floatingyeti
    1,198
    145
Everything posted by floatingyeti
  1. Enable: Software list automatic media type
  2. To fix blackscreen Bezel error: Enable Alternate render method in RA options I listed all my RA settings here: https://hyperspin-fe.com/forums/topic/43059-how-to-add-systems-for-retroarchmame/
  3. Version 1.0.1
    1,299 downloads
    FM Towns Marty RetroArch(mame - current) setup This is for use with Mame Software list CHD "fmtowns_cd" set I tested all 783 games and ended up with a set of 264 playable. Conditions for included games: Compatible with 2 virtual gamepads Boots straight to game (no Towns OS) Does not required mouse Any game left off this list will be in a future expanded FM Towns setup. I have made a "Games" folder that is prepped with all user/boot/utility disks necessary. Just drop in the fmtowns_cd CHD files into the corresponding folders. I created my own hash file so make sure to download that and the retroarch fmtmarty.cfg for controls. RetroArch.ahk additions: MSystem: "Fujitsu FM Towns Marty" mTypeVar: Fujitsu FM Towns Marty|mame_libretro|fmtmarty
  4. Thank you for sharing this, it is amazing!
  5. Version 1.0.0
    477 downloads
    Philips CD-i Setup for RetroArch (libretro_mame core) I tested every game CD-i (not DVC) game and was able to run all of these. I prepared a preconfigured games folder. The empty zip files are the dummy roms Place your CHD files in the empty folders (one for each game). The folders are named the same as MAME Software List CHDs so you can drop in the folders/CHDs easily. ---------------------------------------------------- These games are not run though RetroArch MAME core: Link - The Faces of Evil (Remastered) - Launch PC version with PC Launcher Zelda - The Wand of Gamelon (Remastered) - Launch PC version with PC Launcher The - Apprentice (Shikote's PC Remake) - Launch PC version with PC Launcher Dimo's Quest (Dos version) - Launch with (DOSBox - Pure) core
  6. Version 1.0.1
    542 downloads
    IBM PCjr RetroArch (mame_libretro) Complete Setup Database/Menus/Wheels/Videos/Bezel/Games/CFG ----------------------------------------------- Using CFG file: L1=F1 R2=F2 R2=K (Keyboard Selection) L2=J (Joystick Selection) Select=O (Options) Start=S (Start) A=Button 1 X=Button 2
  7. Version 1.0.0
    334 downloads
    Tiger Game.com setup for RetroArch(mame_libretro) Database/Menus/Wheels/Videos/Bezel/Games/CFG --------------------------------- Using gamecom.cfg: To Start game press "X" once to highlight cartridge then "X" again to launch game.
  8. Version 1.0.1
    354 downloads
    I've always avoided this system because there are only 3 games and its barely what I would consider to be playable. I wanted to challenge myself to see if I could make an interesting theme and completely playable with an xinput controller. Database/Themes/Wheels/Videos/Games/CFG I added audio to the videos Special instruction: ------------------------- Edit RetroArch.ahk (Module) In MSystem add: "Aamber Pegasus" In mTypeVar add: Aamber Pegasus|mame_libretro|pegasus -------------------------- How to load games (using CFG file): Galaxy: Press X to load game For Game Option selection L1=1 R1=2 Invaders: Press Start to load game Press X for Go Tank: Press L2 then R2 to load game
  9. Version 1.0.0
    500 downloads
    Bandai Super Vision 8000 setup for RetroArch (mame_libretro core) Database/Menus/Wheels/Videos/Bezel/Games/CFG I recommend using the bezel with scanlines it makes the low res games easier to play. ------------------------------------------------------- Xinput Map (USE CFG FILE): LEFT THUMBSTICK AND DPAD = MOVEMENT FIRE = X/A L1=1 R1=2 L2-3 R2=4 Y=5 B=6 L3=7 R3=8 START=9 SELECT=0
  10. Version 1.0.1
    422 downloads
    Complete Setup for Casio PV-1000/PV-2000 systems Databases/Menus/Wheels/Games/CFG for RetroArch (mame_libretro core)
  11. Version 1.0.1
    549 downloads
    Sord M5 setup for RetroArch (mame_libretro) Themes/Wheels/Database/Videos/Games/CFG Expanded for 11 to 22 games Download CFG for Xinput mapped controls: L1= 1 R1= 2 L2=3 R2=4 X=Fire Rocket Launcher Module Fix: RetroArch.ahk Edit: Sord M5|LibRetro_SORD|mame_libretro|m5 To: Sord M5|mame_libretro|m5
  12. Version 1.0.1
