sevenseal Posted October 12, 2015 Posted October 12, 2015 Altough I am a hyperspin noob (<Month) I figured out a solution for this just now. I extended my displays as i normally do so in the monitor settings it was to the right of monitor 1. I launched a game in fullscreen just now from rocketlauncher and noticed it threw a piece of the rocketlauncher program onto the 2nd monitor (It pushes to the right). So I went into the display settings and was able to put the 2nd monitor above monitor 1. I then moved the hyper marquee into the new window and launched HS. Now it works perfectly ! I assume some systems push things to the right or left when they are launched because they don't fit on the desktop anymore but now that my marquee is on top it don't matter anymore.glad your problem was solved
subwyking Posted October 13, 2015 Posted October 13, 2015 Is there a possibility of themes containing .swf graphics being supported in a future release? Thanks Russ Sent from my iPhone using Tapatalk
sevenseal Posted October 13, 2015 Posted October 13, 2015 lol my son like post #602, i didnt do on my behalf
Antos Posted October 13, 2015 Author Posted October 13, 2015 lol my son like post #602, i didnt do on my behalf Yeah right sevenseal! I like that post too! The only problem is that I have spent hours trying to find a way doing this with .net without success (HM coded in .Net). There are a lot of plausible ways but none of them are conclusive. My last option so far is to create (convert) new themes with .mp4 or .flv instead of .swf, which is a relative 'big' price to pay. Anybody ready to pay that price? if the answer is yes, then I maybe write a converter (not real time) and read modified themes. NB: Transparency is also an issue since .net doesn't support alpha blending videos. (i can do a transparency key, but not as nice as using alpha channel) Users to let me know. HyperMarquee & Event Dispatch System
sevenseal Posted October 13, 2015 Posted October 13, 2015 see that like of your post was on purpose... but probably need to do some more r&d on that for the project
subwyking Posted October 14, 2015 Posted October 14, 2015 I'm not trying to stir up trouble! Only providing feedback. I wish I knew enough about coding to be of help. But sadly I don't. I'm glad you guys already have the gears turning on a way to make it work. I can't thank you enough for the gem of an application you've already provided. Thanks Russ Sent from my iPhone using Tapatalk
danwelsh Posted November 10, 2015 Posted November 10, 2015 Hi, I'm having trouble getting this to work.....i'm running the latest version of HS and rocketlauncher, windows 8.1 and the latest version of hypermarquee. I setup EDS and HM as per instructions and videos but it isn't working, what I was getting is the game screen itself flashing on the other monitor for about 1 second then disappearing.....hypermarquee isn't showing up whatsoever..... I'm lovin my arcade
Reefboi16 Posted November 10, 2015 Posted November 10, 2015 Is it possible to use HM, in pair with hyper speech,eds,and LED Blinky? The reason i ask is i see you rename some files to a fake LEDBlinky. I already did that for hyper speech so how would i get HM and EDS to work?
ninja2bceen Posted November 10, 2015 Posted November 10, 2015 Hyperspeech does work well in 1.4 at least the bios dont Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
sevenseal Posted November 10, 2015 Posted November 10, 2015 all work together just what ninja2bceen said is the bug due to hyperspeech needs to be updated Is it possible to use HM, in pair with hyper speech,eds,and LED Blinky? The reason i ask is i see you rename some files to a fake LEDBlinky. I already did that for hyper speech so how would i get HM and EDS to work?
