or8ital's HyperSpin Helper Software - 2nd / 3rd Display Controller
Would you be interested in software like this?
124 members have voted
  1. 1. Would you be interested in software like this?
That machine looks great!! I need to get working on building mine.
Info on HyperspinHelper Software: http://hyperspinhelper.wordpress.com. Allows you to enable two additional displays as a Marquee and a controls help screen as well as map UltraStik 360 controls. Works exclusively with Hyperspin.
  • Replies 606
Yes. Just flip the screens each is displayed on.
I can't as my emulators resolution is set for the upper monitor (higher resolution)
As soon as I swap them the emus crash. Only way is to switch off the monitor. Also some of my emulators refuse to run on the secondary monitor. Another glitch is when using my lightgun on secondary monitor if I press the trigger it loses focus as the pc sees the mouse clicked on the primary screen.
sig2.png?raw=1sig.jpg?raw=1
My idea (theory) is for hyperspin to launch an ahk.exe for each lightgun game that:
1. Kills HSHelper
2. Switches display mode to "projector only"
3. Launches an instance of an emulator with settings for that particular game.
4. Switches display mode back to "external" on exit.
5. Re-launch HSHelper.
Good point and I can't switch them until hyperlaunch has started which means the emulator has as well.
Script all ready and working :) apart from HSHelper :(
Posted so you could see what's happening at my end.
Loop
Process, Wait, pcsxr-lightgun.exe
Process,Close, HyperSpinHelper.exe
sleep, 2000
run C:\Windows\System32\DisplaySwitch.exe /external
sleep, 1000
WinGetActiveTitle, title
WinMinimize, %title%
WinMaximize, %title%
Process,WaitClose, pcsxr-lightgun.exe
run C:\Windows\System32\DisplaySwitch.exe /extend
;run C:\HyperSpinHelper\HyperSpinHelper.exe
I think I might know what's going on. My pc is currently not setup so once I get that setup again I will take a look.
To not have it launch HS then change the settings.xml file where it says "LaunchHSonStart" set that to false.
Is it still crashing when you run your AHK script to remove the monitor?
Try the version I just uploaded and see if that works. I made the change I think I need in only 2 of the 3 places it is needed. If you have the bezel enabled then it would have crashed the last time you tried it.
I'll have to take a look again tonight. Does it work with that system if you don't disconnect the monitor? I want to make sure I'm chasing the right problem.
Just looked at your scripts again. Try not killing HShelper and see what happens. Just disable the monitor.
What is your AHK saying that causes you to think it is giving an error when it tries to launch again?
It crashes after the updated code from yesterday if you don't close it? Hmmm
Can you run your script compiled? I think it might be because HSHelper requires admin privileges and not confirming the UAC is causing it to crash. If you compile it you can then run that exe as an admin.
I think I figured it out finally. It was inside a delegate for another thread so handling the error was a little obscure. You should be able to keep HSHelper running now. New version on FTP
Brilliant, it works :D
No need to kill it now it just works perfect. Much appreciated, thank you :)
Glad I still get to use HSHelper, it's a great piece of software.
Orbital, ive just read this thread. Great piece of software. Also a thanks to Sandman and yourself for working through issues.
Im sure it will come in handy when I finally start my project.
I have an old playstation 1 travel screen which I plan to mod into a secondary display and thismsoftware looks like it will put it to great use.
Testing with RocketLauncher.0 tonight to see if there are any compatibility issues or new content we can tie into.
I've updated to work with RocketLauncher.0. Unfortunately I can't upload as the FTP site is saying it is above its maximum limit.
OK, finally got in. Now updating. Kept the old version out there for the old Hyperlaunch (I did have to make changes for the new). I have no fully tested this with the new Hyperlaunch but it should work. Let me know if you find any issues.
