Metalzoic Posted May 25, 2016 Author Posted May 25, 2016 can I get this from you please? Sure, check you messages
thatman84 Posted May 26, 2016 Posted May 26, 2016 Not sure what you guys mean. Transitions came with your HyperSpin download. You should already have (most of) them. There was an additional pack of them here in the DL section... or maybe it was on the FTP, but that just adds more to what you have. There are no special transitions for this wheel, it's just using the default ones. I will have a dig about again, but I think the only things I could see were in the main menu and named as system name.flv. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
knewlife Posted May 26, 2016 Posted May 26, 2016 I think this are the transitions /Platinum Downloads/_Old FTP/_Extras/Transition Packs/ Sent from my Nokia Lumia 520 using Tapatalk EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
Metalzoic Posted May 26, 2016 Author Posted May 26, 2016 Your Intersticials are found in media>main menu>images>backgrounds Your Transitions are found in media>front end>video You should already have a bunch of each, I have 84 transitions but many (if not most) are included in the HS download. you probably just have them turned off in HyperHQ.
Metalzoic Posted June 18, 2016 Author Posted June 18, 2016 excelent work, can I get this from you please? Sure! I'll send it to you in a bit.
Metalzoic Posted June 19, 2016 Author Posted June 19, 2016 Wonderful, can I get this from you please? Sure, as long as you aren't one of those thieving pantsheads from Spain.
maks Posted June 23, 2016 Posted June 23, 2016 Fantastic. I would also love to have it. Sent from my SM-N910P using Tapatalk
Metalzoic Posted June 23, 2016 Author Posted June 23, 2016 Fantastic. I would also love to have it. Sent from my SM-N910P using Tapatalk Sure... I just remembered I totally forgot to send it to the other 2 dudes too. oops.
BATTLEDONKEY Posted June 23, 2016 Posted June 23, 2016 All the artwork and everything looks incredible, love the fact u not only created the themes but also custom fade screens and the bezels. Fantastic work. Any chance I can hop on the bandwagon n get a link for this too?
klizine Posted June 23, 2016 Posted June 23, 2016 This is amazing! I would love a pm for the link too!
Metalzoic Posted June 23, 2016 Author Posted June 23, 2016 Thanks guys. I'll get it to both of you in just a bit.
Metalzoic Posted June 28, 2016 Author Posted June 28, 2016 Just found realized that Ghosts'N Demons is up to version 1.5.4 now. It was only at 1.3.6 when I created this. There's a text file in the GnD folder that tells you what version you are on. Or if when you're starting a new game, there isn't a beehive right above whee Arthur starts you're playing an older version.
klizine Posted June 29, 2016 Posted June 29, 2016 holy moley.... I'm not going to lie... i set it up and just sat there watching the main menu theme..... it's just awesome to see on your own setup. Great work on Metalzoic!! It's obvious how much work went into this!! You've done a great job!
Metalzoic Posted June 29, 2016 Author Posted June 29, 2016 holy moley.... I'm not going to lie... i set it up and just sat there watching the main menu theme..... it's just awesome to see on your own setup. Great work on Metalzoic!! It's obvious how much work went into this!! You've done a great job! Thanks. That Main Menu theme is actually a HyperSpin cinematic theme created by JamesBaker. I just altered it to add the "'N Goblins'N Gargoyles" part.
maks Posted June 30, 2016 Posted June 30, 2016 Anyone have some tips on setting up the pc games? I cant get Ghouls n ghosts remix to fullscreen. And when I try to exit, rocketlauncher doesn't seem to close either of the pc games. I end up getting stuck on rocketlaunchers fade out screen. Sent from my SM-N920V using Tapatalk
Metalzoic Posted July 2, 2016 Author Posted July 2, 2016 Anyone have some tips on setting up the pc games? I cant get Ghouls n ghosts remix to fullscreen. And when I try to exit, rocketlauncher doesn't seem to close either of the pc games. I end up getting stuck on rocketlaunchers fade out screen. Sent from my SM-N920V using Tapatalk For Ghosts'n Demons set the resolution to Fullscreen, 2x and personally I think bilinear plus looks the best for the filter. That will give you almost full screen, but the aspect will be slightly stretched. Or you can run it at Fullscreen, 4x which gives the correct aspect and fills the entire screen, but personally I think looks worse because there are no filters to soften the (now) ginormous pixels. For GnG Remix there is one particular setting that works and runs the game full-screen and correct aspect... Video Mode: 640x480 Scanlines: Off Fullscreen: On Fit Resolution: On To exit set the "Exit Mode" to "In-Game" for each. Then exit using the actual exit option.
BATTLEDONKEY Posted July 7, 2016 Posted July 7, 2016 You put together a fantastic collection, love all the artwork and the custom fades are a great touch
Metalzoic Posted July 7, 2016 Author Posted July 7, 2016 You put together a fantastic collection, love all the artwork and the custom fades are a great touch Thanks. Glad you like it.
maks Posted July 8, 2016 Posted July 8, 2016 For Ghosts'n Demons set the resolution to Fullscreen, 2x and personally I think bilinear plus looks the best for the filter. That will give you almost full screen, but the aspect will be slightly stretched. Or you can run it at Fullscreen, 4x which gives the correct aspect and fills the entire screen, but personally I think looks worse because there are no filters to soften the (now) ginormous pixels. For GnG Remix there is one particular setting that works and runs the game full-screen and correct aspect... Video Mode: 640x480 Scanlines: Off Fullscreen: On Fit Resolution: On To exit set the "Exit Mode" to "In-Game" for each. Then exit using the actual exit option. Thanks! That worked out great for me. Sent from my SM-N910P using Tapatalk
KlopjerO Posted July 12, 2016 Posted July 12, 2016 You know what I absolutely hate about the main menu theme? The way it makes the rest of my setup look like shit. Sent from my SM-A700FD using Tapatalk | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
Metalzoic Posted July 12, 2016 Author Posted July 12, 2016 You know what I absolutely hate about the main menu theme? The way it makes the rest of my setup look like shit. Sent from my SM-A700FD using Tapatalk Ha!Sent from my SM-G935V