sevenseal Posted November 10, 2015 Posted November 10, 2015 Hi, I'm having trouble getting this to work.....i'm running the latest version of HS and rocketlauncher, windows 8.1 and the latest version of hypermarquee. I setup EDS and HM as per instructions and videos but it isn't working, what I was getting is the game screen itself flashing on the other monitor for about 1 second then disappearing.....hypermarquee isn't showing up whatsoever.....could paste the code of your eds setting here? and please provide the names of the labels you used in hypermarquee
danwelsh Posted November 10, 2015 Posted November 10, 2015 my eds setting application=hyper marquee ipc method=pipe(cli) parameters= false MAME-Marquee_Artwork [game] [system] pipe id= MAME-Marquee_Artwork Event Filter 1,3,9 Close Filter 2,4,6,11 labels for Hypermarquee is MAME-Marquee_Artwork Hope you can help me get this going I've been nonstop working on it since last night.....you're more than welcome to do remote assistance if you would like. Also, when I click try in EDS....HM does not appear so I obviously have something wrong I'm lovin my arcade
sevenseal Posted November 10, 2015 Posted November 10, 2015 my eds setting application=hyper marquee ipc method=pipe(cli) parameters= false MAME-Marquee_Artwork [game] [system] pipe id= MAME-Marquee_Artwork Event Filter 1,3,9 Close Filter 2,4,6,11 labels for Hypermarquee is MAME-Marquee_Artwork Hope you can help me get this going I've been nonstop working on it since last night.....you're more than welcome to do remote assistance if you would like. i am fine doing rremote assist if you want, just pm your info
sevenseal Posted November 10, 2015 Posted November 10, 2015 parameters= false MAME-Marquee_Artwork [game] [system] needs to be changed like this parameters= false MAME-Marquee_Artwork "[game]" "[system]" is all i can tell with the little information you have gave normally a copy of the setting.ini for eds is pasted or attached the file, but i should have been clear about that same for hyper marquee but the file is in your setting folder of the program with the label name..
danwelsh Posted November 10, 2015 Posted November 10, 2015 I want to send a big thank you to sevenseal for getting this up and running for me.....I wouldn't have had it going for 6 months, everybody that has HS should have HM too, it looks insanely awesome I'm lovin my arcade
Reefboi16 Posted November 11, 2015 Posted November 11, 2015 So what would be the process to get all three to work together? What files need renamed and too what?
sevenseal Posted November 11, 2015 Posted November 11, 2015 So what would be the process to get all three to work together? What files need renamed and too what? in hyperspin's folder, you would need to enable LEDBlinky in HyperHQ, the opition are under the "TOOLS" tab and select where EDS is, instead of the actual real LEDBlinky is. *Note: you should have rename an .EXE as LEDBlinky.exe in the EDS folder In EDS, click the application entry for LEDBlinky and select where the real LEDBlinky.exe is at. for Hyperspeech, you would need to add then copy the line entry exactly the same as LEDBlinky entry in eds, only different is that your are selecting the hyperspeech program instead...
Reefboi16 Posted November 11, 2015 Posted November 11, 2015 Ah ok I already have led blinky set up and going just need to do it to EDS thanks a lot Sevenseal!
sevenseal Posted November 11, 2015 Posted November 11, 2015 Ah ok I already have led blinky set up and going just need to do it to EDS thanks a lot Sevenseal!eds is your main goto,... but got to keep this thread focus on it main subject.this is the hypermarquee thread, not the eds thread, anything mainly related to eds; please discuss on that thread
danwelsh Posted November 11, 2015 Posted November 11, 2015 im wondering how do I layer things.....what I want to have is a background(static) behind the wheel art and scrolling text along the top.....how would I achieve this? I'm lovin my arcade
sevenseal Posted November 11, 2015 Posted November 11, 2015 im wondering how do I layer things.....what I want to have is a background(static) behind the wheel art and scrolling text along the top.....how would I achieve this?in the generall tab, there is a background line there, pick your background, what text are you talking about?
danwelsh Posted November 11, 2015 Posted November 11, 2015 game info from the database.....like the info that shows on the main screen with the year, manufacturer, etc. I'm lovin my arcade
sevenseal Posted November 11, 2015 Posted November 11, 2015 game info from the database.....like the info that shows on the main screen with the year, manufacturer, etc.you have setup a new hm config as text, select the location of your databases, theres another line for your game info database from rocketlauncher
danwelsh Posted November 11, 2015 Posted November 11, 2015 okay, thanks sevenseal.....I'll be home in an hour from work and see if I can get it going. I'm lovin my arcade
danwelsh Posted November 12, 2015 Posted November 12, 2015 you have setup a new hm config as text, select the location of your databases, theres another line for your game info database from rocketlauncher got it working after a few hours haha....i'm learning the ropes though, thank you ....i got videos to work too, now just to mod my cab to accept the monitor this weekend.... I'm lovin my arcade
