maddags Posted November 18, 2010 Posted November 18, 2010 Hey chris, Where did you get that shaker from! Do you have a link where I could get one or one similar And If I could also get the exact model numbers of the cree led's and the componets that you used. I also seen on that website that they have these http://www.led-tech.de/en/High-Power-Supply/LED-Profile-CoverLine-c_106_151.html . Could this be used and top mount it onto of the back box. Another question, How is it all conected to the cree leds. So the four wires one for common power and four for ground for each color. Do you have to solder them onto the board directly or is there a connector.
chriz99 Posted November 19, 2010 Author Posted November 19, 2010 Hey chris,Where did you get that shaker from! Do you have a link where I could get one or one similar And If I could also get the exact model numbers of the cree led's and the componets that you used. I also seen on that website that they have these http://www.led-tech.de/en/High-Power-Supply/LED-Profile-CoverLine-c_106_151.html . Could this be used and top mount it onto of the back box. Another question, How is it all conected to the cree leds. So the four wires one for common power and four for ground for each color. Do you have to solder them onto the board directly or is there a connector. hey maddags, I think you can use this Aluminium LED Profile for the cree leds. You have to solder some wires to the cree star-board. Check this thread for a direct shoplink to the cree led. klaus (wolfsoft.de) will order some shaker for the forums. cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
shilmover Posted November 19, 2010 Posted November 19, 2010 klaus (wolfsoft.de) will order some shaker for the forums. Hmmm. I wonder how much they would cost and how much to ship to this side of the Atlantic...
shilmover Posted November 20, 2010 Posted November 20, 2010 Here is the first test of my flashers. They are not hooked up to the pinball, but are running off my laptop. These are the RGB LEDs I got from China and while they can display white, there is a bit of color bleedoff with displaying white (you can see a bit of the RGB colors off the lens refraction. Also, this is running with 5v. I am planning on running it with 12v. The resistors are 29 ohm, 5W so they should be good for the 12v too. They are currently running with no extra heatsink, but I will add those when they arrive from china. It may not be noticable in the video, but they are bright and will give you a headache if you stare right at them for a prolonged period of time... Chris, I hope its okay that I posted this in your thread. If not, let me know and I will move this post... greHfgBTtb8
shilmover Posted November 20, 2010 Posted November 20, 2010 And a quick experiment hooking it up to music... There should be more LEDs hooked up and its not the greatest quality, but gives an idea... This is what my touchscreen jukebox will be doing... aRRDJpaSuVY
chriz99 Posted November 20, 2010 Author Posted November 20, 2010 nice and bright rgb setup, shilmover no prob for posting cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
chriz99 Posted November 20, 2010 Author Posted November 20, 2010 I think I found the "perfect" dmd resolution for my cabinet Resizing manually the dmd (via software) causes unproportional dot matrix dots --> looks bad. I drive my 19" dmd screen @ 640x480/16bit with a doublesized pinmame dmd. It's nice and clear, but there was always a 2cm left/right black border. Now I use a 570x460 custom resolution (16bit/doublesized dmd/25%AA)... which fills my screen perfectly I love it! I use PowerStrip (http://entechtaiwan.com/util/ps.shtm) to create custom resolutions for my dmd-screen. Works like a champ! cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
shilmover Posted November 20, 2010 Posted November 20, 2010 I think I found the "perfect" dmd resolution for my cabinet Resizing manually the dmd (via software) causes unproportional dot matrix dots --> looks bad. I drive my 19" dmd screen @ 640x480/16bit with a doublesized pinmame dmd. It's nice and clear, but there was always a 2cm left/right black border. Now I use a 570x460 custom resolution (16bit/doublesized dmd/25%AA)... which fills my screen perfectly I love it! I use PowerStrip (http://entechtaiwan.com/util/ps.shtm) to create custom resolutions for my dmd-screen. Works like a champ! Very cool Chris. I will try that... maybe it can help me with my Future Pinball problem. I have my backglass set to 1280x1024, but that option is not available in Future Pinball...
shilmover Posted November 20, 2010 Posted November 20, 2010 I'm blind! Hooked up the LEDs to 12v (actually, 9.6v as I did not want to blow them... ) and man are they bright... I actually accidentally connected 12v into the USB on my laptop, at which point it went completely dead! Had to disconnect both batteries and wait 30 minutes until I could get it running again... LED-Wiz board is okay too! I thought I was in trouble... Anyway, here is a short video with 12v driving 3 RGB LEDs: SEXbia6PP3k Compared to 5v (same test): greHfgBTtb8 It does not look like it, but they are much, much brighter!
