connorsdad Posted August 1, 2014 Author Posted August 1, 2014 could this be converted into something like a "bartop"? What parts did you use for the rotating screen? Yeah sure it could be converted. The parts I used are: pololu simple motor controller http://www.pololu.com/product/1372 12v DC motor from eBay 4" lazy Susan bearing Mounting hub http://www.pololu.com/product/1083 Brackets http://www.pololu.com/product/1084 Regular microswitches to stop the rotation/motor.
Agrajag Posted August 1, 2014 Posted August 1, 2014 I've been meaning to ask, does the monitor rotate into a perfectly horizontal / vertical orientation and lock into position and did it take a lot of trial and error to make it rotate by the right amount? I would love to build a cab with a rotating screen, but I'm not sure I have the skills to make it look as professional as yours, and it would drive me mad if the screen was always slightly wonky. Sent from my phone using Tapatalk, probably while at work... HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
connorsdad Posted August 1, 2014 Author Posted August 1, 2014 It rotates perfectly, it keeps going until it hits a limit switch (microswitch) which cuts the motor. The plane itself can be off if your monitor is heavier on 1 side, mine is off slightly but I need to pull it apart shortly so I'll either add a counter weight or castor underneath.
Agrajag Posted August 1, 2014 Posted August 1, 2014 OK that makes sense, thanks. Good luck with the fine tuning! Sent from my phone using Tapatalk, probably while at work... HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
albert_c Posted August 1, 2014 Posted August 1, 2014 Sexy as hell. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
connorsdad Posted August 1, 2014 Author Posted August 1, 2014 Here's a few videos from my testing phase that may be of interest to others.
KlopjerO Posted August 1, 2014 Posted August 1, 2014 Yeah sure it could be converted. The parts I used are:pololu simple motor controller http://www.pololu.com/product/1372 12v DC motor from eBay 4" lazy Susan bearing Mounting hub http://www.pololu.com/product/1083 Brackets http://www.pololu.com/product/1084 Regular microswitches to stop the rotation/motor. Thanks, I'm going to ask an impertinent question. Do you have the schematics to share? A Blueprint I mean. | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
connorsdad Posted August 1, 2014 Author Posted August 1, 2014 I don't but I will take photos when I dismantle it, hopefully in about 6 weeks.
AshuraX Posted August 1, 2014 Posted August 1, 2014 Amazing work, you're cabinet is so beautifull! Love rotate fonction and the mix of pinball & arcade. Thanks Ash My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
KlopjerO Posted August 1, 2014 Posted August 1, 2014 I don't but I will take photos when I dismantle it, hopefully in about 6 weeks. Thanks hopefully I can reference it. I totally dig this design | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
KlopjerO Posted August 19, 2014 Posted August 19, 2014 I love it, I have my ideas but, did you attach a plank to the motor and then mounted the monitor on the plank using a vesa mount ? | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
connorsdad Posted August 19, 2014 Author Posted August 19, 2014 I love it, I have my ideas but, did you attach a plank to the motor and then mounted the monitor on the plank using a vesa mount ? In that video I did but eventually swapped it for a piece of wood slightly bigger than the vesa mount area to save on weight. I have an aluminium bar that runs the full length of the monitor attached to the piece of wood, this bar in turn hits the limit switches.
connorsdad Posted September 23, 2014 Author Posted September 23, 2014 You are my new hero. This is awesome. Lol thanks for the comment
HazzardActual Posted September 23, 2014 Posted September 23, 2014 i envy your ability to have your aimtraks work.
connorsdad Posted September 23, 2014 Author Posted September 23, 2014 Who said they work perfect lol, either one works fine on their own but, like everybody else running dual aimtraks the calibration just doesn't work perfectly with both guns. I even returned one gun for a replacement thinking it was broke.
HazzardActual Posted September 23, 2014 Posted September 23, 2014 I even returned one gun for a replacement thinking it was broke. did that twice lol
connorsdad Posted October 18, 2014 Author Posted October 18, 2014 I've read that you should plug 1 gun in and calibrate, then remove that gun before plugging in and calibrating the 2nd gun. Once both guns are plugged in and calibrated individually they will work together. Not tried it yet though.
njgsx96 Posted October 22, 2014 Posted October 22, 2014 When I calibrated mine, I plugged one gun in and calibrated it. I then plugged the other gun in and rebooted. I then verified gun 1 was calibrated still, switched to the second one and calibrated it. Rebooted and verified both were calibrated. Not sure why, but the reboots seemed to help because I did have a bear of a time calibrating them at first. I have not had a problem since using them together or separate. The one issue I have is that they change names/designations in MAME every time I boot up, although they never loose their calibration. Meaning when I use them one time, they are gun1 and gun2. The next time I boot up they are gun4 and gun3. The time after that, gun2 and gun4. etc etc etc. Not a HUGE deal, as I just set them in the global settings. it is a little annoying but only takes a minute. Once that is done in MAME I have never had an issue using both at the same time or one or the other.
connorsdad Posted October 22, 2014 Author Posted October 22, 2014 When I calibrated mine, I plugged one gun in and calibrated it. I then plugged the other gun in and rebooted. I then verified gun 1 was calibrated still, switched to the second one and calibrated it. Rebooted and verified both were calibrated. Not sure why, but the reboots seemed to help because I did have a bear of a time calibrating them at first. I have not had a problem since using them together or separate.The one issue I have is that they change names/designations in MAME every time I boot up, although they never loose their calibration. Meaning when I use them one time, they are gun1 and gun2. The next time I boot up they are gun4 and gun3. The time after that, gun2 and gun4. etc etc etc. Not a HUGE deal, as I just set them in the global settings. it is a little annoying but only takes a minute. Once that is done in MAME I have never had an issue using both at the same time or one or the other. If you plug them into separate usb headers on the motherboard they stick with the same id. The 1 out of 5/6 boot ups where the id has changed, simply reboot and they will be back as they were. I needed them to stick as Sega model 2 and 3 required it. I will try re calibrating them separately at some point.
connorsdad Posted June 29, 2015 Author Posted June 29, 2015 Thinking of selling up :/ maybe time for a new project. Sell as a complete unit or dismantle and sell the parts, have you guys sold any of your home made cabs before ? Sent from my SM-N9005 using Tapatalk
ninja2bceen Posted June 29, 2015 Posted June 29, 2015 eBay? How much (Tapatalk) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Metalzoic Posted June 29, 2015 Posted June 29, 2015 Thinking of selling up :/ maybe time for a new project. Sell as a complete unit or dismantle and sell the parts, have you guys sold any of your home made cabs before ? Sent from my SM-N9005 using Tapatalk Why do you want to sell it?
connorsdad Posted June 29, 2015 Author Posted June 29, 2015 Started to collect original cabs and need the room, wife says no more unless you get rid of 1. Keeping my vpin and sega rally 2 plus I'm just about to take delivery of a sit down racer. I've got my eye on a few more but something has to go first Sent from my SM-N9005 using Tapatalk
