slydog43 Posted October 26, 2011 Posted October 26, 2011 Good thinking, no need for pause at all anymore. I also never used the countdown thing. You have my vote for eliminating those "old" features, +1 for simplicity and easier coding!
DedroK_V Posted October 26, 2011 Posted October 26, 2011 Can do without pause screen, I have become attached to Exit 321 as a novelty ,I still use it sometimes ... but that said, whatever make it easier for you guys. Top work Blur and Samwyze. All these new features have made a huge difference, and now printscreen as well By the way, still haven't copied on to my cab and tested it yet .... maybe on the weekend.
bent98 Posted October 26, 2011 Posted October 26, 2011 That sounds reasonable. Maybe you should add the word. Pause/Menu. I have a Pause Button on my cab. Also, I havent been home to test latest WIP. Did you guys add the DMD messages when scrolling in HP? I know there is some much to test and going on with this script but I was just curious about this as that was one feature I was really looking forward to.
unclewilly Posted October 26, 2011 Posted October 26, 2011 I had a question just to see if this is possible. Can you use multiple versions of pinmame and have the fplaunch rename the fplaunch.dll files at table launch. I know vpman allows you to choose between different versions of pinmame. I have just found that some games play better on older pinmames, not sure why. Just wondering if this is possible or if i need to figure a way to do it through the table script FP TableS: Bad Cats, Schizo, Puzzlebox VP Table Mods: TOTAN night, Flintstones night VP Tables: Bad Cats Cabinet Builder [sIGPIC][/sIGPIC]
bent98 Posted October 26, 2011 Posted October 26, 2011 You know what UW, thats a great idea. I too find certain tables for whatever reason play better with different versions of Pinmame. Blur, you gotta figure this one out.
blur Posted October 26, 2011 Posted October 26, 2011 (edited) rename of vpinmame dll is not a problem if that's all that needs to be done if you have to run vpinmame setup every time - that could be a problem will have to try as for dmd - if you mean high scores (pinemhi) i didn't put that in yet - that dmd in swf looks very squeezed - i would prefer high scores written in some dmd like font over upper part of the screen (kinda like fp). This squeezed dmd doesn't look up to the standard of hyperpin if you thought about utility for third screen - that's not on the way yet last thing i did is adding gdi plus loading screen with rolling hyperpin sign i thought changing world rotate with bitmap rotate flip would reduce gdip code very much, but it looks like it won't gdi code just for showing image in gui is awfully long - check this: Gui, 1: -Caption +E0x80000 +LastFound +OwnDialogs +Owner +AlwaysOnTop Gui, 1: Show, NA hwnd1 := WinExist() pBitmap := Gdip_CreateBitmapFromFile("background.png") Width := Gdip_GetImageWidth(pBitmap), Height := Gdip_GetImageHeight(pBitmap) hbm := CreateDIBSection(Width//2, Height//2) hdc := CreateCompatibleDC() obm := SelectObject(hdc, hbm) G := Gdip_GraphicsFromHDC(hdc) Gdip_SetInterpolationMode(G, 7) Gdip_DrawImage(G, pBitmap, 0, 0, Width//2, Height//2, 0, 0, Width, Height) UpdateLayeredWindow(hwnd1, hdc, 0, 0, Width//2, Height//2) SelectObject(hdc, obm) DeleteObject(hbm) DeleteDC(hdc) Gdip_DeleteGraphics(G) Gdip_DisposeImage(pBitmap) rotation just adds few lines more does any body know a shorter way to do this? if not i will have to put this in function Edited October 27, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Zablon Posted October 27, 2011 Posted October 27, 2011 I've been messing with the latest WIP and everything seems to work great. (Except screen printing of FP tables in Win7---which I think you are already aware of. I also seem to ahve an issue of the visual pinball menu coming up when I bring up the menu in a game, and it does not go away when returning to the game, however I think that is due to that I still use "esc" as my primary button.
