UPDATED: Vectorized versions HyperSpin Footer Animations, Exit and Favorites menus (4:3 and 16:9)
Bubs
Hi,
I made vectorized version of  Hyperspin Footer animations of the main menu (Next Game, Press Start, Free Play) and also Favorites and Exit menus !
Idea was to not have jagged animation when not running in Native Resolution (1024x768), or not stretched if running in 16/9:
You can download them here:  HyperSpin_Vector_Pack_v4.5.1_by_Bubs.zip
  • There is a Readme.txt file in the archive that explains how to test it
  • Now are included 4:3 and 16:9 versions
  • Now are included Favorites & Exit menus: (files are .swf renamed as .png to be accepted by HyperSpin)
Let me know what you think !
Thanks
Bubs
FOOTER:
Before (Bitmap):
After (Vector):
16/9 Before (Bitmap, stretched):
16/9 After (Vector, not stretched):
HiDPi Detail:
MENU (Exit & Favorites):
Before (Bitmap):
After (Vector):
16/9 Before (Bitmap is stretched):
16/9 After (Vector is not stretched):
DOWNLOAD HERE : HyperSpin_Vector_Pack_v4.5.1_by_Bubs.zip
Upgrade you Frontend arts with the new Vector Pack ! -> Download Here
Usually its best to drop the images in a thread like this with the .psd/.ai or similar file.
Hopefully the other art dudes will comment on them.
I dont think they will be added to the official download package as such but they can be moved to the main downloads section once submitted and some commemts made by an aprover
Thanks, in this forum, or should I use another one?
Hi,
I edited the first message to share the files to test
Feel free to share your feedbacks
Thank you :)
Bubs
Cool...  are there both 4:3 and 16:9 versions? I'd love to get some 16:9 ones to fix that stretch look.
I found some once, but the quality was bad. These look sharp.
Can you try to put this one in Media\Main Menu\Images\Special\SpecialB1.swf and tell me if it looks good to you?
It's the non stretched version of the 4/3 version above...
if it works for you, i'll redo them all
The press start text looks awesome and sharp, the joystick is still stretched wide and the yellow text under the joystick looks the same.
Done, I updated the zip above, with 16:9 versions
Thanks
Bubs
Hi,
I also updated the files to provides Vector content for Exit & Favorites menu, both in 4/3  and non stretched 16/9
Thanks
Bubs
18 minutes ago, thatman84 said:
Nice additions Bubs.
Just a heads up before you spend more time on things gou dont need to...
Thanks, never saw them :)
I dowloanded those files, and I think mines are still relevant, because texts are 100% vectors and not resized bitmaps, so they should look like much cleaner no matter the resolution or aspect ratio.
Also, the two backgrounf files (exit & favs) are dynamically resized to the right aspect ratio in the swf, and not previously in photoshop, so it should look better as no loose of details on Hi resolutions (ie 4K)
hopefully one of the experienced art dudes will give a verdict and I will get these pushed to the proper section.
Seem like an improvement to me. I know everyone likes vector.
When your already submit them to Upload here and Use "Frontend" and "Special Art" in the titles.
Dude this is awesome!
I've been wanting 16:9 art for these items forever. And not only did you do that, but they look awesome and sharp too.
Thanks man! Really appreciated. This is great! So good I'm calling this a new version of the cab and will run a full backup tonight to preserve it for future generations. All of which will sing praises to your name and name their first born Bubs. Which also happens to be the nickname of the cat that is pestering me as I type this.
Glad you liked them :)
I slightly updated couple of 16/9 menu images to make them better centered (Yes/No/Arrow of Exit Menu)
New version in the main post
42 minutes ago, thatman84 said:
I created a Frontend Media section in the downloads now!
Whenever your happy there finished
:) Just did it here:
Anything missing ? Did not found anything related to where to put the category?
My Adobe Animate trial licence expire tonight, so timing is good :)
So I only need to update the Front End images?
Yes!
I upgraded the Favorties, Exit background and arrows to 100% vector, it should now appear very clean on any resolution :)
(re-draw from scratch)