shilmover Posted November 21, 2010 Posted November 21, 2010 And a night video... terrible video, but you get the idea... Not as bright at the Cree ones, but lights up the room. WednCa4diGM Disco in my kitchen!!! WQPdo-t0wvM
njay Posted November 21, 2010 Posted November 21, 2010 pretty cool shilmover, nice work installing them leds My Mini Pin Build: http://www.hyperspin-fe.com/forum/showthread.php?t=5622 My Arcade Bartop Build: http://www.hyperspin-fe.com/forum/showthread.php?t=14570
Guest gstav Posted November 21, 2010 Posted November 21, 2010 Yes! Shillmover, which leds are you using! Thought of pointing my setup against the player, so your brightness seemes to be perfect for me. Did you bought them on ebay? regards!
shilmover Posted November 21, 2010 Posted November 21, 2010 These ones... I bought 10. 2 have been having issues, but they are working with me to replace them... http://cgi.ebay.com/3W-High-Power-RGB-Led-6-Pins-1pcs-/380289340496?pt=LH_DefaultDomain_0&hash=item588b02d450 I also ran these for about 30 minutes and they only got slightly warm, so I am not sure they need heatsinks...
shilmover Posted November 21, 2010 Posted November 21, 2010 Here is a video (again, sorry about the quality) of the flashers on top of the pinball: QaEDzWhKUxc
Guest gstav Posted November 21, 2010 Posted November 21, 2010 Thanks mate! Have you tried to display "white" light with them too?
shilmover Posted November 21, 2010 Posted November 21, 2010 Thanks mate! Have you tried to display "white" light with them too? Yes. It comes out white, but if you look closely at refraction against the wall/etc you see that its made up of the 3 base colors... most people would not notice it...
lettuce Posted November 22, 2010 Posted November 22, 2010 Woooo, Shilmover and chris - alot of progress have been made on this i take it nothing has been scripted to work with a actual table yet? Also are people looking at installing lights inside the cab, by the side of the LCD PF screen if theres room to simulate flashers on the PF?
shilmover Posted November 22, 2010 Posted November 22, 2010 Woooo, Shilmover and chris - alot of progress have been made on this i take it nothing has been scripted to work with a actual table yet? Also are people looking at installing lights inside the cab, by the side of the LCD PF screen if theres room to simulate flashers on the PF? Chris has the beta software, so his are ROM driven from actual tables. I dont have the software yet so I am holding out wiring the actual cabinet for now. I have thought of installing some small 5v RGB LEDs (I have several) on the sides of the monitor to see how it looks, but I have not had time yet... Not sure how reflections off the glass will look...
Guest gstav Posted November 22, 2010 Posted November 22, 2010 Hey Lettuce, I´m planning of placing my domes like this: What do you think about that shillmover? Thought of usin CREEs first, but then you´ll probably go blind
shilmover Posted November 22, 2010 Posted November 22, 2010 Hey Lettuce, I´m planning of placing my domes like this: What do you think about that shillmover? Thought of usin CREEs first, but then you´ll probably go blind gstav, I like that, but I think it might be too bright to do it that way... Maybe with 5v it would be okay. I will test it with both voltages tonight ...
gbeef Posted November 22, 2010 Posted November 22, 2010 i was thinking of doing this same also. But not sure how it would look My Cabs My Pin Cab Attack of the PINZ cab My Racing Cab OutRun Racing
shilmover Posted November 22, 2010 Posted November 22, 2010 i was thinking of doing this same also. But not sure how it would look Hang tight. I will test it tonight... I have also been working on mounting small RGB LEDs on the wood frame I have around my LCD Bezel. so that the lights come from the sides/top of the LCD under the glass. I will post my updates on that as I move forward...
Guest gstav Posted November 22, 2010 Posted November 22, 2010 Sounds great guys! Ordered the same RGB as you Shillmover. So hopefully the reflection under the glas turn out well! Can´t wait for your test!!
shilmover Posted November 22, 2010 Posted November 22, 2010 Sounds great guys! Ordered the same RGB as you Shillmover. So hopefully the reflection under the glas turn out well! Can´t wait for your test!! to be clear. I think the 3W LEDs are too bright to be used under the glass, but regular RGB LEDs may work...
gbeef Posted November 22, 2010 Posted November 22, 2010 well what if you setup the caps like medevil maddness. that machine doesnt use Large caps My Cabs My Pin Cab Attack of the PINZ cab My Racing Cab OutRun Racing
