Steam Wheel Creator
pietie
  • Replies 239
  • 4 weeks later...
Hey true believers
I get the following error
2018-11-24 19:56:58
System.NullReferenceException: Object reference not set to an instance of an object.
   at SteamWheelCreator.CreateNewSteamWheel.<>c__DisplayClass13.<PrePruneList>b__d() in c:\00-Work\Projects\HyperSpinClone\SteamWheelCreator\CreateNewSteamWheel.xaml.cs:line 317
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   at System.Windows.Window.ShowHelper(Object booleanBox)
   at System.Windows.Window.Show()
   at System.Windows.Window.ShowDialog()
   at SteamWheelCreator.CreateNewSteamWheel.ShowDialog(SWCProject currentProject) in c:\00-Work\Projects\HyperSpinClone\SteamWheelCreator\CreateNewSteamWheel.xaml.cs:line 77
   at SteamWheelCreator.MainWindow.updateWheel_Click(Object sender, RoutedEventArgs e) in c:\00-Work\Projects\HyperSpinClone\SteamWheelCreator\MainWindow.xaml.cs:line 695
can someone help?
I've not used it in a long time but one thing I remember is getting an error if you don't already have a Steam xml to write to.
Well i was able  to use this program properly about 6 mothns ago and now i cant. So my guess is that it is probably broken. Is anybody able to use it?
  • 1 month later...
Nope- I get "The request was aborted: Could not create SSL/TLS secure channe...."
It also worked for me about 5 months ago.  I suspect it is Steam using HTTPS ?
This program worked absolutely beautifully- when it worked- please fix man!!
  • 2 months later...
I am experiencing the same issues today and it also worked for me a few months ago. Is this tool still being actively supported? Last update I see on the download here was 2015?
  • 5 months later...
  • 2 months later...
  • 1 month later...
On 11/11/2019 at 9:48 PM, CiscoStu said:
no one working on this anymore? it is such a great tool to go to waste like this....
I have revisited SWC as there have been forum members trying to use it recently, but unfortunately it does fail upon fetch.
I think that was the problem that PieTie encountered with it when he tried the update it
The Hyperspin Report writer/editor <br />resident grouch, Hyperspin facebook modorator<br />for those who want to read my work <br /><a href='http://thehyperspinreport.blogspot.co.uk' class='bbc_url' title='External link' rel='nofollow external'>http://thehyperspinreport.blogspot.co.uk</a>
  • 4 weeks later...