blur Posted October 27, 2011 Posted October 27, 2011 yup, all true, win7 and printscreen don't like each other, and you should change your exit key to e My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted October 30, 2011 Posted October 30, 2011 here is new release 1.295 wip 6 (or shortly wip 6): http://www.mediafire.com/?6ir943l2cbndzb2 here is change log from this and previous version (in case you missed it), with to do list, all of this you can read from the ahk file also (comment at the beginning of file): 1.295 wip 5 + save printscreen-a under name taken from description + quick launch gui from HL 2.0 + options do not get overwritten + menus + show instructions and flyer on pause + fix slow down after close (when vp is still closing) - fixed - you have to wait a little till windows free memory 1.295 wip 6 + pauseVPinball key changed to pauseKey since it is not just for VP + pauseVP acts exactly the same as exitEmulatorKey so now you can have two keys for opening and exiting menus (Esc and p) and two keys for menu items activation (1 and enter) + instructions are bigger + flyer is bigger, and if works with different dimensions images for same table + loading menu is merged from sam's version + some parts of the code are optimized (draw image by the book), some are not + lots of work and testing so that you can always use exit, enter, flyer and instr keys for example you can press flyer to open flyer directly or go through menus with enter same with instructions you can also switch from flyer to instructions you can close flyer with exit, enter or flyer key, same for instructions all of this will work in vp and fp + ... what else, uhmmmmm let me think - yes loading menu - something was hiding loading slider (probably vp) and unhiding taskbar - this is both fixed so taskbar is hidden every few secs and slider is unhiden + focus problem with loading screen - while slider is on the screen every few seconds we try to activate vp (avoiding dmd hack) also after aprox. 25 secs. we just close loading screen unconditionally also on exit key (or pause key) we close loading screen unconditionally and after close of loading screen there is a one sec sleep and winactivate in a loop so now you should get perfect focus on every vp game + debug mode - lot's of things was written to log file, I also added tool tip on top of the screen - but nothing is written anywhere by default only if you enable it with this option in settings.ini TO DO: - change key names to exitkey exitkey1 and startkey startkey1 for simlicity - remove usepause useexitasapuse useexitmenu options for simplicitiy - use prerotated menu images for simplicity - always use draw image by the book function for simplicity - put every repeating code to subroutines for simplicity - change instruction card menu item to instructions - enable png instructions - compile a set of png instructions and replay score cards and helps for setting replay levels, and tactics help, and ... (hopefully somebody will do this eventually) - test service menu - fix late printscreen in fp - fp auto positioning My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
rockyrocket Posted October 31, 2011 Posted October 31, 2011 Thanks Blur!. Starwars build Tron build Tempest build
blur Posted October 31, 2011 Posted October 31, 2011 blur said: here is new release 1.295 wip 6 (or shortly wip 6):http://www.mediafire.com/?6ir943l2cbndzb2 here is change log from this and previous version (in case you missed it), with to do list, all of this you can read from the ahk file also (comment at the beginning of file): 1.295 wip 5 + save printscreen-a under name taken from description + quick launch gui from HL 2.0 + options do not get overwritten + menus + show instructions and flyer on pause + fix slow down after close (when vp is still closing) - fixed - you have to wait a little till windows free memory 1.295 wip 6 + pauseVPinball key changed to pauseKey since it is not just for VP + pauseVP acts exactly the same as exitEmulatorKey so now you can have two keys for opening and exiting menus (Esc and p) and two keys for menu items activation (1 and enter) + instructions are bigger + flyer is bigger, and if works with different dimensions images for same table + loading menu is merged from sam's version + some parts of the code are optimized (draw image by the book), some are not + lots of work and testing so that you can always use exit, enter, flyer and instr keys for example you can press flyer to open flyer directly or go through menus with enter same with instructions you can also switch from flyer to instructions you can close flyer with exit, enter or flyer key, same for instructions all of this will work in vp and fp + ... what else, uhmmmmm let me think - yes loading menu - something was hiding loading slider (probably vp) and unhiding taskbar - this is both fixed so taskbar is hidden every few secs and slider is unhiden + focus problem with loading screen - while slider is on the screen every few seconds we try to activate vp (avoiding dmd hack) also after aprox. 