teacworms
  • Replies 59
  monkeychunkuk said:
It's so good I wonder if more skins will be added ?
That surely is their intention.
Which begs the question " What would you like to see ?"
They've already done my favourite movie, The Exorcist, so as a second choice maybe An American Werewolf in London.
I did like the flying spectres on the Indy skin.
Maybe there should be another genre/wheel. Retro doesn't quite cover it.... Tribute? (Tenacious D bangin' in my head right now, with game in stead of song!)
Wow this is actually epic, just played and loved it.......I would like to add it to my vertical cab tho as well it would suit it best. How can I add this to mame as stated in few posts back instead of running as a pc game ?
ty all :)
Hi MontyQ
Add an entry into your Mame xml
  Quote
<game name="Donkey Me" index="true" image="'">
<description>Donkey Me</description>
<cloneof>Donkey Kong</cloneof>
<crc />
<manufacturer>bruneras.com</manufacturer>
<year>2013</year>
<genre>Platform</genre>
<rating>AAMA - Green (Suitable For All Ages)</rating>
<enabled>Yes</enabled>
Go to Hyperlaunch\Settings\Mame
Find the Games.ini and open it
Add the Donkey Me entry, this is what's in mine currently.
  Quote
[FixitFelixJr]
Emulator=PCLauncher
System=MAME
[Donkey Me]
Emulator=PCLauncher
System=MAME
I'll assume your already using the PCLuancher module for something else. If not put the tick in the box.
Now head over to :\HyperLaunch\Modules\PCLauncher
open the Pclauncher.ini
Add this entry, changing the application path to reflect where you have the game.
  Quote
[Donkey Me]
Application=J:\Donkey Me\DonkeyMe.exe
FadeTitle=Donkey-Me ahk_class YYGameMakerYY
That should be it, give me a shout if not.
thanks for the info giga, thought I could make it into a zip for mame as I don't use hyperspin on my vertical cab as well theres no real vertical support at all.(Except cocktail which be awesome if I had a cocktail cab)
Ty tho
Ty tho
Mame zips have .bin files in correct?
Wouldn't have a clue how to do that or if its possible, but would be interesting to find out.
Heck I'd do it the way giga said but hyperspin has no real vertical support for cabs, there is that awesome cocktail work being done which seems epic (gotta build me one) but as far as vertical stand up cabs hs doesn't seem to go that way. Be awesome tho there is 100s of vertical games and I like hyperspin the best for the eyecandy, but unil then its mala for vertical for me.
  MontyQ said:
Is there anyways with like an app or batch file ect to make this game flip into vertical as soon as it loads ?
Perhaps you could use iRotate, which you can find in the module extensions folder.
When you run it you then press ctrl-alt and then the cursor keys depending on which way you want to rotate.
Perhaps someone can help create an ahk or bat to add in to the post and pre launch of Donkey Me.
I just found this
I have it doing this, I'll post my script when I get home later.
Sent from my SM-N9005 using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
I just found this
Thanks :) my vertical cab is mala tho since hs has no vertical support....not sure mala even does ahk plus I need it all off a dk cpo so not many keys there. Thinking auto launch it vertical is my way to play cheers tho
ty sounds awesome, so I don't need to do it throught hs then ?
You would need to have Ahk installed to use my script, I could modify it for you so that it sits in the system tray waiting for DonkeyMe to be launched. You would probably be better off using .bat but I know squat about batch files. The one I could offer would basically wait for the DonkeyMe process to start then would rotate your desktop using iRotate, then on closing the DonkeyMe process, rotate the desktop back and close iRotate.
Edit
Doesn't need ahk installed, only iRotate is needed, doesn't sit in the system tray waiting for DonkeyMe to be launched. It replaces the original exe.
Ya sounds kool :)
I'll be home in a few hours so I'll post my script then if you haven't been sorted out :)
In the meantime, install iRotate, I think you'll need iRotate anyway with either script.
ok ty , I shall install it cheers :)
