for play on my IPS monitor (Mushishimisama looks great with these settings!). Just makes sure you also enable 'multithreading' so you don't get dropped frames. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