    696 downloads
    Atari XEGS setup for RetroArch (mame_libretro) Themes/Wheels/Database/Videos/BoxArt/Games/CFG
  13. Version 1.0.1
    498 downloads
    Sharp MZ-2500 RetroArch (mame_libretro) setup All playable games that: 1. Currently run in the core 2. Playable with xinput controller Themes/Videos/Wheels/Games/CFG included
  14. Version 1.0.1
    574 downloads
    MGT Sam Coupe Setup for RetroArch (mame_libretro) I thought this would be easy but MAME core didn't have mappable joystick or mouse controls. This limited the amount playable games but I think it was worth the effort in the end. Main Theme/default - modified version of Nimbios72 default theme Wheels - mostly recreated with fonts in Photoshop Hash file - made by me For Xinput Controller Mapping download RetroArch(MAME) Hash and CFG.zip and place hash and config in correct folders -------------------------------------------------------- Launch games: Press select(back) to boot game mapped to F9 key Special Controls: L1 - 1 R1 - 2 L2 - 3 R2 - 4 L3 - y (yes) R3 - n (no)
  15. Version 1.0.1
    725 downloads
    Atari 800 (cart only) This is using MAME Software List Rom set for Atari 800 (a800) carts. This will work in MAME and RetroArch (MAME-current) Database (Games/Cart only) + Genre xml Main Menu theme Default theme Wheels - Complete Video (mp4/png) - complete Boxes (3D/2D mix) - incomplete 198/225
  16. Version 1.0.0
    85 downloads
    Creatronic Mega Duck Main Theme and Wheel
  17. Version 1.0.1
    492 downloads
    I made a version of this seven years ago. I tracked down my old files anything else I could find but it was very incomplete. Made Updated: Database Video Snaps Wheels All using MAME Software List names. It works great in MAME and RetroArch (MAME-current core)
  18. Version 1.0.0
    366 downloads
    All Files are using MAME Software List names. It is playable in MAME and RetroArch (MAME-current). I highly recommend using bezel for this system (the graphics are hard to make out fullscreen)
  19. Version 1.0.0
    460 downloads
    Gamate (BIT Corporation) Full Setup All files are using MAME Software List names. It is playable in MAME and RetroArch (MAME - current) The wheels were (for the most part) original designs by me. There wasn't much original artwork to work with so I just created logos based off the game tiles when needed.
  20. Great work! Is the game out yet, I thought it was pushed back until next year?
  21. Version 1.0.0
    39 downloads
    My daughter is obsessed with FNAF so I'm converting my basement into a FNAF Pizzeria complete with FNAF themed arcade machine for her birthday party. This took way longer than I expected, I couldn't find any existing themes, so i made everything from scratch. I've never played the games so hopefully I got the appropriate images for each game. File includes: Database Main Menu Theme, Wheel, Video, and Marquee Games Themes, Wheels, Videos, and Marquees
  22. The actual theme is missing from the download I made one matching your thumbnail and attached it. Axiom Verge 2.zip
  23. Version 1.0.0
    1,530 downloads
    I made a 175 game database for Teknoparrot. Most of the themes are by Trymado I made a lot of the marquees Everything is named according to Teknoparrot UI info Included genre databases I only included 3 video themes because they might be harder to track down. The other videos should be available at Emumovies or individually at Trymado's content page.
  24. Version 1.0.0
    58 downloads
    There are not a lot of Nintendo 3DS videos available yet so I collected these 235 screenshots. These combined with the videos available on Emumovies are a complete set.
  25. Version 1.0.0
    653 downloads
    I took the excellent work done by HOSCARCONH and I made a more "standard" setup -Converted the naming convention of just numbers to actual game names -Created Database with game names and genre info and made genre files -Created text wheels in Photoshop with PICO-8 font -Altered HOSCARCONH's default theme to match wheel -Uploaded all renamed files and games (original files where just numbers) -Included HOSCARCONH's main menu, bezel, and fade Everything works great with Retroarch retro-8 alpha core