25 secs. we just close loading screen unconditionally also on exit key (or pause key) we close loading screen unconditionally and after close of loading screen there is a one sec sleep and winactivate in a loop so now you should get perfect focus on every vp game + debug mode - lot's of things was written to log file, I also added tool tip on top of the screen - but nothing is written anywhere by default only if you enable it with this option in settings.ini TO DO: - change key names to exitkey exitkey1 and startkey startkey1 for simlicity - remove usepause useexitasapuse useexitmenu options for simplicitiy - use prerotated menu images for simplicity - always use draw image by the book function for simplicity - put every repeating code to subroutines for simplicity - change instruction card menu item to instructions - enable png instructions - compile a set of png instructions and replay score cards and helps for setting replay levels, and tactics help, and ... (hopefully somebody will do this eventually) - test service menu - fix late printscreen in fp - fp auto positioning forgot to say - all images are there in zip file, just move them to media\hyperpin\images and one pixel offset bug is fixed also My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Blitz17 Posted October 31, 2011 Posted October 31, 2011 Installed newest WIP on my cab last night. Works great! Thanks for all your guys hardwork and time put in. It really adds a lot to the already great HyperPin software! Having a cabinet to play full screen pins is awesome! Check out my mini pin cab here on HSForums. http://www.hyperspin-fe.com/forum/showthread.php?t=11227
Guest gstav Posted October 31, 2011 Posted October 31, 2011 Thanks Blur and crew! Sounds like great features!!! :D
V1kt0R52 Posted October 31, 2011 Posted October 31, 2011 (edited) Thanks for work ! Great Job ! I've installed the new versions (WIP 6) but it makes all tables lag. So, back to WIP 5v3 and everything's OK. Only with WIP 6 I can see the ball rolling, not with previous version. Here's my config: Windows 7 Ultimate Edition (x64) (build 7601) Service Pack 1 Motherboard: SMBios version 2.5 MSI MS-7309 1.0 Bios: MS-7309 V1.11 04/03/2008 taille: 512Kb Chipset: Northbridge: NVIDIA MCP61 Southbridge: NVIDIA MCP61 Processor: AMD Athlon 64 X2 6000+ Windsor Socket AM2 (940) (@90 nm) 3000 Mhz ( L1I: 2 x 64 Ko, L1D: 2 x 64 Ko, L2: 2 x 1024 Ko ) Memory: Total Physical Memory: 2048 Mo, Type: DDR2, @376.7MHz, 5.0-5-5-18-2T DDR2 Corsair CM2X1024-6400 1024 Mo PC2-6400 (400 Mhz) (5.0-5-5-18) DDR2 Corsair CM2X1024-6400 1024 Mo PC2-6400 (400 Mhz) (5.0-5-5-18) Graphic Card: Radeon HD 4670 (RV730,,512 Mo) Monitors: 2 widescreen 22 inch in 1680x1050 Edited October 31, 2011 by V1kt0R52
shifters67 Posted October 31, 2011 Posted October 31, 2011 (edited) Hi guys, done some testing with WIP6. While it displays great - when i go into the menu in game, i get the menu up, can navigate up and down the list with the flipper buttons but I can't select anything. I tried the start button (which is 'x' on my machine) and launch ball (which is 'g' on my machine). While i configured up and down in the config to be what my flipper buttons are mapped too, there doesn't seem to be an option to define what the start/select key is to select the menu option. Is it optional for the sound to play? The noise is a bit harsh to me (but only my opinion i hasten to add!) Keep going with this great addition to hyperpin! Any ideas? regards Shifters Edited October 31, 2011 by shifters67
blur Posted October 31, 2011 Posted October 31, 2011 for viktor - just tested lots of tables - no lag for me except for tables that lag even outside of hyperpin, but i don't have win 7 to test with so, all is possible you could start in debug mode and send me log for shifter menu sound is menu.wav - you can put something else or remove it exit buttons are exitemulatorkey and pausekey start/select buttons are exitemulator1 and exitemulator2 (old names - old users will know them and have them already configured) - for next release names will change to exitkey exit1key and startkey start1key or something like that - it's all said in change log My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
