Yet another feature rich Hyperspin rom & media manager
xttx
  • Replies 170
Thanks for your help!! Problem is solved. I just checked the last cue file and the quotations was missing in the name inside the cue file Example: Supreme Warrior (USA) (Disc 1).bin instead of "Supreme Warrior (USA) (Disc 1).bin"
The log is very useful. Thanks a lot!! Looking forward to future releases!
This tool was really useful for me in cleaning out my old artwork after HyperSync, and also in renaming several ROMS. Thanks for creating it!
Hi, this tool is amazing! Great work and thank you for sharing!
I tested it out on my TG16 CD collection and it helped me clean it up to match the XML databases expectations, however I noticed a possible bug. When associating and renaming bin|iso/cue files the decimal separator for the extension ISO is left off on both the renamed ISO file and its reference with in the .CUE files.
Example of change:
Exile (USA).cue
Exile (USA)ISO
Should be:
Exile (USA).cue
Exile (USA).ISO
Is this something I'm doing wrong or is this a bug ?
I'm using the latest release posted in the thread, 002u3.
Thanks!
aupton,
I can not reproduce the error :(
Please, can you provide a simple step-by-step example of how it can be reproduced, and fullpath to cue/iso with filenames?
xttx, Thanks for checking into this futher. Here's the details below. Please let me know if you need any more info:
Original Filenames and full path =
"G:\CONSOLES\NEC\NEC PC-Engine CD\[LOAD]\Ai_Chou_Aniki_(NTSC-J)_[NSCD5018].cue"
"G:\CONSOLES\NEC\NEC PC-Engine CD\[LOAD]\Ai_Chou_Aniki_(NTSC-J)_[NSCD5018].iso"
Original .cue ISO definition =
FILE "AI_CHOU_ANIKI_(NTSC-J)_[NSCD5018].ISO" BINARY
G: = Mounted SMB share.
Steps:
1) launch the "HyperspinChecker.exe"
2) Select "NEC PC Engine-CD"
3) Check/Enable "Program Settings/always use HS VideopPath"
4) rename just .cue = disabled/unchecked
5) Summary/Check
6) Matcher/roms
7) Locate and associate XML given name to filename.
Post-Association Filenames and full path =
"G:\CONSOLES\NEC\NEC PC-Engine CD\[LOAD]\Ai Chou Aniki (Japan).cue
"G:\CONSOLES\NEC\NEC PC-Engine CD\[LOAD]\Ai Chou Aniki (Japan)ISO"
Post-ASsociation .cue ISO definition =
FILE "Ai Chou Aniki (Japan)ISO" BINARY
Wow!!! I tried this program and it is really good. I spent hours and hours associating files with the official databases and then I found this very helpfull tool. Just only one request. Could you extend the list of categories to associate? I mean, sound files (playing at the background while watching the themes) and theme packs (the zip or rar files with all the artworks) can not be associated. Could it be possible?
xttx, looks like I may have found another bug. When selecting "Move unneeded roms or media to subfolder" the app thows a JIT error.
I'm using Windows 7 x86_64 and I am up to date on system patches.
Please let me know if you need any other information.
Thank you,
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at WindowsApplication1.Form1.contextMenuMoveRoms(Object sender, ToolStripItemClickedEventArgs e) in F:\Documents\My_Progs\HyperspinChecker\Form1.vb:line 1301
at System.Windows.Forms.ToolStrip.OnItemClicked(ToolStripItemClickedEventArgs e)
at System.Windows.Forms.ToolStripDropDown.OnItemClicked(ToolStripItemClickedEventArgs e)
at System.Windows.Forms.ToolStrip.HandleItemClick(ToolStripItem dismissingItem)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
HyperspinChecker
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/HyperSpin/HyperspinChecker/HyperspinChecker.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.0.30319.1001 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
zero dreams
Request filled. You can delete entrys from HS DB now.
http://80.240.211.12/HyperspinChecker_bin_0.002u5.rar
Well, I don't know if I did it right: i'm creating backup only the first time you delete something, because I thing this button will be used multiple times in a row to delete "from this to that", and in this case you will find yourself with dozens of backups :) Correct me if I did it wrong.
flames
Sure, will add sounds and themes (can they really be in .rar??? I didn't know :/)
aupton,
tested with Amiga2600 roms and Sega Saturn images in subfoldered mode. Can't get this error.
Please, can you say, as usual:
- path to rom folder, and if they are in subfolders
- what need to be done to get this error (if something else ten just select system, check, and click 'move unneeded to...')
jejeje, you are right. most of the sound files are .mp3 jejeje you got me! I said this for theme packs. They use to be like .zip files but i do not know if they can be used as .rar files. Jejeje. Great! I think .... (this is an irony) You create the beast to match all my roms with the databases. In fact, I had my machine a side until I saw your program. This helps us a lot. Long live to hyperspin with hyperspin checker!!!! I think ... (a gain? I am thinking too much this night). This program gives me strenght to go through my roms and match them with the databases. Artwork and sound files too. I will dive into them ...
Sorry guys, the app is hosted on my webserver just because I don't know where to host it elsewhere :(
I can't attach it to post here, and I can't find good filehosting service.
The link is fixed now, but it would be great if I can host it somewhere else, to avoid it in the future.
Update:
The last version is attached to first post in this thread now!
I couldn't attach it because it was in .rar. But it allows .zip, and i didn't know it :)