slydog43 Posted October 31, 2011 Posted October 31, 2011 (edited) Getting better and better, totally awesome! I really love the moving ball in the loading screen. No slow down noticed yet, only play 2 games though. Being able to hit my favorite/flyer button is the middle of a game is top notch! Thank you. Really looking forward to png support! Any way to record date and time of all table launches, so a reporting type thing may be run making a list of the most played tables and such. I think others would like this also, or I may be wrong who knows? Edited November 1, 2011 by slydog43
rockyrocket Posted November 1, 2011 Posted November 1, 2011 All is working well here for me blur!. I have one feature request, is it possible to have a volume setting in the service menu so that a button is used as 7 the the flippers act as 8 and 9 for us that have no service buttons?. Starwars build Tron build Tempest build
V1kt0R52 Posted November 1, 2011 Posted November 1, 2011 Incomprehensible !!! Everything works fine today, so sorry for the post. No lag on tables. Send mp my log file if it can be useful.
blur Posted November 1, 2011 Posted November 1, 2011 tnx guys great idea for 7890 keys - during "service mode" some keys could be converted to 7890 maybe left and right flipper and left and right nudge or magna save - or make it configurable exit key could exit from service mode so all other keys could be used for 7890 it would be even better with some per table guide to setting replay levels and all options as image on the screen while we do this My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
rockyrocket Posted November 1, 2011 Posted November 1, 2011 Sweet!. Could do with an "end" key too!. Starwars build Tron build Tempest build
shifters67 Posted November 1, 2011 Posted November 1, 2011 Got it working fine - many thanks for the help! regards Shifters
blur Posted November 2, 2011 Posted November 2, 2011 (edited) h guys you probably noticed that for flyer you can see all images that have same game name. other parts of description like year manufacturer and all after that are not important. only name till first ( is checked. why? let's say you have two same games, but they are from different authors or one of them is night mod. you want them both in your hyperpin. but you want to see difference between them - for example you want them to have different screen shots - to see which one is which (from picture you see if it is megapin or jpsalas version), or you even want different wheel image - with night mode text. so you have to give those two games different description. if you keep HP naming convention you usually name them like this: Twilight Zone (Bally 1993) Twilight Zone (Bally 1993) NM so they can have diffferent wheel and backglass images but you don't want to copy all flyer images and instructions. so in my flyer browser in fplaunch i remove everything after first "(" and i search for all flyer images with name "Twilight Zone"* for now instructions are strictly tabledescription.swf but that will also be changed when i enable instructions browsing - then you will be able to browse through all docs with name shortdescription* this means that sometimes you'll have documents from other tables shown - for example airborne game will show all docs from airborne avenger also or eight ball will show all from eight ball champ and eight ball deluxe but i thought better to see more then to not see anything on some tables. now that i think of it i could change it so that it searches for all images with name "Twilight Zone ("* there could be a problem with instructions, i see there is a lot's of swf rules for every table, so you should check them manually and chose which one fits best to your settings and move others to some other folder, and possibly add whatever images and swf's you want (replay scores for example) what do you think? Edited November 2, 2011 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
slydog43 Posted November 2, 2011 Posted November 2, 2011 How do multiple pages work now, ie which pages gets loaded first, second, etc. tablename-1, tablename-2 - would it load them up alphanumerically or randomly if tablename matches like your last message. Blur what do you think about changing 'exit' to 'Exit To HyperPin' in the table pause/menu and Exit to 'Exit To Windows' in the HyperPin menu. I think it is clearer for newbies on my PinCab. (If not no biggie, I will just change the graphic myself, just thought others might want it also) Great work, Thanks. Make cab sooooo much better. Any idea when PNG support will be added?
Create an account
Register a new accountSign in
Sign In Now
